[PATCH] Add support for OpenRISC architecture.
Hesham Moustafa heshamelmatary at gmail.com
Tue Aug 12 10:25:57 UTC 2014
On Mon, Aug 11, 2014 at 8:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Aug 11, 2014 at 8:03 AM, Hesham ALMatary
> <heshamelmatary at gmail.com> wrote:
>> This work is based on the old or32 port (that has been removed back in 2005)
>> authored by Chris Ziomkowski. The patch includes the basic functions every
>> port should implement like: context switch, exception handling,
>> OpenRISC ABI and machine definitions and configurations.
>>  cpukit/configure.ac                                |    1 +
>>  cpukit/score/cpu/Makefile.am                       |    1 +
>>  cpukit/score/cpu/or1k/Makefile.am                  |   36 +
>>  cpukit/score/cpu/or1k/asm.h                        |  104 ++
>>  cpukit/score/cpu/or1k/cpu.c                        |  120 +++
>>  cpukit/score/cpu/or1k/or1k-context-initialize.c    |   43 +
>>  cpukit/score/cpu/or1k/or1k-context-switch.S        |  115 +++
>>  cpukit/score/cpu/or1k/or1k-exception-default.c     |   24 +
>>  cpukit/score/cpu/or1k/or1k-exception-frame-print.c |   22 +
>>  cpukit/score/cpu/or1k/or1k-exception-handler-low.S |  285 ++++++
>>  cpukit/score/cpu/or1k/rtems/asm.h                  |   99 ++
>>  cpukit/score/cpu/or1k/rtems/score/cpu.h            | 1049 ++++++++++++++++++++
>>  cpukit/score/cpu/or1k/rtems/score/cpu_asm.h        |   74 ++
>>  cpukit/score/cpu/or1k/rtems/score/or1k-utility.h   |  334 +++++++
>>  cpukit/score/cpu/or1k/rtems/score/or1k.h           |   49 +
>>  cpukit/score/cpu/or1k/rtems/score/types.h          |   51 +
>>  16 files changed, 2407 insertions(+)
>>  create mode 100644 cpukit/score/cpu/or1k/Makefile.am
>>  create mode 100644 cpukit/score/cpu/or1k/asm.h
>>  create mode 100644 cpukit/score/cpu/or1k/cpu.c
>>  create mode 100644 cpukit/score/cpu/or1k/or1k-context-initialize.c
>>  create mode 100644 cpukit/score/cpu/or1k/or1k-context-switch.S
>>  create mode 100644 cpukit/score/cpu/or1k/or1k-exception-default.c
>>  create mode 100644 cpukit/score/cpu/or1k/or1k-exception-frame-print.c
>>  create mode 100644 cpukit/score/cpu/or1k/or1k-exception-handler-low.S
>>  create mode 100644 cpukit/score/cpu/or1k/rtems/asm.h
> You have two of these asm.h files. You should only have this one.
>>  create mode 100644 cpukit/score/cpu/or1k/rtems/score/cpu.h
>>  create mode 100644 cpukit/score/cpu/or1k/rtems/score/cpu_asm.h
>>  create mode 100644 cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
>>  create mode 100644 cpukit/score/cpu/or1k/rtems/score/or1k.h
>>  create mode 100644 cpukit/score/cpu/or1k/rtems/score/types.h
>> diff --git a/cpukit/score/cpu/or1k/cpu.c b/cpukit/score/cpu/or1k/cpu.c
>> new file mode 100644
>> index 0000000..05e4cd9
>> --- /dev/null
>> +++ b/cpukit/score/cpu/or1k/cpu.c
>> @@ -0,0 +1,120 @@
>> + *  Opencore OR1K CPU Dependent Source
>> + *  COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>> + *  COPYRIGHT (c) 1989-1999.
>> + *  On-Line Applications Research Corporation (OAR).
>> + *  The license and distribution terms for this file may be
>> + *  found in the file LICENSE in this distribution or at
>> + *  http://www.rtems.com/license/LICENSE.
>> +#include <rtems/system.h>
>> +#include <rtems/score/isr.h>
>> +#include <rtems/score/wkspace.h>
>> +#include <bsp/linker-symbols.h>
>> + * @brief Performs processor dependent initialization.
>> +void _CPU_Initialize(void)
>> +  /* Do nothing */
>> + * @brief Sets the hardware interrupt level by the level value.
>> + * @param[in] level for or1k can only range over two values:
>> + * 0 (enable interrupts) and 1 (disable interrupts). In future
>> + * implementations if fast context switch is implemented, the level
>> + * can range from 0 to 15. @see OpenRISC architecture manual.
>> +inline void _CPU_ISR_Set_level(uint32_t level)
>> +  uint32_t sr = 0;
>> +  level = (level > 0)? 1 : 0;
>> +  /* map level bit to or1k interrupt enable/disable bit in sr register */
>> +  level <<= CPU_OR1K_SPR_SR_SHAMT_IEE;
>> +  sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
>> +  if (level == 0) /* Enable all interrupts */
>> +    sr |= CPU_OR1K_SPR_SR_IEE | CPU_OR1K_SPR_SR_TEE;
>> +  else
>> +    sr &= CPU_OR1K_ISR_STATUS_MASK_I_DIS;
> Put braces on same line as if/else, e.g.:
> if ( level == 0 ) {
> } else {
>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr);
>> +uint32_t  _CPU_ISR_Get_level( void )
>> +  uint32_t sr = 0;
>> +  return (sr & CPU_OR1K_SPR_SR_IEE)? 0 : 1;
>> +void _CPU_ISR_install_raw_handler(
>> +  uint32_t   vector,
>> +  proc_ptr    new_handler,
>> +  proc_ptr   *old_handler
>> +void _CPU_ISR_install_vector(
>> +  uint32_t    vector,
>> +   volatile proc_ptr *table =
>> +     (proc_ptr *) bsp_start_vector_table_begin;
> Why is this volatile?
>> +   proc_ptr current_handler;
>> +   ISR_Level level;
>> +  _ISR_Disable( level );
>> +  current_handler = table [vector];
>> +  /* The current handler is now the old one */
>> +  if (old_handler != NULL) {
>> +    *old_handler = (proc_ptr) current_handler;
>> +  /* Write only if necessary to avoid writes to a maybe read-only memory */
>> +  if (current_handler != (uint32_t) new_handler) {
>> +    table [vector] = (uint32_t) new_handler;
>> +   _ISR_Enable( level );
>> +void _CPU_Install_interrupt_stack( void )
>> +void _CPU_Context_Initialize_fp(
>> +  void **fp_context_ptr
>> +void _CPU_Thread_Idle_body( void )
>> +  for( ; ; );
>> +    /* insert your "halt" instruction here */
>> diff --git a/cpukit/score/cpu/or1k/or1k-exception-handler-low.S b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
>> index 0000000..00da0ec
>> --- /dev/null
>> +++ b/cpukit/score/cpu/or1k/or1k-exception-handler-low.S
>> @@ -0,0 +1,285 @@
>> + * @file
>> + * @ingroup ScoreCPU
>> + * @brief OR1K exception support implementation.
>> + *  http://www.rtems.org/license/LICENSE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <rtems/asm.h>
>> +#include <rtems/score/percpu.h>
>> +#include "rtems/score/or1k-utility.h"
>> +.align 4
>> +.text
>> +PUBLIC(_ISR_Handler)
>> +.type    _ISR_Handler, at function
>> + SYM(_ISR_Handler):
>> +  l.addi  r1, r1, -140
>> +  /* r3 is saved by BSP exception handler */
>> +  l.sw  16(r1),r4
>> +  l.sw  20(r1),r5
>> +  l.sw  24(r1),r6
>> +  /* Save interrupted task stack pointer */
>> +  l.addi r4, r1, 144
>> +  l.sw   4(r1), r4
>> +  /* Save interrupted task r3 (first arg) value */
>> +  l.addi r4, r1, 140
>> +  l.lwz  r4, 0(r4)
>> +  l.sw  12(r1), r4
>> +  /* Increment nesting level */
>> +  l.movhi r6, hi(ISR_NEST_LEVEL)
>> +  l.ori   r6, r6, lo(ISR_NEST_LEVEL)
>> +  l.lwz   r5, 0(r6)
>> +  l.addi  r5, r5, 1
>> +  l.sw    0(r6), r5
>> +  /* Disable multitasking */
>> +  l.movhi r6, hi(THREAD_DISPATCH_DISABLE_LEVEL)
>> +  l.ori   r6, r6, lo(THREAD_DISPATCH_DISABLE_LEVEL)
>> +  l.lwz   r5, 0(r6)
>> +  l.addi  r5, r5, 1
>> +  l.sw    0(r6), r5
>> +  l.sw  8(r1),r2
>> +  l.sw  24(r1),r6
>> +  l.sw  28(r1),r7
>> +  l.sw  32(r1),r8
>> +  l.sw  36(r1),r9
>> +  l.sw  40(r1),r10
>> +  l.sw  44(r1),r11
>> +  l.sw  48(r1),r12
>> +  l.sw  52(r1),r13
>> +  l.sw  56(r1),r14
>> +  l.sw  60(r1),r15
>> +  l.sw  64(r1),r16
>> +  l.sw  68(r1),r17
>> +  l.sw  72(r1),r18
>> +  l.sw  76(r1),r19
>> +  l.sw  80(r1),r20
>> +  l.sw  84(r1),r21
>> +  l.sw  88(r1),r22
>> +  l.sw  92(r1),r23
>> +  l.sw  96(r1),r24
>> +  l.sw  100(r1),r25
>> +  l.sw  104(r1),r26
>> +  l.sw  108(r1),r27
>> +  l.sw  112(r1),r28
>> +  l.sw  116(r1),r29
>> +  l.sw  120(r1),r30
>> +  l.sw  124(r1),r31
>> +  /* Exception level related registers */
>> +  /* EPCR */
>> +  l.mfspr r13, r0, CPU_OR1K_SPR_EPCR0
>> +  l.sw  128(r1), r13 /* epcr */
>> +  /* EEAR */
>> +  l.mfspr r13, r0, CPU_OR1K_SPR_EEAR0
>> +  l.sw  132(r1), r13 /* eear */
>> +  /* ESR */
>> +  l.mfspr r13, r0, CPU_OR1K_SPR_ESR0
>> +  l.sw  136(r1), r13  /* esr */
>> +  /* Keep r1 (Exception frame address) in r14 */
>> +  l.add   r14, r1, r0
> I take it that r14 is a callee-save register?
Yes it's.
>> +  /* Call the exception handler from vector table */
>> +  /* First function arg for C handler is vector number,
>> +   * and the second is a pointer to exception frame.
>> +  l.add  r13, r3, r0
>> +  l.add  r4, r1, r0
>> +  l.slli r13, r13, 2
>> +  l.addi r13, r13, lo(bsp_start_vector_table_begin)
>> +  l.lwz  r13, 0(r13)
>> +   /* Switch to RTEMS dedicated interrupt stack */
>> +  l.movhi r1, hi(INTERRUPT_STACK_HIGH)
>> +  l.ori   r1, r1, lo(INTERRUPT_STACK_HIGH)
>> +  l.lwz   r1, 0(r1)
> If this is a nested interrupt, you should not switch the stack, since
> execution is already on the interrupt stack. Make a note of where you
> store the pointer to the task stack (r14). I think saving the frame
> pointer in r14 only has to be done if you switch the stack, since
> otherwise you can obtain it by simple unwinding in the interrupt
> stack.
Yes. But currently the port does not support nesting interrupts. It's
mentioned in the OpenRISC architecture manual that nesting interrupts
should not occur unless fast context switch is implement (which is not
supported in the port in the time being). I can insert a check on the
value of isr nesting level, and only switch the stack if it's 1, would
this be a correct implementation?
>> +  l.jalr r13
>> +  l.nop
>> + SYM(exception_frame_restore):
>> +  l.add r1, r14, r0
> Add comment here that you are switching back to the interrupted stack.
> Again, notice that it may not be needed if you don't switch stacks due
> to nested interrupts.
>> +  /* EPCR */
>> +  l.lwz  r13,  128(r1)
>> +  l.mtspr r0, r13, CPU_OR1K_SPR_EPCR0
>> +  /* EEAR */
>> +  l.lwz  r13,  132(r1)
>> +  l.mtspr r0, r13, CPU_OR1K_SPR_EEAR0
>> +  /* ESR */
>> +  l.lwz  r13,  136(r1)
>> +  l.mtspr r0, r13, CPU_OR1K_SPR_ESR0
>> +  /* Decrement nesting level */
>> +  l.lwz   r5, 0(r6)
>> +  l.addi  r5, r5, -1
>> +  l.sw    0(r6), r5
>> +  /* Enable multitasking */
>> +  l.lwz   r5, 0(r6)
>> +  l.addi  r5, r5, -1
>> +  l.sw    0(r6), r5
>> +  l.lwz  r2,  8(r1)
>> +  l.lwz  r3,  12(r1)
>> +  l.lwz  r4,  16(r1)
>> +  l.lwz  r5,  20(r1)
>> +  l.lwz  r6,  24(r1)
>> +  l.lwz  r7,  28(r1)
>> +  l.lwz  r8,  32(r1)
>> +  l.lwz  r9,  36(r1)
>> +  l.lwz  r10, 40(r1)
>> +  l.lwz  r11, 44(r1)
>> +  l.lwz  r12, 48(r1)
>> +  l.lwz  r13, 52(r1)
>> +  l.lwz  r14, 56(r1)
>> +  l.lwz  r15, 60(r1)
>> +  l.lwz  r16, 64(r1)
>> +  l.lwz  r17, 68(r1)
>> +  l.lwz  r18, 72(r1)
>> +  l.lwz  r19, 76(r1)
>> +  l.lwz  r20, 80(r1)
>> +  l.lwz  r21, 84(r1)
>> +  l.lwz  r22, 88(r1)
>> +  l.lwz  r23, 92(r1)
>> +  l.lwz  r24, 96(r1)
>> +  l.lwz  r25, 100(r1)
>> +  l.lwz  r26, 104(r1)
>> +  l.lwz  r27, 108(r1)
>> +  l.lwz  r28, 112(r1)
>> +  l.lwz  r29, 116(r1)
>> +  l.lwz  r30, 120(r1)
>> +  l.movhi r31, hi(DISPATCH_NEEDED)
>> +  l.ori   r31, r3, lo(DISPATCH_NEEDED)
>> +  l.lwz   r31, 0(r31)
>> +  l.sfgtu r31, r0
>> +  l.lwz   r31, 124(r1)
>> +  l.bf    _ISR_Dispatch /* Thread dispatch necessary */
>> +  l.nop
>> +  l.addi r1, r1, 140
>> +  l.lwz  r3, 0(r1)
>> +  l.addi r1, r1, 4
>> +  l.rfe
>> +  l.nop
>> +PUBLIC(_ISR_Dispatch)
>> +SYM (_ISR_Dispatch):
>> +  l.sw  4(r1),r1
>> +  l.sw  8(r1),r2
>> +  l.sw  16(r1),r4
>> +  l.sw  20(r1),r5
>> +  l.sw  24(r1),r6
>> +  l.sw  28(r1),r7
>> +  l.sw  32(r1),r8
>> +  /* Skip r10 as it's preserved to be used by TLS */
>> +  /* The following set of registers are preserved across function calls */
>> +  l.sw  56(r1),r14
>> +  l.sw  64(r1),r16
>> +  l.sw  72(r1),r18
>> +  l.sw  80(r1),r20
>> +  l.sw  88(r1),r22
>> +  l.sw  96(r1),r24
>> +  l.sw  104(r1),r26
>> +  l.sw  112(r1),r28
>> +  l.sw  120(r1),r30
> You can probably avoid saving the context here and restoring it later,
> by moving the  DISPATCH_NEEDED check to before
> exception_frame_restore(). Then you would just jump to
> exception_frame_restore() after the call to _Thread_Dispatch(), and
> you can get rid of this redundant code. Yes?
Great advice. I have implemented it and the program runs smoothly. Thanks.
>> +  l.movhi r13, hi(_Thread_Dispatch)
>> +  l.ori   r13, r13, lo(_Thread_Dispatch)
>> +  l.jalr  r13
>> +  l.nop
>> +  /* EPCR */
>> +  /* EEAR */
>> +  /* ESR */
>> +  l.lwz  r1,  4(r1)
>> +  l.lwz  r2,  8(r1)
>> +  l.lwz  r4,  12(r1)
>> +  l.lwz  r4,  16(r1)
>> +  l.lwz  r5,  20(r1)
>> +  l.lwz  r6,  24(r1)
>> +  l.lwz  r7,  28(r1)
>> +  l.lwz  r8,  32(r1)
>> +  l.lwz  r9,  36(r1)
>> +  l.lwz  r10, 40(r1)
>> +  l.lwz  r11, 44(r1)
>> +  l.lwz  r12, 48(r1)
>> +  l.lwz  r13, 52(r1)
>> +  l.lwz  r14, 56(r1)
>> +  l.lwz  r15, 60(r1)
>> +  l.lwz  r16, 64(r1)
>> +  l.lwz  r17, 68(r1)
>> +  l.lwz  r18, 72(r1)
>> +  l.lwz  r19, 76(r1)
>> +  l.lwz  r20, 80(r1)
>> +  l.lwz  r21, 84(r1)
>> +  l.lwz  r22, 88(r1)
>> +  l.lwz  r23, 92(r1)
>> +  l.lwz  r24, 96(r1)
>> +  l.lwz  r3, 0(r1)
>> +  l.addi r1, r1, 4
>> +  l.rfe
>> +  l.nop
> (This is cpu.h):
>> + *  Disable all interrupts for an RTEMS critical section.  The previous
>> + *  level is returned in _level.
>> +static inline uint32_t or1k_interrupt_disable( void )
>> +  volatile uint32_t sr;
> Why is sr volatile?
>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, (sr & CPU_OR1K_ISR_STATUS_MASK_I_DIS));
>> +  return sr;
>> +static inline void or1k_interrupt_enable(uint32_t level)
> Ditto.
>> +  /* Enable interrupts and restore rs */
>> +  sr = level | CPU_OR1K_SPR_SR_IEE | CPU_OR1K_SPR_SR_TEE;
>> +#define _CPU_ISR_Disable( _isr_cookie ) \
>> +  do{ \
>> +    _isr_cookie = or1k_interrupt_disable(); \
>> +  } while (0)
> For a one-line macro, you don't need this do-while construct. You did
> it correctly below.
>> + *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
>> + *  This indicates the end of an RTEMS critical section.  The parameter
>> + *  _level is not modified.
>> +#define _CPU_ISR_Enable( _isr_cookie )  \
>> +  or1k_interrupt_enable( _isr_cookie )
>> + *  This temporarily restores the interrupt to _level before immediately
>> + *  disabling them again.  This is used to divide long RTEMS critical
>> + *  sections into two or more parts.  The parameter _level is not
>> + *  modified.
>> +#define _CPU_ISR_Flash( _isr_cookie ) \
> Is there a reason you don't provide an ISR_Flash implementation? This
> should just be an enable followed by disable in a do-while cpp macro.
>> +#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE
>> +#define CPU_TIMESTAMP_USE_INT64 FALSE
>> +#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
> Almost all CPUs in RTEMS are using int64. Is there a good reason not
> to for or1k?
>> diff --git a/cpukit/score/cpu/or1k/rtems/score/cpu_asm.h b/cpukit/score/cpu/or1k/rtems/score/cpu_asm.h
>> index 0000000..a5659f3
>> --- /dev/null
>> +++ b/cpukit/score/cpu/or1k/rtems/score/cpu_asm.h
> What's the point of this file, it appears mostly empty to me and isn't
> included anywhere.
>> @@ -0,0 +1,74 @@
>> + * @file
>> + * @brief OR1K Assembly File
>> + * Very loose template for an include file for the cpu_asm.? file
>> + * if it is implemented as a ".S" file (preprocessed by cpp) instead
>> + * of a ".s" file (preprocessed by gm4 or gasp).
>> +#ifndef _RTEMS_SCORE_CPU_ASM_H
>> +#define _RTEMS_SCORE_CPU_ASM_H
>> +/* pull in the generated offsets */
>> +#include <rtems/score/offsets.h>
>> + * Hardware General Registers
>> +/* put something here */
>> + * Hardware Floating Point Registers
>> + * Hardware Control Registers
>> + * Calling Convention
>> + * Temporary registers
>> + * Floating Point Registers - SW Conventions
>> + * Temporary floating point registers
>> +#endif
>> +/* end of file */
>> diff --git a/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h b/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
>> index 0000000..2187c63
>> --- /dev/null
>> +++ b/cpukit/score/cpu/or1k/rtems/score/or1k-utility.h
>> +/* Used to disable interrupts */
>> +#define CPU_OR1K_ISR_STATUS_MASK_I_DIS  0xFFFFFFFB
> This is just ~(CPU_OR1K_SPR_SR_IEE). I would just use that and get rid
> of this macro.
>> +#ifndef ASM
>> +#include <stddef.h>
>> +#include <stdint.h>
>> +#include <stdbool.h>
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif /* __cplusplus */
>> + * @brief Supervision Mode registers definitions.
>> + * @see OpenRISC architecture manual - revision 0.
>> +typedef enum {
>> +  OR1K_EXCEPTION_RESET = 1,
>> +  OR1K_EXCEPTION_BUS_ERR = 2,
>> +  OR1K_EXCEPTION_D_PF = 3, /* Data Page Fault */
>> +  OR1K_EXCEPTION_I_PF = 4, /* Instruction Page Fault */
>> +  OR1K_EXCEPTION_TICK_TIMER = 5,
>> +  OR1K_EXCEPTION_ALIGNMENT = 6,
>> +  OR1K_EXCEPTION_I_UNDEF= 7, /* Undefiend instruction */
>> +  OR1K_EXCEPTION_IRQ = 8, /* External interrupt */
>> +  OR1K_EXCPETION_D_TLB = 9, /* Data TLB miss */
>> +  OR1K_EXCPETION_I_TLB = 10, /* Instruction TLB miss */
>> +  OR1K_EXCPETION_RANGE = 11, /* Range exception */
>> +  OR1K_EXCPETION_SYS_CALL = 12,
>> +  OR1K_EXCPETION_FP = 13, /* Floating point exception */
>> +  OR1K_EXCPETION_TRAP = 14, /* Caused by l.trap instruction or by debug unit */
>> +  OR1K_EXCPETION_RESERVED1 = 15,
>> +  OR1K_EXCPETION_RESERVED2 = 16,
>> +  OR1K_EXCPETION_RESERVED3 = 17,
>> +  MAX_EXCEPTIONS = 17,
>> +  OR1K_EXCEPTION_MAKE_ENUM_32_BIT = 0xffffffff
>> +} OR1K_symbolic_exception_name;
> capitalize the S in symbolic.
>> +static inline uint32_t _OR1K_mfspr(uint32_t reg)
>> +   uint32_t spr_value;
>> +   asm volatile (
>> +     "l.mfspr  %1, r0, 0"
>> +     : "=r" (spr_value) : "r" (reg));
> Something is wrong with your assembly here. I think you want to be
> saying "l.mfspr spr_value, reg, 0"? This would be written as:
> asm volatile("l.mfspr %0, %1, 0" : "=r" (spr_value) : "r" (reg));
> Also, to make reading disassembly easier, you should put a \n\t at the
> end of each line of assembly, i.e. "l.mfspr %0, %1, 0\n\t".
> -Gedare
