[PATCH 1/2] arm: Add support for FPv4-SP floating point unit
Peter Dufault dufault at hda.com
Tue Aug 12 11:32:23 UTC 2014
On Aug 11, 2014, at 17:02 , Gedare Bloom <gedare at rtems.org> wrote:
>> +#ifdef ARM_MULTILIB_VFP
>> +       /* CPACR is located at address 0xe000ed88 */
>> +       ldr.w   r0, =0xe000ed88
> Maybe the constant should be provided by a header file? The comments
> are nice though. And I didn't see anything else in the rest, although
> my arm asm is rusty.
When used in a single place in a hardware specific C file I prefer a constant.  When I'm suspicious I'm comparing definitions against the reference manuals looking for transcription errors and I'd rather avoid the indirection.  Obviously it needs an appropriate constant (which Sebastian provides).
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
