[PATCH 1/2] arm: Add support for FPv4-SP floating point unit
Tue Aug 12 18:42:54 UTC 2014
On 08/12/2014 04:08 PM, Gedare Bloom wrote:
> On Tue, Aug 12, 2014 at 7:32 AM, Peter Dufault<dufault at hda.com>  wrote:
>> >On Aug 11, 2014, at 17:02 , Gedare Bloom<gedare at rtems.org>  wrote:
>>>> >>>+#ifdef ARM_MULTILIB_VFP
>>>> >>>+       /* CPACR is located at address 0xe000ed88 */
>>>> >>>+       ldr.w   r0, =0xe000ed88
>>> >>Maybe the constant should be provided by a header file? The comments
>>> >>are nice though. And I didn't see anything else in the rest, although
>>> >>my arm asm is rusty.
>> >When used in a single place in a hardware specific C file I prefer a constant.  When I'm suspicious I'm comparing definitions against the reference manuals looking for transcription errors and I'd rather avoid the indirection.  Obviously it needs an appropriate constant (which Sebastian provides).
> True, and the comment is pretty clear. So, either way. I guess I am
> surprised the constant is only used in this one place.
If there is only one place, then there is no real need for a define.  I
added improved exception support, so now we have two places and a define.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
