Using rtl-host in covor - some questions
Wed Aug 13 20:48:41 UTC 2014
On 8/13/2014 3:28 PM, Chris Johns wrote:
> Hi,
> Sorry about not responding before now. It had dropped of my list and I
> had forgotten about it.
> On 12/08/2014 9:58 pm, Krzysztof Mięsowicz wrote:
>> Hi,
>> I'm currently working on adding symbol generation to covoar. I'm going
>> to use rtl::process::execute function to run nm from covoar (as
>> suggested by Chris). I do not know exactly how should I use this in
>> covoar. Should I build rtl-host as a library and link it to covoar? Or
>> maybe there is another, better option?
> This is a really good question. Having covoar and rtems-host work
> together is a really thing because there is lots of good code to reuse.
> Currently the rtems-host repo is my private area and maybe this need to
> change. It is difficult to have both work together when in separate
> repos. Joel, should this code be moved to the rtems-tools.git repo ?
covoar has moved.
rtems-coverage I think is the other directory that would have to move.
It is OK by me.
> As it stands rtems-host builds 3 static libraries and you can use those...
> $ ls build-linux2/*.a
> build-linux2/libelf.a
> build-linux2/libiberty.a
> build-linux2/librld.a
As I recall, we just need to look up the address for a specific symbol.
I assume
libelf.a has that.
I have used covoar with C++ but don't recall how the name mangling was
addressed.
> Chris
> devel mailing list
> devel at rtems.org
