[PATCH] BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Aug 14 08:53:08 UTC 2014
Hello Sebastian,
On Thursday 14 of August 2014 10:07:06 Sebastian Huber wrote:
> On 14/08/14 09:48, Pavel Pisa wrote:
> > https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/arch
> >/mips/include/uapi/asm/inst.h?id=refs/tags/v3.15#n486
> My experience with bitfields at this level is that GCC is regularly broken
> in this area.
Aligned with my feeling that it is dangerous and combined with required
volatile for regs can lead even to worse code.
> > But I generally prefer more only defines used for such fields.
> > Then it would look something like
> >    TMS570_SCI_SCICLEARINT_XXX
> > My notation is to add suffix "_m" for mask, "_b" for starting bit
> > position if used and where are offset from base "_o". The "_m" and "_b"
> > quite usesfull because C dosenit warn you when starting bit or mask is
> > mixed and results of mixing are quite damaging.
> > But use of macros leads to quite complex/long lines in the code.
> Yes, I prefer this too.  You may have a look at
> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/shared/include/arm-pl0
>11-regs.h
I am OK with single bit masks - BSP_BIT32(7), but I prefer only single
define per multi bit field. So my own approach is to use macros to find
field start bit from maks
/*masked fields macros*/
#define __val2mfld(mask,val) (((mask)&~((mask)<<1))*(val)&(mask))
#define __mfld2val(mask,val) (((val)&(mask))/((mask)&~((mask)<<1)))
for constant masks they compile optimal way and for variable
they are usable too if CPU has ffs/clz support.
http://sourceforge.net/p/ulan/sysless/ci/master/tree/arch/arm/generic/defines/cpu_def.h
This is how I use it in our bare HW/system-less code
http://sourceforge.net/p/ulan/sysless/ci/master/tree/libs4c/spi/spi_lpcssp.c#l200
 lpcssp_drv->ssp_regs->CR0 =
     __val2mfld(SSP_CR0_DSS_m, lpcssp_drv->data16_fl? 16 - 1 : 8 - 1) |
     __val2mfld(SSP_CR0_FRF_m, 0) |
     (msg->size_mode & SPI_MODE_CPOL? SSP_CR0_CPOL_m: 0) |
     (msg->size_mode & SPI_MODE_CPHA? SSP_CR0_CPHA_m: 0) |
     __val2mfld(SSP_CR0_SCR_m, 15);
http://sourceforge.net/p/ulan/sysless/ci/master/tree/arch/arm/mach-lpc17xx/libs/hal/hal_gpio.c#l32
So I would prefer something like that. But I agree that it can hurt
someone else eyeballs as well.
I have seen similar solution in Nvidia driver sources with even
really interresting (ab)use of ternary C operator.
But if RTEMS preference is to define all fields twice with SET and GET
then I would suggest that to Premek.
Best wishes,
              Pavel
