[PATCH] BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Aug 14 13:46:40 UTC 2014
Hello Gedare,
On Thursday 14 of August 2014 15:12:44 Gedare Bloom wrote:
> On Thu, Aug 14, 2014 at 4:53 AM, Pavel Pisa <pisa at cmp.felk.cvut.cz> wrote:
 > I am OK with single bit masks - BSP_BIT32(7), but I prefer only single
> > define per multi bit field. So my own approach is to use macros to find
> > field start bit from maks
> > /*masked fields macros*/
> > #define __val2mfld(mask,val) (((mask)&~((mask)<<1))*(val)&(mask))
> > #define __mfld2val(mask,val) (((val)&(mask))/((mask)&~((mask)<<1)))
> Do you get the similar effect from BSP_FLD32?
> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/shared/include/utility.h#n
>68
You get exactly same code if mask is constant and contains only
single continuous region of one bits. The main advantage is,
that you can define everything required to describe field
by single plain define
#define MODULEx_REGy_FIELDx_m 0x00000f00
or in BSP utility language more readable
#define MODULEx_REGy_FIELDx_m BSP_MSK32(8, 11)
Then to access filed in register (if struct is used for registers
placement in memory) you get
value = __mfld2val(MODULEx_REGy_FIELDx_m, MODULEx->REGy);
to setup register by values for more fields
  MODULEx->REGy = __val2mfld(MODULEx_REGy_FIELD1_m, val1) |
                  __val2mfld(MODULEx_REGy_FIELD2_m, val2);
To replace field value
  MODULEx->REGy = (MODULEx->REGy & ~MODULEx_REGy_FIELDz_m) |
                  __val2mfld(MODULEx_REGy_FIELDz_m, val1);
I see significant advantage in defining of plain masks without get/set
that they suggest to be used directly in more situations.
I.e. used in atomic clear mask or other special instructions.
In the fact, real mask can be retrieved from set/get pair by little
(or bigger) hack
   MODULEx_REGy_FIELDx_SET(~1)
You can get the first bit position still too
   __builtin_ffs(MODULEx_REGy_FIELDx_SET(~1))
and bit count similar way from get or by more ops from SET.
But seems to be hacky to me.
Anyway all these is compiled to constants by GCC.
So no overhead only final and and shift if value
put into field is not constant.
I have used __val2mfld/__mfld2val names with two underscores
to be outside of clash with POSIX when masks are used
in generic headerfiles which can be included by third party
libraries.
But if you accept these in BSP_ space for RTEMS, I would be happy
with any other descriptive name
#define BSP_TOFLD(mask,val) (((mask)&~((mask)<<1))*(val)&(mask))
#define BSP_FROMFLD(mask,val) (((val)&(mask))/((mask)&~((mask)<<1)))
or under some other name BSP_MF2V  BSP_V2MF ???? in
> > for constant masks they compile optimal way and for variable
> > they are usable too if CPU has ffs/clz support.
> > http://sourceforge.net/p/ulan/sysless/ci/master/tree/arch/arm/generic/def
> >ines/cpu_def.h
> > This is how I use it in our bare HW/system-less code
> > http://sourceforge.net/p/ulan/sysless/ci/master/tree/libs4c/spi/spi_lpcss
> >p.c#l200
> >  lpcssp_drv->ssp_regs->CR0 =
> >      __val2mfld(SSP_CR0_DSS_m, lpcssp_drv->data16_fl? 16 - 1 : 8 - 1) |
> >      __val2mfld(SSP_CR0_FRF_m, 0) |
> >      (msg->size_mode & SPI_MODE_CPOL? SSP_CR0_CPOL_m: 0) |
> >      (msg->size_mode & SPI_MODE_CPHA? SSP_CR0_CPHA_m: 0) |
> >      __val2mfld(SSP_CR0_SCR_m, 15);
> > http://sourceforge.net/p/ulan/sysless/ci/master/tree/arch/arm/mach-lpc17x
> >x/libs/hal/hal_gpio.c#l32
Best wishes,
                  Pavel
