Console driver that needs extra TIMER
Thu Aug 14 14:20:07 UTC 2014
On Thu, Aug 14, 2014 at 10:15 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 8/14/2014 9:11 AM, Kolja Waschk wrote:
>> Hi,
>> I'm developing a DMA-based UART driver for Blackfin. It requires an
>> extra timer to trigger data processing after a transmission ended. This
>> increases the amount of timers required by every application that uses
>> it for the console.
> Don't you get an end of DMA TX interrupt?
>> E.g. most of the tests won't even start without modifications. So
>> effectively I have to fall back to a polling driver for console if I
>> want to run the tests unmodified, or is there any mechanism to generally
>> increment the amount of timers for all tests?
> I don't think so. There are some BSP hooks for various features and
> default number
> of termios ports. But nothing specific to an object.
If you are working with rtems.git, you could probably just add another
BSP setting in confdefs.h for this and push the patch out for
inclusion in RTEMS. Something like CONFIGURE_BSP_TIMERS() that gets
added into CONFIGURE_MAXIMUM_TIMERS(). If you need more guidance how
to do this just ask.
> I suppose one could be added but for orthogonality, it would make me wonder
> why we wouldn't also let you add a BSP factor on every Classic API object.
> Just thinking out load.
Joel, what kind of load?
There are probably only a few object-types that a BSP might need to
reserve for use, but it may be worth considering.
-Gedare
>> Thanks,
>> Kolja
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
