Console driver that needs extra TIMER
Thu Aug 14 17:08:07 UTC 2014
On 8/14/2014 12:02 PM, Kolja Waschk wrote:
>>> If you are working with rtems.git, you could probably just add another
>>> BSP setting in confdefs.h for this and push the patch out for
> Thanks for that hint. There already seems to be such mechanism in place for SHARED_MEMORY_DRIVER:
Glad  you have a temporary solution. I think the permanent solution may
unfortunately be
something that feels it like this (which could grow by drivers * object
classes):
bsp.h:
  #define CONFIGURE_BSP_TIMERS_FOR_CONSOLE_DRIVER 1
confdefs.h:
  default it in the "no bsp section"
  later in a section for standard driver  resources
  #ifndef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
  #undef CONFIGURE_BSP_TIMERS_FOR_CONSOLE_DRIVER
  #define CONFIGURE_BSP_TIMERS_FOR_CONSOLE_DRIVER 0
  #endif
  and then use it in the timer configuration line.
> confdefs.h
> rtems_api_configuration_table Configuration_RTEMS_API = {
>    CONFIGURE_TASKS,
>    CONFIGURE_NOTEPADS_ENABLED,
>    CONFIGURE_MAXIMUM_TIMERS + CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER,
>    CONFIGURE_SEMAPHORES,
> At least confdefs allows to add something to CONFIGURE_MAXIMUM_TIMERS so I can
> patch it for running the tests, and soon make it properly dependent on some
> BSP setting.
> Thanks,
> Kolja
> devel mailing list
> devel at rtems.org
