Console driver that needs extra TIMER
Thu Aug 14 17:52:41 UTC 2014
On 8/14/2014 12:13 PM, Gedare Bloom wrote:
> Joel,
> A problem with the approach you outlined is as Sebastian said, you
> still end up overestimating if for example the application does not
> use the DMA-based console but uses a different console within the same
> bsp.
That is true but the bspopts.h should be able to detect that. Wouldn't
that be
like polled versus interrupt? It is a BSP configure.ac issue that is
reflected in
bspopts.h.  I don't think you would be switching the mode
DMA/interrupt/polled
after BSP configure/build time
In this case, the BSP would just have to be a little more careful to
define things
correctly for each console driver configuration. The one defined would
get used
if the driver were configured.
--joel
> -Gedare
> On Thu, Aug 14, 2014 at 1:08 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> On 8/14/2014 12:02 PM, Kolja Waschk wrote:
>>>>> If you are working with rtems.git, you could probably just add another
>>>>> BSP setting in confdefs.h for this and push the patch out for
>>> Thanks for that hint. There already seems to be such mechanism in place for SHARED_MEMORY_DRIVER:
>> Glad  you have a temporary solution. I think the permanent solution may
>> unfortunately be
>> something that feels it like this (which could grow by drivers * object
>> classes):
>> bsp.h:
>>   #define CONFIGURE_BSP_TIMERS_FOR_CONSOLE_DRIVER 1
>> confdefs.h:
>>   default it in the "no bsp section"
>>   later in a section for standard driver  resources
>>   #ifndef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>   #undef CONFIGURE_BSP_TIMERS_FOR_CONSOLE_DRIVER
>>   #define CONFIGURE_BSP_TIMERS_FOR_CONSOLE_DRIVER 0
>>   #endif
>>   and then use it in the timer configuration line.
>>> confdefs.h
>>> rtems_api_configuration_table Configuration_RTEMS_API = {
>>>    CONFIGURE_TASKS,
>>>    CONFIGURE_NOTEPADS_ENABLED,
>>>    CONFIGURE_MAXIMUM_TIMERS + CONFIGURE_TIMER_FOR_SHARED_MEMORY_DRIVER,
>>>    CONFIGURE_SEMAPHORES,
>>> At least confdefs allows to add something to CONFIGURE_MAXIMUM_TIMERS so I can
>>> patch it for running the tests, and soon make it properly dependent on some
>>> BSP setting.
>>> Thanks,
>>> Kolja
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
