[PATCH] RTL: Fix options handle and add a new option to rtems-ld
Fri Aug 15 08:15:50 UTC 2014
On 14/08/2014 11:21 am, Peng Fan wrote:
> Hi,
> I have a two days travel, so this reply is late.
> 2014-08-12 10:56 GMT+08:00 Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>>:
>     On 11/08/2014 12:24 am, Peng Fan wrote:
>         1. Fix getopt_long usage in rtl host. some shorthand options are not
>         hanlded correctly, this patch fixes it.
>     Thanks for cleaning this up.
>         2. Add a new option '--mach-flags'/'-m' to rtems-ld. This optarg
>         of this
>         option will be passed to xx-rtemsxx-gcc, it will be used the
>         search lib
>         dirs. Detailed msg is in the commit log of the patch.
>     I wonder if we need the explicit -march and -mcpu options and this
>     or should we remove them and add a more general option that can
>     include these flags. When I added the -march etc I thought this was
>     all that was needed and that is proving to be a little naive.
> If -march and -mcpu are only passed to gcc to let gcc search the libs, I
> think we can add a more generic option.
>     What do you think ?
> I think we can extract the 'machine' related flags from rtems bsp and
> build a table in rtl-host like the following:
> struct bsp_flag {
> char* bsp_name;
> char* flags;
> Here machine related flags in gcc is at
> https://gcc.gnu.org/onlinedocs/gcc-4.8.3/gcc/ chapter 3.17.
> struct bsp_flag bsp_flags[RTEMS_BSP_NUMS];
> alloc space
> bsp_flags[0].bsp_name = bsp name from rtems source code
> bsp_flags[0].flags = machine flags from rtems source code corresponding
> to the bsp
> bsp_flags[1]
> bsp_flags[2]
I think the user should manage this in their build environment. The
rtems-tld (trace linker) will need the BSP set up to work so this is a
different case.
> Using the machine flags, xxx_rtemsxx_gcc can search the related libs
> first, if not found, then search the common libs, because the machine
> related lib path is in the first.
Yes it can.
> Just my thought, the code above is not good. Hmm. using String, new and
> class in c++
I understand.
> I think we may pass a madantory bsp name to rtl-host, such as "--bsp
> xxxxxxx" , xxxxxxx means the bsp name
Or we pass --cc-flags and let the user manage the interface to the BSP.
