[PATCH] RTL: Fix options handle and add a new option to rtems-ld
Sat Aug 16 02:51:27 UTC 2014
On 15/08/2014 7:37 pm, Peng Fan wrote:
> On 08/15/2014 04:15 PM, Chris Johns wrote:
>> On 14/08/2014 11:21 am, Peng Fan wrote:
>>> Hi,
>>> I have a two days travel, so this reply is late.
>>> 2014-08-12 10:56 GMT+08:00 Chris Johns <chrisj at rtems.org
>>> <mailto:chrisj at rtems.org>>:
>>>     On 11/08/2014 12:24 am, Peng Fan wrote:
>>>         1. Fix getopt_long usage in rtl host. some shorthand options
>>> are not
>>>         hanlded correctly, this patch fixes it.
>>>     Thanks for cleaning this up.
>>>         2. Add a new option '--mach-flags'/'-m' to rtems-ld. This optarg
>>>         of this
>>>         option will be passed to xx-rtemsxx-gcc, it will be used the
>>>         search lib
>>>         dirs. Detailed msg is in the commit log of the patch.
>>>     I wonder if we need the explicit -march and -mcpu options and this
>>>     or should we remove them and add a more general option that can
>>>     include these flags. When I added the -march etc I thought this was
>>>     all that was needed and that is proving to be a little naive.
>>> If -march and -mcpu are only passed to gcc to let gcc search the libs, I
>>> think we can add a more generic option.
>>>     What do you think ?
>>> I think we can extract the 'machine' related flags from rtems bsp and
>>> build a table in rtl-host like the following:
>>> struct bsp_flag {
>>> char* bsp_name;
>>> char* flags;
>>> Here machine related flags in gcc is at
>>> https://gcc.gnu.org/onlinedocs/gcc-4.8.3/gcc/ chapter 3.17.
>>> struct bsp_flag bsp_flags[RTEMS_BSP_NUMS];
>>> alloc space
>>> bsp_flags[0].bsp_name = bsp name from rtems source code
>>> bsp_flags[0].flags = machine flags from rtems source code corresponding
>>> to the bsp
>>> bsp_flags[1]
>>> bsp_flags[2]
>> I think the user should manage this in their build environment. The
>> rtems-tld (trace linker) will need the BSP set up to work so this is a
>> different case.
> I have not read related source code. what is it for?
The rtems-tld is a trace linker. It is still being worked on and not
usable. Trace linking lets a user define a set of functions they want to
trace and rtems-tld will generate the wrapping functions, compile them
and perform a link using the GNU ld's '--wrap=symbol' option. This will
combine with the capture engine to allow real-time tracing on targets.
The first pass of the rtems-tld will provide a proof of concept way to
output to stdout entry to a function with the arguments and the return
value shown as hex dumps. The capture engine integration is happening
slowly with Jennifer and is the end objective.
If things work out with rtems-tld the wrapping generators will be
specified in INI files which lets users provide custom ways to trace
execution. The INI files in the repo show the idea being worked on.
>>> Using the machine flags, xxx_rtemsxx_gcc can search the related libs
>>> first, if not found, then search the common libs, because the machine
>>> related lib path is in the first.
>> Yes it can.
>>> Just my thought, the code above is not good. Hmm. using String, new and
>>> class in c++
>> I understand.
>>> I think we may pass a madantory bsp name to rtl-host, such as "--bsp
>>> xxxxxxx" , xxxxxxx means the bsp name
>> Or we pass --cc-flags and let the user manage the interface to the BSP.
> If not pass correct machine flags to gcc, rtems-ld may link wrong
> libgcc.a and other libxxx.a, and rtems-ld can not give any error msg
> about this. At last, when loading rap file, error occurs, but hard to
> find what happens.
> I am not sure, but I think let user to handle the machine flags is not
> user friendly, unless users are clearly about what machine flags should
> be passed to xx-rtemsxx-gcc by rtems-ld.
> If using --cc-flags, this option may be manatory, but not optional. And
> the user should extract the machine flags from rtems source code.
> I think  passing bsp name to rtems-ld, and rtems-ld search a table which
> contains bsps' name and the machine flags corresponding to the bsp. If
> the bsp name passed to rtems-ld can not be found in the table, rtems-ld
> complains err msg, If found, then all is fine.
This sounds reasonable. Maybe we provide both and users can decide. The
bsp option may be suitable and may need some extra options or they can
provide the full list and not specify a bsp.
Which ever way we go the rtems-ld and rtems-tld should be the similar.
