[PATCH] score: Fix initially locked prio inherit sema
    Sebastian Huber
    Tue Aug 19 15:45:14 UTC 2014
 cpukit/score/src/coremutex.c     | 15 +++++++++++----
 testsuites/sptests/sp51/init.c   | 35 +++++++++++++++++++++++++++++++++++
 testsuites/sptests/sp51/sp51.doc |  3 +++
 3 files changed, 49 insertions(+), 4 deletions(-)
diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
index e13c7aa..949aa70 100644
--- a/cpukit/score/src/coremutex.c
+++ b/cpukit/score/src/coremutex.c
@@ -39,10 +39,14 @@ CORE_mutex_Status _CORE_mutex_Initialize(
   the_mutex->Attributes    = *the_mutex_attributes;
   if ( initially_locked ) {
+    bool is_priority_ceiling =
+      _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes );
     the_mutex->nest_count = 1;
     the_mutex->holder     = executing;
-    if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
-         _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
+    if (  is_priority_ceiling ||
+         _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ) {
       Priority_Control ceiling = the_mutex->Attributes.priority_ceiling;
@@ -52,7 +56,7 @@ CORE_mutex_Status _CORE_mutex_Initialize(
       _Thread_Disable_dispatch();
-      if ( executing->current_priority < ceiling ) {
+      if ( is_priority_ceiling && executing->current_priority < ceiling ) {
         _Thread_Enable_dispatch();
         return CORE_MUTEX_STATUS_CEILING_VIOLATED;
@@ -65,7 +69,10 @@ CORE_mutex_Status _CORE_mutex_Initialize(
       executing->resource_count++;
-      _Thread_Change_priority( executing, ceiling, false );
+      if ( is_priority_ceiling ) {
+        _Thread_Change_priority( executing, ceiling, false );
   } else {
diff --git a/testsuites/sptests/sp51/init.c b/testsuites/sptests/sp51/init.c
index 98d362f..8d36a30 100644
--- a/testsuites/sptests/sp51/init.c
+++ b/testsuites/sptests/sp51/init.c
@@ -18,6 +18,39 @@ const char rtems_test_name[] = "SP 51";
 /* forward declarations to avoid warnings */
 rtems_task Init(rtems_task_argument argument);
+static void test_create_initially_locked_prio_inherit_sema(void)
+  rtems_status_code   sc;
+  rtems_id            id;
+  rtems_task_priority prio_a;
+  rtems_task_priority prio_b;
+  sc = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio_a);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  rtems_test_assert(prio_a != 0);
+  sc = rtems_semaphore_create(
+    rtems_build_name( 'S', 'E', 'M', 'A' ),
+    0,
+    RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+    0,
+    &id
+  sc = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio_b);
+  rtems_test_assert(prio_a == prio_b);
+  sc = rtems_semaphore_release(id);
+  sc = rtems_semaphore_delete(id);
 rtems_task Init(
@@ -57,6 +90,8 @@ rtems_task Init(
   fatal_directive_status(
     sc, RTEMS_NOT_OWNER_OF_RESOURCE, "rtems_semaphore_release" );
+  test_create_initially_locked_prio_inherit_sema();
   TEST_END();
   rtems_test_exit( 0 );
diff --git a/testsuites/sptests/sp51/sp51.doc b/testsuites/sptests/sp51/sp51.doc
index a1003db..fac5534 100644
--- a/testsuites/sptests/sp51/sp51.doc
+++ b/testsuites/sptests/sp51/sp51.doc
@@ -23,3 +23,6 @@ concepts:
 + Ensure the when the binary semaphore lock fails to acquire the mutex,
   it is an error to release it since the lock failed.
++ Verify that creation of an initially locked priority inheritance mutex does
+  not change the priority of the executing thread.
1.8.4.5
