[PATCH] score: Fix initially locked prio inherit sema
Tue Aug 19 16:18:54 UTC 2014
Apply this.
On 8/19/2014 10:49 AM, Gedare Bloom wrote:
> Looks good.
> On Tue, Aug 19, 2014 at 11:45 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>>  cpukit/score/src/coremutex.c     | 15 +++++++++++----
>>  testsuites/sptests/sp51/init.c   | 35 +++++++++++++++++++++++++++++++++++
>>  testsuites/sptests/sp51/sp51.doc |  3 +++
>>  3 files changed, 49 insertions(+), 4 deletions(-)
>> diff --git a/cpukit/score/src/coremutex.c b/cpukit/score/src/coremutex.c
>> index e13c7aa..949aa70 100644
>> --- a/cpukit/score/src/coremutex.c
>> +++ b/cpukit/score/src/coremutex.c
>> @@ -39,10 +39,14 @@ CORE_mutex_Status _CORE_mutex_Initialize(
>>    the_mutex->Attributes    = *the_mutex_attributes;
>>    if ( initially_locked ) {
>> +    bool is_priority_ceiling =
>> +      _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes );
>>      the_mutex->nest_count = 1;
>>      the_mutex->holder     = executing;
>> -    if ( _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ||
>> -         _CORE_mutex_Is_priority_ceiling( &the_mutex->Attributes ) ) {
>> +    if (  is_priority_ceiling ||
>> +         _CORE_mutex_Is_inherit_priority( &the_mutex->Attributes ) ) {
>>        Priority_Control ceiling = the_mutex->Attributes.priority_ceiling;
>> @@ -52,7 +56,7 @@ CORE_mutex_Status _CORE_mutex_Initialize(
>>        _Thread_Disable_dispatch();
>> -      if ( executing->current_priority < ceiling ) {
>> +      if ( is_priority_ceiling && executing->current_priority < ceiling ) {
>>          _Thread_Enable_dispatch();
>>          return CORE_MUTEX_STATUS_CEILING_VIOLATED;
>> @@ -65,7 +69,10 @@ CORE_mutex_Status _CORE_mutex_Initialize(
>>        executing->resource_count++;
>> -      _Thread_Change_priority( executing, ceiling, false );
>> +      if ( is_priority_ceiling ) {
>> +        _Thread_Change_priority( executing, ceiling, false );
>>    } else {
>> diff --git a/testsuites/sptests/sp51/init.c b/testsuites/sptests/sp51/init.c
>> index 98d362f..8d36a30 100644
>> --- a/testsuites/sptests/sp51/init.c
>> +++ b/testsuites/sptests/sp51/init.c
>> @@ -18,6 +18,39 @@ const char rtems_test_name[] = "SP 51";
>>  /* forward declarations to avoid warnings */
>>  rtems_task Init(rtems_task_argument argument);
>> +static void test_create_initially_locked_prio_inherit_sema(void)
>> +  rtems_status_code   sc;
>> +  rtems_id            id;
>> +  rtems_task_priority prio_a;
>> +  rtems_task_priority prio_b;
>> +  sc = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio_a);
>> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
>> +  rtems_test_assert(prio_a != 0);
>> +  sc = rtems_semaphore_create(
>> +    rtems_build_name( 'S', 'E', 'M', 'A' ),
>> +    0,
>> +    RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
>> +    0,
>> +    &id
>> +  sc = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio_b);
>> +  rtems_test_assert(prio_a == prio_b);
>> +  sc = rtems_semaphore_release(id);
>> +  sc = rtems_semaphore_delete(id);
>>  rtems_task Init(
>> @@ -57,6 +90,8 @@ rtems_task Init(
>>    fatal_directive_status(
>>      sc, RTEMS_NOT_OWNER_OF_RESOURCE, "rtems_semaphore_release" );
>> +  test_create_initially_locked_prio_inherit_sema();
>>    TEST_END();
>>    rtems_test_exit( 0 );
>> diff --git a/testsuites/sptests/sp51/sp51.doc b/testsuites/sptests/sp51/sp51.doc
>> index a1003db..fac5534 100644
>> --- a/testsuites/sptests/sp51/sp51.doc
>> +++ b/testsuites/sptests/sp51/sp51.doc
>> @@ -23,3 +23,6 @@ concepts:
>>  + Ensure the when the binary semaphore lock fails to acquire the mutex,
>>    it is an error to release it since the lock failed.
>> ++ Verify that creation of an initially locked priority inheritance mutex does
>> +  not change the priority of the executing thread.
>> 1.8.4.5
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
