[Bug 2180] New: _TOD_Get_with_nanoseconds() is broken on SMP
Daniel Cederman
cederman at gaisler.com
Wed Aug 20 13:12:35 UTC 2014
Hi,
We are currently experiencing this bug reported by Sebastian Huber and I
could not find any discussion on it on the list. I'm guessing that the
simple solution of moving the call to Clock_driver_support_at_tick() to
the critical section of _TOD_Tickle_ticks() is not an acceptable
solution, given that it would be a call from score to the BSP?
Best regards,
Daniel C
On 2014-06-05 15:29, bugzilla-daemon at rtems.org wrote:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=2180
> Bug #: 2180
> Summary: _TOD_Get_with_nanoseconds() is broken on SMP
> Classification: Unclassified
> Product: RTEMS
> Version: 4.11
> Platform: All
> OS/Version: RTEMS
> Status: NEW
> Severity: normal
> Priority: P3
> Component: cpukit
> AssignedTo: joel.sherrill at oarcorp.com
> ReportedBy: sebastian.huber at embedded-brains.de
> We have
> Timestamp_Control *_TOD_Get_with_nanoseconds(
> Timestamp_Control *snapshot,
> const Timestamp_Control *clock
> TOD_Control *tod = &_TOD;
> ISR_lock_Context lock_context;
> Timestamp_Control offset;
> Timestamp_Control now;
> uint32_t nanoseconds;
> _TOD_Acquire( tod, &lock_context );
> nanoseconds = ( *tod->nanoseconds_since_last_tick )();
> now = *clock;
> _TOD_Release( tod, &lock_context );
> _Timestamp_Set( &offset, 0, nanoseconds );
> _Timestamp_Add_to( &now, &offset );
> *snapshot = now;
> return snapshot;
> and
> void _TOD_Tickle_ticks( void )
> Timestamp_Control tick;
> uint32_t nanoseconds_per_tick;
> nanoseconds_per_tick = rtems_configuration_get_nanoseconds_per_tick();
> /* Convert the tick quantum to a timestamp */
> _Timestamp_Set( &tick, 0, nanoseconds_per_tick );
> /* Update the counter of ticks since boot */
> _Watchdog_Ticks_since_boot += 1;
> /* Update the uptime */
> _Timestamp_Add_to( &tod->uptime, &tick );
> /* Update the current TOD */
> _Timestamp_Add_to( &tod->now, &tick );
> _TOD.seconds_trigger += nanoseconds_per_tick;
> if ( _TOD.seconds_trigger >= 1000000000UL ) {
> _TOD.seconds_trigger -= 1000000000UL;
> _Watchdog_Tickle_seconds();
> and (standard Clock driver)
> #if defined(BSP_FEATURE_IRQ_EXTENSION) || \
> (CPU_SIMPLE_VECTORED_INTERRUPTS != TRUE)
> void Clock_isr(void *arg)
> #else
> rtems_isr Clock_isr(rtems_vector_number vector);
> #endif
> * Accurate count of ISRs
> Clock_driver_ticks += 1;
> #if CLOCK_DRIVER_USE_FAST_IDLE
> do {
> rtems_clock_tick();
> } while (
> _Thread_Heir == _Thread_Executing
> && _Thread_Executing->Start.entry_point
> == rtems_configuration_get_idle_task()
> Clock_driver_support_at_tick();
> return;
> #else
> * Do the hardware specific per-tick action.
> * The counter/timer may or may not be set to automatically reload.
> #if CLOCK_DRIVER_ISRS_PER_TICK
> * The driver is multiple ISRs per clock tick.
> if ( !Clock_driver_isrs ) {
> rtems_clock_tick();
> Clock_driver_isrs = CLOCK_DRIVER_ISRS_PER_TICK;
> Clock_driver_isrs--;
> #else
> * The driver is one ISR per clock tick.
> rtems_clock_tick();
> #endif
> #endif
> Suppose we are between Clock_driver_support_at_tick() and _TOD_Tickle_ticks().
> Now call _TOD_Get_with_nanoseconds() on another processor. With most
> nanoseconds extensions we observe now a serviced hardware clock interrupt and
> the old _TOD.uptime value.
