[Bug 2180] New: _TOD_Get_with_nanoseconds() is broken on SMP
Wed Aug 20 13:59:12 UTC 2014
On 20/08/14 15:53, Joel Sherrill wrote:
> On 8/20/2014 8:12 AM, Daniel Cederman wrote:
>> >Hi,
>> >We are currently experiencing this bug reported by Sebastian Huber and I
>> >could not find any discussion on it on the list. I'm guessing that the
>> >simple solution of moving the call to Clock_driver_support_at_tick() to
>> >the critical section of _TOD_Tickle_ticks() is not an acceptable
>> >solution, given that it would be a call from score to the BSP?
> I don't have a problem with it. Some documentation may need to be updated to
> reflect the environment in which the bsp hook is called but I think it
> is pretty
> obvious it is called when an accurate timestamp is wanted.
Its not that easy.  This Clock_driver_support_at_tick() is part of
clockdrv_shell.h.  What we need is a proper clock driver API.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
