[GSoC2014] arinc653 on rtems (using pok) patches
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Wed Aug 20 14:10:39 UTC 2014
I already fixed that in my current version of virtualpok, but Janek's
patches were created against his version from April.
He already has the new version.
I maintain an own linkcmds in virtualpok, as I added a 0x1000 offset to
the start of the binary. It confused me to see some strange code in GDB
when the actual issue was a NULL pointer.
However, this offset led to other issues with debugging pok+rtems, so I
am thinking of dropping this again. Meaning, using pc386/startup/linkcmds.
Cheers,
Philipp
On 08/20/2014 04:01 PM, Gedare Bloom wrote:
>>>> * Is the linkcmds change required for running pok-rtems?
>>> For me, it was required. The old linkcmd script was causing undefined
>>> TLS errors while building RTEMS.
>> Please report this. This sounds like an independent issue which needs to
>> be run down.
> I believe this is a known issue. I think Sebastian fixed the in-tree
> BSPs, but out-of-tree BSPs also need to add sections for TLS. This
> would need to be added to the virtualpok BSP, which is currently
> embargoed from entering RTEMS due to needing a binary blob for
> libpok.a.
> -Gedare
> devel mailing list
> devel at rtems.org
