[PATCH] (2 commits squashed into one) Beagle BSP for review
Wed Aug 20 14:20:22 UTC 2014
Ben, As far as getting this merged, all of my comments can be done as
a follow-on commit. -Gedare
On Thu, Jul 24, 2014 at 4:28 PM, Ben Gras <beng at shrike-systems.com> wrote:
> Thanks for the fast & detailed review. Let me get back to it/you.
> In the meantime, any other feedback? From anyone I mean.
> On Thu, Jul 24, 2014 at 4:45 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Ben,
>> Great work. I have a few comments. I skipped the i2c.h and i2c.c
>> files. Most of my comments are about style and a few requests to
>> refactor some of the larger files. The refactoring can be added to
>> your TODO if you like. Please fix the style issues if it is not a
>> burden.
>> +++ b/c/src/lib/libbsp/arm/beagle/README
>> +$ ../claas-rtems/configure --target=arm-rtems4.11
>> --enable-rtemsbsp="beaglebonewhite beagleboardxm"
>> Replace claas-rtems with rtems. If RSB support is available, make a
>> note about it.
>> +++ b/c/src/lib/libbsp/arm/beagle/TODO
>> open:
>> + . how to handle the interrupt?
>> What does this mean?
>> +++ b/c/src/lib/libbsp/arm/beagle/clock.c
>> Why is the entire file ifdef'd on ARM_MULTILIB_ARCH_V4?
>> It might be sensible to put the struct definitions in a .h file if
>> these omap registers might be re-usable.
>> +static struct omap_timer_registers regs_v2 = {
>> This might be better to put behind an #if IS_AM335X since it is not
>> used otherwise?
>> Avoid more than one blank line in a row.
>> +static int done = 0;
>> It would be nice if you got rid of this, but otherwise give it a more
>> useful name like "mmio_init_done"
>> +static void beagle_clock_handler_install(rtems_interrupt_handler isr)
>> +  if (sc != RTEMS_SUCCESSFUL) {
>> +    rtems_fatal_error_occurred(0xdeadbeef);
>> I think there is some capabilities in ARM for bsp fatal error codes
>> now. They should be preferred to be used to help debug these fatal
>> conditions.
>> +static inline uint32_t beagle_clock_nanoseconds_since_last_tick(void)
>> +  return (read_frc() - (uint64_t) last_tick_nanoseconds) * 1000000000
>> / FRCLOCK_HZ;
>> This line is > 80 characters, please break it or shrink it.
>> +++ b/c/src/lib/libbsp/arm/beagle/console/console-config.c
>> +#define CONSOLE_UART_LSR (*(volatile unsigned int
>> *)(BSP_CONSOLE_UART_BASE+0x14))
>> Line > 80 characters, even with the spacing modified.
>> +static void beagle_console_init(void)
>> +    while ((CONSOLE_SYSS & 1) == 0)
>> Is this a fatal loop or is it waiting for hardware to clear something?
>> +    if ((CONSOLE_LSR & (CONSOLE_LSR_THRE | CONSOLE_LSR_TEMT)) ==
>> CONSOLE_LSR_THRE) {
>> Again > 80 characters. Is the test logically equivalent to: if (
>> (CONSOLE_LSR & CONSOLE_LSR_THRE) == CONSOLE_LSR_THRE)
>> +    while ((CONSOLE_LSR & CONSOLE_LSR_TEMT) == 0)
>> Is this a fatal loop or is it waiting for hardware?
>> +++ b/c/src/lib/libbsp/arm/beagle/include/bsp.h
>> This bsp.h is really long. Probably it should be refactored into other
>> headers, including non-public ones.
>> +static inline void dsb(void)
>> +        asm volatile("dsb" : : : "memory");
>> Fix the indentation.
>> +static inline void flush_data_cache(void)
>> Perhaps this should be using _CPU_cache_flush_entire_data()? Perhaps
>> there is a difference in that the cache manager code flushes and
>> "cleans" the cache...
>> Excess newlines. Done a few places in this file.
>> The comments following the defines for various AM33X_INT_ values go
>> off the end of the 80 column character width. Same for some other
>> comments following defines for OMAP3_TIMER, AM33X_DMTIMER1, and
>> AM335X_TIMER_. And further below for the CM_ WKUP and CM_PER_TIMER7
>> defines, and CLKSEL_TIMER1MS_CLK_SEL_SEL5.
>> +#define OMAP3_TCLR_AR       (1 << 1)  /* Autoreload or one-shot mode */
>> +#define OMAP3_TCLR_PRE      (1 << 5)  /* Prescaler on */
>> +#define OMAP3_TCLR_PTV      2
>> This PTV is odd compared to the other defines here. Is it 2 == (1<<1),
>> or is there a typo here?
>> Tabs are used in the OMAP3_CM_ defines, it should be space characters.
>> Also tabs are used in the read/write actlr, ttbcr, dacr, rrbr0
>> functions and the refresh_tlb function.
>> +/* i2c stuff */
>> +typedef struct {
>> +} beagle_i2c;
>> Shouldn't this go in beagle/include/i2c.h?
>> All of this mmu handling code should be refactored. Where possible, it
>> should use the existing code in arm-cp15.h
>> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> This header defines static, non-inline functions. This doesn't make sense.
>> +++ b/c/src/lib/libbsp/arm/beagle/irq.c
>> +static int irqs_enabled[BSP_INTERRUPT_VECTOR_MAX+1];
>> This is an array of 512 bytes. You could use a bit vector comprising 4
>> unsigned ints for the same purpose.
>> +volatile static int level = 0;
>> Unused variable?
>> +static uint32_t get_mir_reg(int vector, uint32_t *mask)
>> +  if(vector <   0) while(1) ;
>> Make this a fatal error?
>> +  if(vector <  32) return OMAP3_INTCPS_MIR0;
>> duplicate code.
>> +  while(1) ;
>> +rtems_status_code bsp_interrupt_facility_initialize(void)
>> +  mmio_write(omap_intr.base + OMAP3_INTCPS_SYSCONFIG,
>> OMAP3_SYSCONFIG_AUTOIDLE);
>> Line length > 80.
>> +++ b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
>> +//static uint32_t pagetable[ARM_SECTIONS] __attribute__((aligned
>> (1024*16)));
>> commented-out.. delete it?
>> +BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void)
>> __attribute__ ((weak));
>> More than 80 characters.
>> diff --git a/c/src/lib/libbsp/bfin/acinclude.m4
>> b/c/src/lib/libbsp/bfin/acinclude.m4
>> index ab6082e..828fd89 100644
>> --- a/c/src/lib/libbsp/bfin/acinclude.m4
>> +++ b/c/src/lib/libbsp/bfin/acinclude.m4
>> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
>> b/c/src/lib/libbsp/powerpc/acinclude.m4
>> index 6442399..e46fa2b 100644
>> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
>> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
>> Don't include these changes. Check your tool versions, and if the
>> correct version of tools does this, provide a separate patch for
>> generated files.
>> -Gedare
>> On Wed, Jul 23, 2014 at 9:00 PM, Ben Gras <beng at shrike-systems.com> wrote:
>> > All,
>> > Full details on how to reproduce all the work from source repositories
>> > to
>> > scripts & utilities to write a complete sd card booting RTEMS and test
>> > the
>> > whole thing:
>> > http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>> > I am submitting the attached patch for review for merging. If accepted
>> > for
>> > merging, please use the top two commits on
>> > https://github.com/bengras/rtems/tree/beaglebone-wip
>> > which have the same net effect but preserve Claas' work because of the
>> > earlier commit. The squashed version attached is for more convenient
>> > review.
>> > I was ironing out more wrinkles but given recent interest it seems
>> > smarter
>> > to merge sooner and keep polishing from mainline. Nevertheless I have
>> > put a
>> > lot of work into getting it into good shape already.
>> > I have rebased everything on the very latest master and verified
>> > That building all the tools and utilities from scratch work, using the
>> > RTEMS
>> > Source Builder repository (Ubuntu + FreeBSD).
>> > That building the beaglebone and bbxm BSPs and linking them with all the
>> > testsuite programs works (Ubuntu + FreeBSD).
>> > That the beaglexm-emulating linaro qemu executes all of those tests
>> > properly, invoked using a single command line with the scripts in the
>> > RTEMS
>> > tools repository, even though not all pass currently (Ubuntu + FreeBSD).
>> > That loading & running over JTAG works, both interactively with gdb and
>> > in a
>> > batch using gdb and the test runner.
>> > That running RTEMS executables using u-boot on the beaglebones from sd
>> > card
>> > work; both with and without MMU enabled at RTEMS start time.
>> > That Claas' earlier commit builds.
>> > Thanks so far to Chris and Brandon for help, support, instructions and
>> > advice in various forms :)
>> > Test results on qemu:
>> > Passed:   497 Failed:     3 Timeouts:   1 Invalid:    0
>> > The test results on bbxm over jtag (older):
>> > Passed:   475 Failed:     7 Timeouts:  10 Invalid:    0
>> > I want to iron out more wrinkles and build support (ethernet) but giving
>> > the
>> > bsp more exposure and having it in mainline so i don't have to keep
>> > rebasing
>> > & testing would be nice at this point.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
