feedback on Re: [PATCH v3] BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
Wed Aug 20 18:17:47 UTC 2014
Hi
Initial quick feedback.  I build normally with --enable-rtems-debug
and the tms570ls3137_hdk variant failed to build with this
failure:
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H   -I../../..
-I../../../../cpukit/../../../tms570ls3137_hdk/lib/include  -DASM
-march=armv7-r -mthumb -mbig-endian -O2 -ggdb3 -DNDEBUG -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -march=armv7-r -mthumb -mbig-endian -O2 -ggdb3 -DNDEBUG
-Wall -Wmissing-prototypes -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs -MT
libscorecpu_a-arm-context-volatile-clobber.o -MD -MP -MF
.deps/libscorecpu_a-arm-context-volatile-clobber.Tpo -c -o
libscorecpu_a-arm-context-volatile-clobber.o `test -f
'arm-context-volatile-clobber.S' || echo
'../../../../../../../../rtems/c/src/../../cpukit/score/cpu/arm/'`arm-context-volatile-clobber.S
mv -f .deps/libscorecpu_a-arm-context-volatile-clobber.Tpo
.deps/libscorecpu_a-arm-context-volatile-clobber.Po
In file included from
../../../../cpukit/../../../tms570ls3137_hdk/lib/include/rtems/score/percpu.h:25:0,
                 from
../../../../cpukit/../../../tms570ls3137_hdk/lib/include/rtems/system.h:23,
                 from
../../../../../../../../rtems/c/src/../../cpukit/score/cpu/arm/cpu.c:29:
../../../../cpukit/../../../tms570ls3137_hdk/lib/include/rtems/score/isrlock.h:
In function '_ISR_lock_ISR_disable_and_acquire':
../../../../cpukit/../../../tms570ls3137_hdk/lib/include/rtems/score/assert.h:38:46:
error: '__ASSERT_FUNC' undeclared (first use in this function)
           __assert_func( __FILE__, __LINE__, __ASSERT_FUNC, #_e ) )
Since there was some work to add a new ARM variant, I am suspicious that
a .h file is missing when this is compiled for Rx ARM variants.
I didn't build other variants and am trying again with debug disabled.
More to follow.
--joel
On 8/20/2014 12:30 PM, Joel Sherrill wrote:
> I replied to a private message without everyone on it.
> Premysl. Can you submit the final patch so I am sure I am
> merging the right thing?
> Thanks.
> --joel
> On 8/20/2014 12:28 PM, Gedare Bloom wrote:
>> All,
>> Pavel has indicated no warnings and no serious problems flagged by
>> check_submission.
>> I'm OK with this patch, Joel commit if you also approve.
>> -Gedare
>> On Wed, Aug 20, 2014 at 11:47 AM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> On August 20, 2014 10:39:06 AM CDT, Gedare Bloom <gedare at rtems.org> wrote:
>>>> Premysl,
>>>> It looks good. I just have two requests for you to do:
>>>> 1) Post the warnings you get when you compile.
>>> Fixing them without papering over them is preferred but we can help if you get stumped.
>>>> 2) Run the script
>>>> http://git.rtems.org/rtems-testing/tree/merge-helpers/check_submission
>>> >from within libbsp/arm/tms570 and post the results.
>>> Some of these may be false positives or hints for a human decision. Ask if in doubt.
>>>> Thanks,
>>>> Gedare
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
