We should release 4.11
Wed Aug 20 18:39:25 UTC 2014
On 8/20/2014 1:34 PM, Gedare Bloom wrote:
> On Tue, Aug 19, 2014 at 5:34 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 20/08/2014 2:38 am, Gedare Bloom wrote:
>>> Anything holding it up at the moment?
>> It would be good to get a formal tool set definition into rtems-tools.git.
> I think this can be dealt with post-release. There may be some time
> gap between the release date and when the stable tools are available,
> but this is probably unavoidable.
>> I am currently testing a change to newlib 19-Aug-2014 which removes an old
>> patch we had.
It also points out a hack in rtems_bsdnet_internal.h where we defined
struct sigaltstack ourselves (years ago) instead of doing the right thing
and adding it to signal.h. Now it is in signal.h and you can't compile
TCP/IP with the new toolset without deleting it.
I suppose I could define an autoconf test for this. But we already have
a lot of have cpuset.h conditionals which should be removed now that
we are over that bump.
diff --git a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
b/cpukit/libnetw
index 05e54b2..812f040 100644
--- a/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
+++ b/cpukit/libnetworking/rtems/rtems_bsdnet_internal.h
@@ -83,11 +83,6 @@ typedef      quad_t *        qaddr_t;
 typedef void __sighandler_t(int);
 typedef        __sighandler_t  *sig_t; /* type of pointer to a signal
function
 #define NSIG    32
-struct sigaltstack {
-       char    *ss_sp;                 /* signal stack base */
-       int     ss_size;                /* signal stack length */
-       int     ss_flags;               /* SS_DISABLE and/or SS_ONSTACK */
>> Chris
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
