[PATCH] Add new (first) OpenRISC BSP called or1ksim.
Hesham Moustafa heshamelmatary at gmail.com
Wed Aug 20 20:06:10 UTC 2014
Hi,
On Wed, Aug 20, 2014 at 9:54 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> Thanks.
> I just pushed this.  I did not compile it. Make sure it builds all tests
What about the nop instruction? Should I add a conditional macros in
the init.c file, or create a new macro to mirror l.nop to nop for or1k
targets?
> for
> you just like it did before.
Thanks for pushing the code.
> How is the test pass/fail rate?
How can I get this? Is there a script for running all tests or
something similar?
> Did you get ticker running?
Ticker is running but there are still two issues. The first is with
the very long delay of context switches. The second is about the
printf and the possibility of broken context switch (which I debug
currently). To get around the printf problem, I was adding an entry in
buffer_test_io.h for or1k target to force tests to use printk. Gedare
suggested not to push such a solution.
> On 8/20/2014 12:23 PM, Hesham ALMatary wrote:
>> This BSP is intended to run on or1ksim (the main OpenRISC emulator).
>> Fixed version according to Joel comments from the mailing list.
>>  c/src/aclocal/rtems-cpu-subdirs.m4                 |   1 +
>>  c/src/lib/libbsp/or1k/Makefile.am                  |  10 +
>>  c/src/lib/libbsp/or1k/acinclude.m4                 |  10 +
>>  c/src/lib/libbsp/or1k/configure.ac                 |  19 ++
>>  c/src/lib/libbsp/or1k/or1ksim/Makefile.am          | 109 ++++++++
>>  c/src/lib/libbsp/or1k/or1ksim/README               |  17 ++
>>  c/src/lib/libbsp/or1k/or1ksim/bsp_specs            |  12 +
>>  c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c     | 104 +++++++
>>  c/src/lib/libbsp/or1k/or1ksim/configure.ac         |  30 ++
>>  .../libbsp/or1k/or1ksim/console/console-config.c   |  58 ++++
>>  c/src/lib/libbsp/or1k/or1ksim/console/uart.c       | 144 ++++++++++
>>  c/src/lib/libbsp/or1k/or1ksim/include/bsp.h        |  47 ++++
>>  c/src/lib/libbsp/or1k/or1ksim/include/irq.h        |  45 +++
>>  c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h    | 118 ++++++++
>>  c/src/lib/libbsp/or1k/or1ksim/include/uart.h       |  42 +++
>>  c/src/lib/libbsp/or1k/or1ksim/irq/irq.c            |  42 +++
>>  .../or1k/or1ksim/make/custom/or1k_or1ksim.cfg      |   7 +
>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am        | 115 ++++++++
>>  c/src/lib/libbsp/or1k/or1ksim/start/start.S        | 182 ++++++++++++
>>  c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds     |  41 +++
>>  c/src/lib/libbsp/or1k/or1ksim/timer/timer.c        |  64 +++++
>>  c/src/lib/libbsp/or1k/preinstall.am                |   7 +
>>  .../libbsp/or1k/shared/include/linker-symbols.h    |  79 ++++++
>>  c/src/lib/libbsp/or1k/shared/startup/linkcmds.base | 310 +++++++++++++++++++++
>>  24 files changed, 1613 insertions(+)
>>  create mode 100644 c/src/lib/libbsp/or1k/Makefile.am
>>  create mode 100644 c/src/lib/libbsp/or1k/acinclude.m4
>>  create mode 100644 c/src/lib/libbsp/or1k/configure.ac
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/README
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/bsp_specs
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/configure.ac
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/console/console-config.c
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/bsp.h
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/irq.h
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/uart.h
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/irq/irq.c
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/start/start.S
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds
>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
>>  create mode 100644 c/src/lib/libbsp/or1k/preinstall.am
>>  create mode 100644 c/src/lib/libbsp/or1k/shared/include/linker-symbols.h
>>  create mode 100644 c/src/lib/libbsp/or1k/shared/startup/linkcmds.base
>> diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4 b/c/src/aclocal/rtems-cpu-subdirs.m4
>> index c5a4a19..9593d34 100644
>> --- a/c/src/aclocal/rtems-cpu-subdirs.m4
>> +++ b/c/src/aclocal/rtems-cpu-subdirs.m4
>> @@ -23,6 +23,7 @@ _RTEMS_CPU_SUBDIR([mips],[$1]);;
>>  _RTEMS_CPU_SUBDIR([moxie],[$1]);;
>>  _RTEMS_CPU_SUBDIR([nios2],[$1]);;
>>  _RTEMS_CPU_SUBDIR([no_cpu],[$1]);;
>> +_RTEMS_CPU_SUBDIR([or1k],[$1]);;
>>  _RTEMS_CPU_SUBDIR([powerpc],[$1]);;
>>  _RTEMS_CPU_SUBDIR([sh],[$1]);;
>>  _RTEMS_CPU_SUBDIR([sparc],[$1]);;
>> diff --git a/c/src/lib/libbsp/or1k/Makefile.am b/c/src/lib/libbsp/or1k/Makefile.am
>> new file mode 100644
>> index 0000000..0ce20e6
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/Makefile.am
>> @@ -0,0 +1,10 @@
>> +ACLOCAL_AMFLAGS = -I ../../../aclocal
>> +## Descend into the @RTEMS_BSP_FAMILY@ directory
>> +## Currently, the shared directory is not explicitly
>> +## added but it is present in the source tree.
>> +SUBDIRS = @RTEMS_BSP_FAMILY@
>> +include $(srcdir)/preinstall.am
>> +include $(top_srcdir)/../../../automake/subdirs.am
>> +include $(top_srcdir)/../../../automake/local.am
>> diff --git a/c/src/lib/libbsp/or1k/acinclude.m4 b/c/src/lib/libbsp/or1k/acinclude.m4
>> index 0000000..c593670
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/acinclude.m4
>> @@ -0,0 +1,10 @@
>> +# RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY)
>> +AC_DEFUN([RTEMS_CHECK_BSPDIR],
>> +  case "$1" in
>> +  or1ksim )
>> +    AC_CONFIG_SUBDIRS([or1ksim]);;
>> +    AC_MSG_ERROR([Invalid BSP]);;
>> +  esac
>> diff --git a/c/src/lib/libbsp/or1k/configure.ac b/c/src/lib/libbsp/or1k/configure.ac
>> index 0000000..96bba16
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/configure.ac
>> @@ -0,0 +1,19 @@
>> +# Process this file with autoconf to produce a configure script.
>> +AC_PREREQ([2.69])
>> +AC_INIT([rtems-c-src-lib-libbsp-or1k],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
>> +AC_CONFIG_SRCDIR([or1ksim])
>> +RTEMS_TOP(../../../../..)
>> +RTEMS_CANONICAL_TARGET_CPU
>> +AM_INIT_AUTOMAKE([no-define foreign 1.12.2])
>> +AM_MAINTAINER_MODE
>> +RTEMS_ENV_RTEMSBSP
>> +RTEMS_PROJECT_ROOT
>> +RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY])
>> +# Explicitly list all Makefiles here
>> +AC_CONFIG_FILES([Makefile])
>> +AC_OUTPUT
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>> index 0000000..d5eb10c
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>> @@ -0,0 +1,109 @@
>> +# @file
>> +# @brief Makefile of LibBSP for the or1ksim BSP.
>> +ACLOCAL_AMFLAGS = -I ../../../../aclocal
>> +include $(top_srcdir)/../../../../automake/compile.am
>> +include_bspdir = $(includedir)/bsp
>> +#include_libcpudir = $(includedir)/libcpu
>> +dist_project_lib_DATA = bsp_specs
>> +#                  Header                                                     #
>> +include_bsp_HEADERS =
>> +include_HEADERS = include/bsp.h
>> +nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>> +include_bsp_HEADERS += ../shared/include/linker-symbols.h
>> +include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
>> +include_bsp_HEADERS += ../../shared/include/utility.h
>> +include_bsp_HEADERS += ../../shared/include/irq-generic.h
>> +include_bsp_HEADERS += ../../shared/include/irq-info.h
>> +include_bsp_HEADERS += ../../shared/include/stackalloc.h
>> +include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>> +include_bsp_HEADERS += ../../shared/tod.h
>> +include_bsp_HEADERS += ../../shared/include/tm27.h
>> +include_bsp_HEADERS += include/irq.h
>> +include_bsp_HEADERS += include/uart.h
>> +include_bsp_HEADERS += include/or1ksim.h
>> +nodist_include_HEADERS = ../../shared/include/coverhd.h \
>> +  include/bspopts.h
>> +#                  Data                                                       #
>> +noinst_LIBRARIES = libbspstart.a
>> +libbspstart_a_SOURCES = start/start.S
>> +project_lib_DATA = start.$(OBJEXT)
>> +project_lib_DATA += startup/linkcmds
>> +project_lib_DATA += ../shared/startup/linkcmds.base
>> +#                  LibBSP                                                     #
>> +noinst_LIBRARIES += libbsp.a
>> +libbsp_a_SOURCES =
>> +libbsp_a_CPPFLAGS =
>> +libbsp_a_LIBADD =
>> +# Startup
>> +libbsp_a_SOURCES += ../../shared/bspstart.c
>> +libbsp_a_SOURCES += ../../shared/bspreset.c
>> +# Shared
>> +libbsp_a_SOURCES += ../../shared/bootcard.c
>> +libbsp_a_SOURCES += ../../shared/bspclean.c
>> +libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
>> +libbsp_a_SOURCES += ../../shared/bsplibc.c
>> +libbsp_a_SOURCES += ../../shared/bsppost.c
>> +libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
>> +libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>> +libbsp_a_SOURCES += ../../shared/cpucounterread.c
>> +libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
>> +libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>> +libbsp_a_SOURCES += ../../shared/sbrk.c
>> +libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>> +# Console
>> +libbsp_a_SOURCES += ../../shared/console.c
>> +libbsp_a_SOURCES += ../../shared/console_control.c
>> +libbsp_a_SOURCES += ../../shared/console_read.c
>> +libbsp_a_SOURCES += ../../shared/console_select.c
>> +libbsp_a_SOURCES += ../../shared/console_write.c
>> +libbsp_a_SOURCES += console/console-config.c
>> +libbsp_a_SOURCES += console/uart.c
>> +# Timer
>> +libbsp_a_SOURCES += timer/timer.c
>> +# clock
>> +libbsp_a_SOURCES += clock/clockdrv.c ../../../shared/clockdrv_shell.h
>> +# IRQ
>> +libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
>> +libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>> +libbsp_a_SOURCES += ../../shared/src/irq-info.c
>> +libbsp_a_SOURCES += irq/irq.c
>> +#                  Special Rules                                              #
>> +DISTCLEANFILES = include/bspopts.h
>> +include $(top_srcdir)/../../../../automake/local.am
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/README b/c/src/lib/libbsp/or1k/or1ksim/README
>> index 0000000..99d1edf
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/README
>> @@ -0,0 +1,17 @@
>> +This BSP should run only on or1ksim: the main simulator for or1k architecture.
>> +or1ksim should be used for testing purposes.
>> +svn co http://opencores.org/ocsvn/openrisc/openrisc/trunk/or1ksim
>> +cd or1ksim
>> +mkdir builddir_or1ksim
>> +cd builddir_or1ksim
>> +../configure --target=or32-elf --prefix=/opt/or1ksim
>> +make all
>> +make install
>> +export PATH=/opt/or1ksim/bin:$PATH
>> +Configuration file "sim.cfg" should be provided for complex board
>> +configurations at the current directory (which you run or1ksim from) or at
>> +~/.or1k/
>> +sim -f sim.cfg hello.exe
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/bsp_specs b/c/src/lib/libbsp/or1k/or1ksim/bsp_specs
>> index 0000000..446dafa
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/bsp_specs
>> @@ -0,0 +1,12 @@
>> +%rename endfile old_endfile
>> +%rename startfile old_startfile
>> +%rename link old_link
>> +*startfile:
>> +%{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems: \
>> +%{!qrtems_debug: start.o%s} \
>> +%{qrtems_debug: start_g.o%s}}}
>> +*link:
>> +%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N -e _start}
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>> index 0000000..926e2b0
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>> @@ -0,0 +1,104 @@
>> + * @file
>> + * @ingroup bsp_clock
>> + * @brief or1ksim clock support.
>> + * or1ksim Clock driver
>> + * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>> + * The license and distribution terms for this file may be
>> + * found in the file LICENSE in this distribution or at
>> + * http://www.rtems.org/license/LICENSE
>> +#include <rtems.h>
>> +#include <bsp.h>
>> +#include <bsp/irq.h>
>> +#include <bsp/or1ksim.h>
>> +#include <rtems/score/cpu.h>
>> +#include <rtems/score/or1k-utility.h>
>> +/* The number of clock cycles before generating a tick timer interrupt. */
>> +#define TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT     0xFFED9
>> +#define OR1KSIM_CLOCK_CYCLE_TIME_NANOSECONDS  10
>> +/* This prototype is added here to Avoid warnings */
>> +void Clock_isr(void *arg);
>> +static void or1ksim_clock_at_tick(void)
>> +  uint32_t TTMR;
>> + /* For TTMR register,
>> +  * The least significant 28 bits are the number of clock cycles
>> +  * before generating a tick timer interrupt. While the most
>> +  * significant 4 bits are used for mode configuration, tick timer
>> +  * interrupt enable and pending interrupts status.
>> +  TTMR = (CPU_OR1K_SPR_TTMR_MODE_RESTART | CPU_OR1K_SPR_TTMR_IE |
>> +           (TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT & CPU_OR1K_SPR_TTMR_TP_MASK)
>> +         ) & ~(CPU_OR1K_SPR_TTMR_IP);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_TTMR, TTMR);
>> +  _OR1K_mtspr(CPU_OR1K_SPR_TTCR, 0);
>> +static void or1ksim_clock_handler_install(proc_ptr new_isr, proc_ptr old_isr)
>> +  rtems_status_code sc = RTEMS_SUCCESSFUL;
>> +  old_isr = NULL;
>> +  _CPU_ISR_install_vector(OR1K_EXCEPTION_TICK_TIMER,
>> +                          new_isr,
>> +                          old_isr);
>> +  if (sc != RTEMS_SUCCESSFUL) {
>> +    rtems_fatal_error_occurred(0xdeadbeef);
>> +static void or1ksim_clock_initialize(void)
>> +  uint32_t sr;
>> +  or1ksim_clock_at_tick();
>> +   /* Enable tick timer */
>> +  sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
>> +  sr |= CPU_OR1K_SPR_SR_TEE;
>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr);
>> + static void or1ksim_clock_cleanup(void)
>> + *  Return the nanoseconds since last tick
>> +static uint32_t or1ksim_clock_nanoseconds_since_last_tick(void)
>> +  return
>> +  TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT * OR1KSIM_CLOCK_CYCLE_TIME_NANOSECONDS;
>> +#define Clock_driver_support_at_tick() or1ksim_clock_at_tick()
>> +#define Clock_driver_support_initialize_hardware() or1ksim_clock_initialize()
>> +#define Clock_driver_support_install_isr(isr, old_isr) \
>> +  do {                                                 \
>> +    or1ksim_clock_handler_install(isr, old_isr);               \
>> +    old_isr = NULL;                                    \
>> +  } while (0)
>> +#define Clock_driver_support_shutdown_hardware() or1ksim_clock_cleanup()
>> +#define Clock_driver_nanoseconds_since_last_tick \
>> +  or1ksim_clock_nanoseconds_since_last_tick
>> +#include "../../../shared/clockdrv_shell.h"
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/configure.ac b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
>> index 0000000..8aff7e3
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
>> @@ -0,0 +1,30 @@
>> +# @file
>> +# @brief Configure script of LibBSP for or1ksim BSP.
>> +AC_PREREQ(2.69)
>> +AC_INIT([rtems-c-src-lib-libbsp-or1k-or1ksim],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
>> +AC_CONFIG_SRCDIR([bsp_specs])
>> +RTEMS_TOP(../../../../../..)
>> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
>> +RTEMS_BSP_CONFIGURE
>> +RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
>> +RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
>> +RTEMS_BSPOPTS_SET([BSP_OR1K_OR1KSIM_PERIPHCLK],[*],[100000000U])
>> +RTEMS_BSPOPTS_HELP([BSP_OR1K_OR1KSIM_PERIPHCLK],[or1ksim PERIPHCLK clock frequency in Hz])
>> +RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm])
>> +RTEMS_CANONICALIZE_TOOLS
>> +RTEMS_PROG_CCAS
>> +RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
>> +RTEMS_BSP_LINKCMDS
>> +AC_OUTPUT
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/console-config.c b/c/src/lib/libbsp/or1k/or1ksim/console/console-config.c
>> index 0000000..9853f20
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/console-config.c
>> @@ -0,0 +1,58 @@
>> + * @file
>> + * @ingroup or1ksim_uart
>> + * @brief Console Configuration.
>> + * Copyright (c) 2014 Hesham ALMatary
>> +#include <rtems/bspIo.h>
>> +#include <libchip/serial.h>
>> +#include <bspopts.h>
>> +#include <bsp/uart.h>
>> +console_tbl Console_Configuration_Ports [] = {
>> +      .sDeviceName = "/dev/ttyS0",
>> +      .deviceType = SERIAL_CUSTOM,
>> +      .pDeviceFns = &or1ksim_uart_fns,
>> +      .deviceProbe = NULL,
>> +      .pDeviceFlow = NULL,
>> +      .ulCtrlPort1 = OR1KSIM_BSP_UART_BASE,
>> +      .ulCtrlPort2 = 0,
>> +      .ulClock = OR1KSIM_UART_DEFAULT_BAUD,
>> +      .ulIntVector = OR1KSIM_BSP_UART_IRQ
>> +#define PORT_COUNT \
>> +  (sizeof(Console_Configuration_Ports) \
>> +    / sizeof(Console_Configuration_Ports [0]))
>> +unsigned long Console_Configuration_Count = PORT_COUNT;
>> +static void output_char(char c)
>> +  const console_fns *con =
>> +    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>> +  if (c == '\n') {
>> +    con->deviceWritePolled((int) Console_Port_Minor, '\r');
>> +  con->deviceWritePolled((int) Console_Port_Minor, c);
>> +BSP_output_char_function_type BSP_output_char = output_char;
>> +BSP_polling_getchar_function_type BSP_poll_char = NULL;
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>> index 0000000..f1cfa09
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>> @@ -0,0 +1,144 @@
>> + * @file
>> + * @brief UART support.
>> +#include <libchip/sersupp.h>
>> +#include <bsp.h>
>> +#include <rtems/score/isr.h>
>> +static rtems_vector_number uart_get_irq_number(const console_tbl *ct)
>> +   return ct->ulIntVector;
>> +static uint32_t uart_get_baud(const console_tbl *ct)
>> +   return ct->ulClock;
>> +static void uart_set_baud(int baud)
>> +  int divisor = (OR1KSIM_BSP_CLOCK_FREQ) / (16 * baud);
>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) |=
>> +    OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB;
>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW) = divisor & 0xff;
>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH) =
>> +    (divisor >> 8) & 0xff;
>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) &=
>> +    ~(OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB);
>> +static void uart_initialize(int minor)
>> +  /* Disable all interrupts */
>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_INT_ENABLE) = 0x00;
>> +  /* Reset receiver and transmitter */
>> +   OR1KSIM_REG(OR1KSIM_BSP_UART_REG_FIFO_CTRL) =
>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO |
>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR  |
>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT  |
>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14;
>> +  /* Set data pattern configuration */
>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) =
>> +    OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8 &
>> +      (OR1KSIM_BSP_UART_REG_LINE_CTRL_STOP |
>> +       OR1KSIM_BSP_UART_REG_LINE_CTRL_PARITY);
>> +  /* Set baud rate */
>> +  uart_set_baud(OR1KSIM_UART_DEFAULT_BAUD);
>> +static int uart_first_open(int major, int minor, void *arg)
>> +  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *) arg;
>> +  struct rtems_termios_tty *tty = (struct rtems_termios_tty *) oc->iop->data1;
>> +  const console_tbl *ct = Console_Port_Tbl [minor];
>> +  console_data *cd = &Console_Port_Data [minor];
>> +  cd->termios_data = tty;
>> +  rtems_termios_set_initial_baud(tty, ct->ulClock);
>> +  return 0;
>> +static int uart_last_close(int major, int minor, void *arg)
>> +  return 0;
>> +static int uart_read_polled(int minor)
>> +   return -1;
>> +static void uart_write_polled(int minor, char c)
>> +  unsigned char lsr;
>> +  const uint32_t transmit_finished =
>> +    (OR1KSIM_BSP_UART_REG_LINE_STATUS_TEMT |
>> +     OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE);
>> +  /* Wait until there is no pending data in the transmitter FIFO (empty) */
>> +  do {
>> +      lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
>> +  } while (!(lsr & OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE));
>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_TX) = c;
>> +  /* Wait until trasmit data is finished */
>> +  do {
>> +  } while ( (lsr & transmit_finished) != transmit_finished );
>> +static ssize_t uart_write_support_polled(
>> +  int minor,
>> +  const char *s,
>> +  size_t n
>> +  ssize_t i = 0;
>> +  for (i = 0; i < n; ++i){
>> +    uart_write_polled(minor, s [i]);
>> +  return n;
>> +static int uart_set_attributes(int minor, const struct termios *term)
>> +  return -1;
>> +const console_fns or1ksim_uart_fns = {
>> +  .deviceProbe = libchip_serial_default_probe,
>> +  .deviceFirstOpen = uart_first_open,
>> +  .deviceLastClose = uart_last_close,
>> +  .deviceRead = uart_read_polled,
>> +  .deviceWrite = uart_write_support_polled,
>> +  .deviceInitialize = uart_initialize,
>> +  .deviceWritePolled = uart_write_polled,
>> +  .deviceSetAttributes = uart_set_attributes,
>> +  .deviceOutputUsesInterrupts = false
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/bsp.h b/c/src/lib/libbsp/or1k/or1ksim/include/bsp.h
>> index 0000000..502e4d9
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/bsp.h
>> @@ -0,0 +1,47 @@
>> + * @file
>> + * @ingroup or1k_or1ksim
>> + * @brief Global BSP definitions.
>> +#ifndef LIBBSP_OR1K_OR1KSIM_H
>> +#define LIBBSP_OR1K_OR1KSIM_H
>> +#include <rtems.h>
>> +#include <rtems/console.h>
>> +#include <rtems/clockdrv.h>
>> +#include <bsp/default-initial-extension.h>
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#endif /* __cplusplus */
>> +#define BSP_FEATURE_IRQ_EXTENSION
>> +#ifdef __cplusplus
>> +#endif /* LIBBSP_OR1K_OR1KSIM_H */
>> + * @defgroup or1k_or1ksim support
>> + * @ingroup bsp_or1k
>> + * @brief or1ksim support package
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/irq.h b/c/src/lib/libbsp/or1k/or1ksim/include/irq.h
>> index 0000000..be669d8
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/irq.h
>> @@ -0,0 +1,45 @@
>> + * @file
>> + * @ingroup or1ksim_interrupt
>> + * @brief Interrupt definitions.
>> +#ifndef LIBBSP_OR1K_OR1KSIM_IRQ_H
>> +#define LIBBSP_OR1K_OR1KSIM_IRQ_H
>> +#ifndef ASM
>> +#include <rtems.h>
>> +#include <rtems/irq.h>
>> +#include <rtems/irq-extension.h>
>> +#define BSP_INTERRUPT_VECTOR_MIN  0x100
>> +#define BSP_INTERRUPT_VECTOR_MAX  0x1F00
>> +/* Interrupt Identification Register */
>> +#define OR1KSIM_BSP_UART_REG_INT_ID_MSI    (0x00)
>> +#define OR1KSIM_BSP_UART_REG_INT_ID_NO_INT (0x01)
>> +#define OR1KSIM_BSP_UART_REG_INT_ID_THRI   (0x02)
>> +#define OR1KSIM_BSP_UART_REG_INT_ID_RDI    (0x04)
>> +#define OR1KSIM_BSP_UART_REG_INT_ID_ID     (0x06)
>> +#define OR1KSIM_BSP_UART_REG_INT_ID_RLSI   (0x06)
>> +#define OR1KSIM_BSP_UART_REG_INT_ID_TOI    (0x0c)
>> +/* Interrupt Enable Register */
>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_RDI  (0x01)
>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_THRI (0x02)
>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_RLSI (0x04)
>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_MSI  (0x08)
>> +#endif /* ASM */
>> +#endif /* LIBBSP_OR1K_OR1KSIM_IRQ_H */
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
>> index 0000000..8279566
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
>> @@ -0,0 +1,118 @@
>> + * @file
>> + * @ingroup or1ksim_reg
>> + * @brief Register definitions.
>> +#include <stdint.h>
>> + * @defgroup or1ksim_reg Register Definitions
>> + * @brief Register Definitions
>> + * @name Register Macros
>> + #define OR1KSIM_REG(x)           (*((volatile char *) (x)))
>> + #define OR1KSIM_BIT(n)           (1 << (n))
>> + * @name Internal OR1K UART Registers
>> +#define OR1KSIM_BSP_CLOCK_FREQ       100000000UL
>> +#define OR1KSIM_BSP_UART_BASE        0x90000000
>> +#define OR1KSIM_BSP_UART_REG_TX              (OR1KSIM_BSP_UART_BASE+0)
>> +#define OR1KSIM_BSP_UART_REG_RX              (OR1KSIM_BSP_UART_BASE+0)
>> +#define OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW   (OR1KSIM_BSP_UART_BASE+1)
>> +#define OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH  (OR1KSIM_BSP_UART_BASE+1)
>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE      (OR1KSIM_BSP_UART_BASE+2)
>> +#define OR1KSIM_BSP_UART_REG_INT_ID          (OR1KSIM_BSP_UART_BASE+2)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL       (OR1KSIM_BSP_UART_BASE+2)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL       (OR1KSIM_BSP_UART_BASE+3)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL      (OR1KSIM_BSP_UART_BASE+4)
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS     (OR1KSIM_BSP_UART_BASE+5)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS    (OR1KSIM_BSP_UART_BASE+6)
>> +#define OR1KSIM_BSP_UART_REG_SCRATCH         (OR1KSIM_BSP_UART_BASE+7)
>> +/* FIFO Control Register */
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_1    (0x00)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO  (0x01)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR   (0x02)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT   (0x03)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_DMA_SELECT   (0x08)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_4    (0x40)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_8    (0x80)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14   (0xC0)
>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_MASK (0xC0)
>> +/* Line Control Register */
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN5  (0x00)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN6  (0x01)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN7  (0x02)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8  (0x03)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_STOP   (0x04)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_PARITY (0x08)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_EPAR   (0x10)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_SPAR   (0x20)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_SBC    (0x40)
>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB   (0x80)
>> +/* Line Status Register */
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_DR   (0x01)
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_OE   (0x02)
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_PE   (0x04)
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_FE   (0x08)
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_BI   (0x10)
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE (0x20)
>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_TEMT (0x40)
>> +/* Modem Control Register */
>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_DTR  (0x01)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_RTS  (0x02)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_OUT1 (0x04)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_OUT2 (0x08)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_LOOP (0x10)
>> +/* Modem Status Register */
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DCTS (0x01)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DDSR (0x02)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_TERI (0x04)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DDCD (0x08)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_CTS  (0x10)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DSR  (0x20)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_RI   (0x40)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DCD  (0x80)
>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_ANY_DELTA (0x0F)
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/uart.h b/c/src/lib/libbsp/or1k/or1ksim/include/uart.h
>> index 0000000..92ed203
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/uart.h
>> @@ -0,0 +1,42 @@
>> + * @file
>> + * @defgroup or1ksim_uart UART Support
>> + * @brief Universal Asynchronous Receiver/Transmitter (UART) Support
>> +#ifndef LIBBSP_OR1K_OR1KSIM_UART_H
>> +#define LIBBSP_OR1K_OR1KSIM_UART_H
>> +#ifdef __cplusplus
>> +extern "C" {
>> +#define OR1KSIM_UART_DEFAULT_BAUD  115200
>> +#define OR1KSIM_BSP_UART_IRQ       13
>> +extern const console_fns or1ksim_uart_fns;
>> +#ifdef __cplusplus
>> +#endif /* LIBBSP_OR1K_OR1KSIM_UART_H */
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/irq/irq.c b/c/src/lib/libbsp/or1k/or1ksim/irq/irq.c
>> index 0000000..c3c4d6d
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/irq/irq.c
>> @@ -0,0 +1,42 @@
>> + * @file
>> + * @ingroup or1k_interrupt
>> + * @brief Interrupt support.
>> + * http://www.rtems.org/license/LICENSE.
>> +#include <bsp/irq-generic.h>
>> +/* Almost all of the jobs that the following functions should
>> + * do are implemented in cpukit
>> +void bsp_interrupt_handler_default(rtems_vector_number vector)
>> +    printk("spurious interrupt: %u\n", vector);
>> +rtems_status_code bsp_interrupt_facility_initialize()
>> +  return 0;
>> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>> +  return 0;
>> +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>> +  return 0;
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg b/c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg
>> index 0000000..fff00ae
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg
>> @@ -0,0 +1,7 @@
>> +include $(RTEMS_ROOT)/make/custom/default.cfg
>> +RTEMS_CPU = or1k
>> +CPU_CFLAGS = -O2
>> +CFLAGS_OPTIMIZE_V ?= -O0 -g
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>> index 0000000..29b37a6
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>> @@ -0,0 +1,115 @@
>> +## Automatically generated by ampolish3 - Do not edit
>> +if AMPOLISH3
>> +$(srcdir)/preinstall.am: Makefile.am
>> +       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>> +endif
>> +PREINSTALL_DIRS =
>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>> +all-local: $(TMPINSTALL_FILES)
>> +TMPINSTALL_FILES =
>> +CLEANFILES = $(TMPINSTALL_FILES)
>> +all-am: $(PREINSTALL_FILES)
>> +PREINSTALL_FILES =
>> +CLEANFILES += $(PREINSTALL_FILES)
>> +$(PROJECT_LIB)/$(dirstamp):
>> +       @$(MKDIR_P) $(PROJECT_LIB)
>> +       @: > $(PROJECT_LIB)/$(dirstamp)
>> +PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
>> +$(PROJECT_INCLUDE)/$(dirstamp):
>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)
>> +       @: > $(PROJECT_INCLUDE)/$(dirstamp)
>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
>> +$(PROJECT_INCLUDE)/bsp/$(dirstamp):
>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
>> +       @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
>> +PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
>> +$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
>> +$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
>> +$(PROJECT_INCLUDE)/bsp/linker-symbols.h: ../shared/include/linker-symbols.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>> +$(PROJECT_INCLUDE)/bsp/mm.h: ../../../libbsp/shared/include/mm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mm.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mm.h
>> +$(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
>> +$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>> +$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
>> +$(PROJECT_INCLUDE)/bsp/stackalloc.h: ../../shared/include/stackalloc.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/stackalloc.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/stackalloc.h
>> +$(PROJECT_INCLUDE)/bsp/uart-output-char.h: ../../shared/include/uart-output-char.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart-output-char.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart-output-char.h
>> +$(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
>> +$(PROJECT_INCLUDE)/bsp/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tm27.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tm27.h
>> +$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>> +$(PROJECT_INCLUDE)/bsp/uart.h: include/uart.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart.h
>> +$(PROJECT_INCLUDE)/bsp/or1ksim.h: include/or1ksim.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/or1ksim.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/or1ksim.h
>> +$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
>> +$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
>> +$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
>> +TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
>> +$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
>> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
>> +$(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(dirstamp)
>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/start/start.S b/c/src/lib/libbsp/or1k/or1ksim/start/start.S
>> index 0000000..6942b52
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/start/start.S
>> @@ -0,0 +1,182 @@
>> + * Copyright (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>> +#include <bsp/linker-symbols.h>
>> +/* The following macro defines the first instructions every exception
>> + * should execute before jumping to its handler function from the
>> + * exception vector table. r3 is saved into the stack and loaded with
>> + * vector number before jumping to _ISR_Handler. r3 value is restored
>> + * back from _ISR_Handler after handling the exception and before
>> + * returning from interrupt.
>> +#define EXCEPTION_SETUP(vector) \
>> +  l.nop   ;\
>> +  l.addi  r1, r1, -4 ;\
>> +  l.sw    0(r1), r3; \
>> +  l.addi  r3, r0, vector; \
>> +  l.j     _ISR_Handler; \
>> +  l.nop
>> +  .extern bsp_start
>> +  .extern boot_card
>> +  .extern bsp_section_bss_begin
>> +  .extern bsp_section_bss_end
>> +  .extern  bsp_start_vector_table_end
>> +  .extern  bsp_start_vector_table_size
>> +  .extern  bsp_vector_table_size
>> +  .extern  bsp_section_stack_begin
>> +  .extern exception_frame_save
>> +  .extern _OR1K_Exception_Process
>> +  .extern _OR1K_Exception_default
>> +  .extern rtems_clock_tick
>> +  .extern _exit
>> +  .extern printk
>> +  .extern bsp_interrupt_handler_default
>> +  /* Global symbols */
>> +  .global  _start
>> +  .global bsp_start_vector_table_begin
>> +/* Popualte HW vector table */
>> +.section .vector, "ax"
>> +.org 0x100
>> +_reset:
>> +  l.j _start
>> +  l.nop
>> +.org 0x200
>> +_buserr:
>> +  EXCEPTION_SETUP(2)
>> +.org 0x300
>> +_dPageFault:
>> +  EXCEPTION_SETUP(3)
>> +.org 0x400
>> +_iPageFaule:
>> +  EXCEPTION_SETUP(4)
>> +.org 0x500
>> +_timer:
>> +  EXCEPTION_SETUP(5)
>> +.org 0x600
>> +_unalign:
>> +  EXCEPTION_SETUP(6)
>> +.org 0x700
>> +_undefIns:
>> +  EXCEPTION_SETUP(7)
>> +.org 0x800
>> +_exInt:
>> +  EXCEPTION_SETUP(8)
>> +.org 0x900
>> +_dTLB:
>> +  EXCEPTION_SETUP(9)
>> +.org 0xA00
>> +_iTLB:
>> +  EXCEPTION_SETUP(10)
>> +.org 0xB00
>> +_range:
>> +  EXCEPTION_SETUP(11)
>> +.org 0xC00
>> +_syscall:
>> +  EXCEPTION_SETUP(12)
>> +.org 0xD00
>> +_fp:
>> +  EXCEPTION_SETUP(13)
>> +.org 0xE00
>> +_trap:
>> +  EXCEPTION_SETUP(14)
>> +.org 0xF00
>> +_undef1:
>> +  EXCEPTION_SETUP(15)
>> +.org 0x1500
>> +_undef2:
>> +  EXCEPTION_SETUP(16)
>> +.org 0x1900
>> +_undef3:
>> +  EXCEPTION_SETUP(17)
>> +.org 0x1F00
>> +bsp_start_vector_table_begin:
>> +  .word 0
>> +  .word _start /* Reset */
>> +  .word _OR1K_Exception_default /* Bus Error */
>> +  .word _OR1K_Exception_default /* Data Page Fault */
>> +  .word _OR1K_Exception_default /* Instruction Page Fault */
>> +  .word _OR1K_Exception_default /* Tick timer */
>> +  .word _OR1K_Exception_default /* Alignment */
>> +  .word _OR1K_Exception_default /* Undefiend Instruction */
>> +  .word _OR1K_Exception_default /* External Interrupt */
>> +  .word _OR1K_Exception_default /* Data TLB Miss */
>> +  .word _OR1K_Exception_default /* Instruction TLB Miss */
>> +  .word _OR1K_Exception_default /* Range Exception */
>> +  .word _OR1K_Exception_default /* System Call */
>> +  .word _OR1K_Exception_default /* Floating Point Exception */
>> +  .word _OR1K_Exception_default /* Trap */
>> +  .word _OR1K_Exception_default /* Reserver for future use */
>> +  .word _OR1K_Exception_default /* Reserved for implementation-specific */
>> +  .word _OR1K_Exception_default /* Reserved for custom exceptions. */
>> +bsp_start_vector_table_end:
>> +  .section  ".bsp_start_text", "ax"
>> +  .type _start, at function
>> +_start:
>> +  /* Set SR register to Supervision mode */
>> +  l.ori  r1, r0, 0x1
>> +  l.mtspr r0, r1, 17
>> +  /* load stack and frame pointers */
>> +  l.movhi r1, hi(bsp_section_stack_begin)
>> +  l.ori   r1, r1, lo(bsp_section_stack_begin)
>> +  l.add   r2, r0, r1
>> +/* Clearing .bss */
>> +  l.movhi r13, hi(bsp_section_bss_begin)
>> +  l.ori   r13, r13, lo(bsp_section_bss_begin)
>> +  l.movhi r15, hi(bsp_section_bss_end)
>> +  l.ori   r15, r15, lo(bsp_section_bss_end)
>> +_loop_clear_bss:
>> +  l.sfgeu r13, r15
>> +  l.bf    _end_clear_bss
>> +  l.addi  r13, r13, 4
>> +  l.sw    0(r13), r0
>> +  l.j     _loop_clear_bss
>> +  l.nop
>> +_end_clear_bss:
>> +  l.j boot_card
>> +  l.nop
>> +/* Temporary code for unhandled exceptions */
>> +.section .text
>> +.align
>> +.global _unhandled_exception
>> +unhandled_exception:
>> +  l.nop
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds b/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds
>> index 0000000..a88db1f
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds
>> @@ -0,0 +1,41 @@
>> + * @file
>> + * @ingroup bsp_linker
>> + * @brief Memory map
>> +MEMORY
>> +      VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 8260
>> +      RAM   : org = 0x00002048, l = 0x1FFDFB8
>> +      UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
>> +REGION_ALIAS ("REGION_START", RAM);
>> +REGION_ALIAS ("REGION_VECTOR", VECTOR_RAM);
>> +REGION_ALIAS ("REGION_TEXT", RAM);
>> +REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
>> +REGION_ALIAS ("REGION_RODATA", RAM);
>> +REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
>> +REGION_ALIAS ("REGION_DATA", RAM);
>> +REGION_ALIAS ("REGION_DATA_LOAD", RAM);
>> +REGION_ALIAS ("REGION_FAST_DATA", RAM);
>> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>> +REGION_ALIAS ("REGION_BSS", RAM);
>> +REGION_ALIAS ("REGION_WORK", RAM);
>> +REGION_ALIAS ("REGION_STACK", RAM);
>> +bsp_section_vector_begin = 0;
>> +bsp_section_stack_begin = 0x1FFDFB8;
>> +INCLUDE linkcmds.base
>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c b/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
>> index 0000000..5d557bf
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
>> @@ -0,0 +1,64 @@
>> + * @file
>> + * @brief Benchmark timer support.
>> + * Copyright (c) 2014 by Hesham ALMatary
>> +#include <rtems.h>
>> +#include <rtems/btimer.h>
>> +#define OR1KSIM_NANOSECONDS_PER_CLK_CYCLE 10
>> +static bool benchmark_timer_find_average_overhead = false;
>> +static uint64_t benchmark_timer_base;
>> +void benchmark_timer_initialize(void)
>> +  benchmark_timer_base = _OR1K_mfspr(CPU_OR1K_SPR_TTCR);
>> +#define AVG_OVERHEAD  0
>> +#define LEAST_VALID   1
>> +uint32_t benchmark_timer_read( void )
>> +  uint64_t         clicks;
>> +  uint64_t         total;
>> +  uint64_t         delta;
>> +   *  Read the timer and see how many clicks (clock cycles)
>> +   *  has passed since timer initialization.
>> +  clicks = _OR1K_mfspr(CPU_OR1K_SPR_TTCR);
>> +  delta = clicks - benchmark_timer_base;
>> +  /* total in nanoseconds */
>> +  total = OR1KSIM_NANOSECONDS_PER_CLK_CYCLE * (delta);
>> +  if ( benchmark_timer_find_average_overhead == true )
>> +    return total;          /* in nanoseconds microsecond units */
>> +  else {
>> +    if ( total < LEAST_VALID )
>> +      return 0;            /* below timer resolution */
>> +      return (total - AVG_OVERHEAD);
>> +void benchmark_timer_disable_subtracting_average_overhead(bool find_flag)
>> +  benchmark_timer_find_average_overhead = find_flag;
>> diff --git a/c/src/lib/libbsp/or1k/preinstall.am b/c/src/lib/libbsp/or1k/preinstall.am
>> index 0000000..dba6cc4
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/preinstall.am
>> @@ -0,0 +1,7 @@
>> +if AMPOLISH3
>> +endif
>> diff --git a/c/src/lib/libbsp/or1k/shared/include/linker-symbols.h b/c/src/lib/libbsp/or1k/shared/include/linker-symbols.h
>> index 0000000..f0f8377
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/shared/include/linker-symbols.h
>> @@ -0,0 +1,79 @@
>> +#ifndef LIBBSP_OR1k_SHARED_LINKER_SYMBOLS_H
>> +#define LIBBSP_OR1k_SHARED_LINKER_SYMBOLS_H
>> +#ifdef __cplusplus
>> +extern "C" {
>> + * @defgroup or1k_linker Linker Support
>> + * @ingroup or1k_shared
>> + * @brief Linker support.
>> +#ifndef ASM
>> +  #define LINKER_SYMBOL(sym) extern char sym [];
>> +#else
>> +  #define LINKER_SYMBOL(sym) .extern sym
>> +#endif
>> +LINKER_SYMBOL(bsp_section_start_begin)
>> +LINKER_SYMBOL(bsp_section_start_end)
>> +LINKER_SYMBOL(bsp_section_start_size)
>> +LINKER_SYMBOL(bsp_section_vector_begin)
>> +LINKER_SYMBOL(bsp_section_vector_end)
>> +LINKER_SYMBOL(bsp_section_vector_size)
>> +LINKER_SYMBOL(bsp_section_text_begin)
>> +LINKER_SYMBOL(bsp_section_text_end)
>> +LINKER_SYMBOL(bsp_section_text_size)
>> +LINKER_SYMBOL(bsp_section_text_load_begin)
>> +LINKER_SYMBOL(bsp_section_text_load_end)
>> +LINKER_SYMBOL(bsp_section_rodata_begin)
>> +LINKER_SYMBOL(bsp_section_rodata_end)
>> +LINKER_SYMBOL(bsp_section_rodata_size)
>> +LINKER_SYMBOL(bsp_section_rodata_load_begin)
>> +LINKER_SYMBOL(bsp_section_rodata_load_end)
>> +LINKER_SYMBOL(bsp_section_data_begin)
>> +LINKER_SYMBOL(bsp_section_data_end)
>> +LINKER_SYMBOL(bsp_section_data_size)
>> +LINKER_SYMBOL(bsp_section_data_load_begin)
>> +LINKER_SYMBOL(bsp_section_data_load_end)
>> +LINKER_SYMBOL(bsp_section_bss_begin)
>> +LINKER_SYMBOL(bsp_section_bss_end)
>> +LINKER_SYMBOL(bsp_section_bss_size)
>> +LINKER_SYMBOL(bsp_section_work_begin)
>> +LINKER_SYMBOL(bsp_section_work_end)
>> +LINKER_SYMBOL(bsp_section_work_size)
>> +LINKER_SYMBOL(bsp_section_stack_begin)
>> +LINKER_SYMBOL(bsp_section_stack_end)
>> +LINKER_SYMBOL(bsp_section_stack_size)
>> +LINKER_SYMBOL(bsp_vector_table_begin)
>> +LINKER_SYMBOL(bsp_vector_table_end)
>> +LINKER_SYMBOL(bsp_vector_table_size)
>> +LINKER_SYMBOL(bsp_start_vector_table_begin)
>> +LINKER_SYMBOL(bsp_start_vector_table_end)
>> +LINKER_SYMBOL(bsp_start_vector_table_size)
>> +LINKER_SYMBOL(bsp_translation_table_base)
>> +LINKER_SYMBOL(bsp_translation_table_end)
>> +#ifdef __cplusplus
>> +#endif /* LIBBSP_OR1K_SHARED_LINKER_SYMBOLS_H */
>> diff --git a/c/src/lib/libbsp/or1k/shared/startup/linkcmds.base b/c/src/lib/libbsp/or1k/shared/startup/linkcmds.base
>> index 0000000..e773d79
>> --- /dev/null
>> +++ b/c/src/lib/libbsp/or1k/shared/startup/linkcmds.base
>> @@ -0,0 +1,310 @@
>> + * @file
>> + * @brief Linker command base file.
>> +OUTPUT_ARCH (or1k)
>> +ENTRY (_start)
>> + * Global symbols that may be defined externally
>> +bsp_start_vector_table_begin = 0x1F00;
>> +bsp_vector_table_size = DEFINED (bsp_vector_table_size) ? bsp_vector_table_size
>> +: 8260;
>> +/* 8192 for raw vector table, and 17 * 4 for handlers vector. */
>> +bsp_section_xbarrier_align  = DEFINED (bsp_section_xbarrier_align) ? bsp_section_xbarrier_align : 1;
>> +bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
>> +bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
>> +bsp_stack_align = DEFINED (bsp_stack_align) ? bsp_stack_align : 8;
>> +bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 0;
>> +bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
>> +bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 1;
>> +SECTIONS {
>> +  .vector : ALIGN_WITH_INPUT {
>> +    *(.vector)
>> +    . = ALIGN(bsp_vector_table_size);
>> +    bsp_section_vector_end = .;
>> +  } > REGION_VECTOR AT > REGION_VECTOR
>> +  bsp_section_vector_size = bsp_section_vector_end - bsp_section_vector_begin;
>> +  bsp_vector_table_begin = bsp_section_vector_begin;
>> +  bsp_vector_table_end = bsp_vector_table_begin + bsp_vector_table_size;
>> +  .start : ALIGN_WITH_INPUT {
>> +    bsp_section_start_begin = .;
>> +    KEEP (*(.bsp_start_text))
>> +    KEEP (*(.bsp_start_data))
>> +    bsp_section_start_end = .;
>> +  } > REGION_START AT > REGION_START
>> +  bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
>> +.xbarrier : ALIGN_WITH_INPUT {
>> +    . = ALIGN (bsp_section_xbarrier_align);
>> +.text : ALIGN_WITH_INPUT {
>> +    bsp_section_text_begin = .;
>> +    *(.text.unlikely .text.*_unlikely)
>> +    *(.text .stub .text.* .gnu.linkonce.t.*)
>> +    /* .gnu.warning sections are handled specially by elf32.em.  */
>> +    *(.gnu.warning)
>> +    *(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
>> +  } > REGION_TEXT AT > REGION_TEXT_LOAD
>> +  .init : ALIGN_WITH_INPUT {
>> +    KEEP (*(.init))
>> +  .fini : ALIGN_WITH_INPUT {
>> +    KEEP (*(.fini))
>> +    bsp_section_text_end = .;
>> +  bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
>> +  bsp_section_text_load_begin = LOADADDR (.text);
>> +  bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
>> +.robarrier : ALIGN_WITH_INPUT {
>> +    . = ALIGN (bsp_section_robarrier_align);
>> +  } > REGION_RODATA AT > REGION_RODATA
>> +.rodata : ALIGN_WITH_INPUT {
>> +    bsp_section_rodata_begin = .;
>> +    *(.rodata .rodata.* .gnu.linkonce.r.*)
>> +  } > REGION_RODATA AT > REGION_RODATA_LOAD
>> +.eh_frame : ALIGN_WITH_INPUT {
>> +               KEEP (*(.eh_frame))
>> +       .gcc_except_table : ALIGN_WITH_INPUT {
>> +               *(.gcc_except_table .gcc_except_table.*)
>> +       .tdata : ALIGN_WITH_INPUT {
>> +               _TLS_Data_begin = .;
>> +               *(.tdata .tdata.* .gnu.linkonce.td.*)
>> +               _TLS_Data_end = .;
>> +       .tbss : ALIGN_WITH_INPUT {
>> +               _TLS_BSS_begin = .;
>> +               *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
>> +               _TLS_BSS_end = .;
>> +       _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
>> +       _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
>> +       _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
>> +       _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
>> +       _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
>> +       _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
>> +       .preinit_array : ALIGN_WITH_INPUT {
>> +               PROVIDE_HIDDEN (__preinit_array_start = .);
>> +               KEEP (*(.preinit_array))
>> +               PROVIDE_HIDDEN (__preinit_array_end = .);
>> +       .init_array : ALIGN_WITH_INPUT {
>> +               PROVIDE_HIDDEN (__init_array_start = .);
>> +               KEEP (*(SORT(.init_array.*)))
>> +               KEEP (*(.init_array))
>> +               PROVIDE_HIDDEN (__init_array_end = .);
>> +       .fini_array : ALIGN_WITH_INPUT {
>> +               PROVIDE_HIDDEN (__fini_array_start = .);
>> +               KEEP (*(.fini_array))
>> +               KEEP (*(SORT(.fini_array.*)))
>> +               PROVIDE_HIDDEN (__fini_array_end = .);
>> +       .ctors : ALIGN_WITH_INPUT {
>> +               /* gcc uses crtbegin.o to find the start of
>> +                  the constructors, so we make sure it is
>> +                  first.  Because this is a wildcard, it
>> +                  doesn't matter if the user does not
>> +                  actually link against crtbegin.o; the
>> +                  linker won't look for a file to match a
>> +                  wildcard.  The wildcard also means that it
>> +                  doesn't matter which directory crtbegin.o
>> +                  is in.  */
>> +               KEEP (*crtbegin.o(.ctors))
>> +               KEEP (*crtbegin?.o(.ctors))
>> +               /* We don't want to include the .ctor section from
>> +                  the crtend.o file until after the sorted ctors.
>> +                  The .ctor section from the crtend file contains the
>> +                  end of ctors marker and it must be last */
>> +               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
>> +               KEEP (*(SORT(.ctors.*)))
>> +               KEEP (*(.ctors))
>> +       .dtors : ALIGN_WITH_INPUT {
>> +               KEEP (*crtbegin.o(.dtors))
>> +               KEEP (*crtbegin?.o(.dtors))
>> +               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
>> +               KEEP (*(SORT(.dtors.*)))
>> +               KEEP (*(.dtors))
>> +       .data.rel.ro : ALIGN_WITH_INPUT {
>> +               *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
>> +               *(.data.rel.ro* .gnu.linkonce.d.rel.ro.*)
>> +       .jcr : ALIGN_WITH_INPUT {
>> +               KEEP (*(.jcr))
>> +       .interp : ALIGN_WITH_INPUT {
>> +               *(.interp)
>> +       .note.gnu.build-id : ALIGN_WITH_INPUT {
>> +               *(.note.gnu.build-id)
>> +       .hash : ALIGN_WITH_INPUT {
>> +               *(.hash)
>> +       .gnu.hash : ALIGN_WITH_INPUT {
>> +               *(.gnu.hash)
>> +       .dynsym : ALIGN_WITH_INPUT {
>> +               *(.dynsym)
>> +       .dynstr : ALIGN_WITH_INPUT {
>> +               *(.dynstr)
>> +       .gnu.version : ALIGN_WITH_INPUT {
>> +               *(.gnu.version)
>> +       .gnu.version_d : ALIGN_WITH_INPUT {
>> +               *(.gnu.version_d)
>> +       .gnu.version_r : ALIGN_WITH_INPUT {
>> +               *(.gnu.version_r)
>> +       .rel.dyn : ALIGN_WITH_INPUT {
>> +               *(.rel.init)
>> +               *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
>> +               *(.rel.fini)
>> +               *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
>> +               *(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*)
>> +               *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
>> +               *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
>> +               *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
>> +               *(.rel.ctors)
>> +               *(.rel.dtors)
>> +               *(.rel.got)
>> +               *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
>> +               PROVIDE_HIDDEN (__rel_iplt_start = .);
>> +               *(.rel.iplt)
>> +               PROVIDE_HIDDEN (__rel_iplt_end = .);
>> +               PROVIDE_HIDDEN (__rela_iplt_start = .);
>> +               PROVIDE_HIDDEN (__rela_iplt_end = .);
>> +       .rela.dyn : ALIGN_WITH_INPUT {
>> +               *(.rela.init)
>> +               *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
>> +               *(.rela.fini)
>> +               *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
>> +               *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
>> +               *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
>> +               *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
>> +               *(.rela.ctors)
>> +               *(.rela.dtors)
>> +               *(.rela.got)
>> +               *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
>> +               *(.rela.iplt)
>> +       .rel.plt : ALIGN_WITH_INPUT {
>> +               *(.rel.plt)
>> +       .rela.plt : ALIGN_WITH_INPUT {
>> +               *(.rela.plt)
>> +       .plt : ALIGN_WITH_INPUT {
>> +               *(.plt)
>> +       .iplt : ALIGN_WITH_INPUT {
>> +               *(.iplt)
>> +       .dynamic : ALIGN_WITH_INPUT {
>> +               *(.dynamic)
>> +       .got : ALIGN_WITH_INPUT {
>> +               *(.got.plt) *(.igot.plt) *(.got) *(.igot)
>> +       .rtemsroset : ALIGN_WITH_INPUT {
>> +               /* Special FreeBSD linker set sections */
>> +               __start_set_sysctl_set = .;
>> +               *(set_sysctl_*);
>> +               __stop_set_sysctl_set = .;
>> +               *(set_domain_*);
>> +               *(set_pseudo_*);
>> +               KEEP (*(SORT(.rtemsroset.*)))
>> +               bsp_section_rodata_end = .;
>> +  bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
>> +  bsp_section_rodata_load_begin = LOADADDR (.rodata);
>> +  bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
>> +.rwbarrier : ALIGN_WITH_INPUT {
>> +    . = ALIGN (bsp_section_rwbarrier_align);
>> +  } > REGION_DATA AT > REGION_DATA
>> +.data : ALIGN_WITH_INPUT {
>> +    bsp_section_data_begin = .;
>> +    *(.data .data.* .gnu.linkonce.d.*)
>> +    SORT(CONSTRUCTORS)
>> +  } > REGION_DATA AT > REGION_DATA_LOAD
>> +  .data1 : ALIGN_WITH_INPUT {
>> +    *(.data1)
>> +  .rtemsrwset : ALIGN_WITH_INPUT {
>> +    KEEP (*(SORT(.rtemsrwset.*)))
>> +    bsp_section_data_end = .;
>> +  bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
>> +  bsp_section_data_load_begin = LOADADDR (.data);
>> +  bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
>> +  .bss : ALIGN_WITH_INPUT {
>> +    bsp_section_bss_begin = .;
>> +    *(.dynbss)
>> +    *(.bss .bss.* .gnu.linkonce.b.*)
>> +    *(COMMON)
>> +    bsp_section_bss_end = .;
>> +  } > REGION_BSS AT > REGION_BSS
>> +  bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
>> +.work : ALIGN_WITH_INPUT {
>> +     * The work section will occupy the remaining REGION_WORK region and
>> +     * contains the RTEMS work space and heap.
>> +    bsp_section_work_begin = .;
>> +    . += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.);
>> +    bsp_section_work_end = .;
>> +  } > REGION_WORK AT > REGION_WORK
>> +  bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
>> +  .stack : ALIGN_WITH_INPUT {
>> +    bsp_section_stack_end = .;
>> +  } > REGION_STACK AT > REGION_STACK
>> +  bsp_section_stack_size = bsp_section_stack_begin - bsp_section_stack_end;
>> +  RamBase = ORIGIN (REGION_WORK);
>> +  RamSize = LENGTH (REGION_WORK);
>> +  WorkAreaBase = bsp_section_work_begin;
>> +  HeapSize = 0;
>> 1.9.3
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
