[PATCH] Add new (first) OpenRISC BSP called or1ksim.
Hesham Moustafa heshamelmatary at gmail.com
Wed Aug 20 20:40:34 UTC 2014
On Wed, Aug 20, 2014 at 10:29 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Aug 20, 2014 at 4:06 PM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
>> Hi,
>> On Wed, Aug 20, 2014 at 9:54 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> Hi
>>> Thanks.
>>> I just pushed this.  I did not compile it. Make sure it builds all tests
>> What about the nop instruction? Should I add a conditional macros in
>> the init.c file, or create a new macro to mirror l.nop to nop for or1k
>> targets?
> It might be nice to suggest this for gcc/gas. You can use a
> conditional like Joel suggested, otherwise.
>>> for
>>> you just like it did before.
>> Thanks for pushing the code.
>>> How is the test pass/fail rate?
>> How can I get this? Is there a script for running all tests or
>> something similar?
> You may be interested to investigate adding support for or1ksim to
> rtems-tester: http://git.rtems.org/rtems-tools/tree/tester
> We left it off the original plan due to time constraints, but it would
> be nice for maintenance of the port.
I will see what I can do.
>>> Did you get ticker running?
>> Ticker is running but there are still two issues. The first is with
>> the very long delay of context switches. The second is about the
> What is the fidelity of the clock in ork1sim? How accurate wrt wall
> time is it? Do you need to use any prescalar to get an accurate time?
> Using the FAST_IDLE mode can alleviate the timing problems.
The time is getting very quickly when I replace
"status = rtems_task_wake_after(task_index * 5 *
rtems_clock_get_ticks_per_second());"
with
"status = rtems_task_wake_after(task_index * 5);"
Though it goes very quickly. That was how I make sure ticker is
working and do not wait too much as for the case now.
When I used FAST_IDLE mode, I did not get output from ticker.exe. I
have configured or1ksim to run at 100MHz (10 ns) from sim.cfg and
added a definition for that at or1ksim.h which is used from uart.h
driver.
>> printf and the possibility of broken context switch (which I debug
>> currently). To get around the printf problem, I was adding an entry in
>> buffer_test_io.h for or1k target to force tests to use printk. Gedare
>> suggested not to push such a solution.
> Yes, you should not hide your bug in this way. Figure out why printf
> is failing. It almost certainly is corruption of the registers during
> either isr or context switch handling.
Yes, I am trying to debug with Sebastian's solution you provided.
Hopefully I'd find the bug soon.
Thanks,
Hesham
> -Gedare
>>> On 8/20/2014 12:23 PM, Hesham ALMatary wrote:
>>>> This BSP is intended to run on or1ksim (the main OpenRISC emulator).
>>>> Fixed version according to Joel comments from the mailing list.
>>>>  c/src/aclocal/rtems-cpu-subdirs.m4                 |   1 +
>>>>  c/src/lib/libbsp/or1k/Makefile.am                  |  10 +
>>>>  c/src/lib/libbsp/or1k/acinclude.m4                 |  10 +
>>>>  c/src/lib/libbsp/or1k/configure.ac                 |  19 ++
>>>>  c/src/lib/libbsp/or1k/or1ksim/Makefile.am          | 109 ++++++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/README               |  17 ++
>>>>  c/src/lib/libbsp/or1k/or1ksim/bsp_specs            |  12 +
>>>>  c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c     | 104 +++++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/configure.ac         |  30 ++
>>>>  .../libbsp/or1k/or1ksim/console/console-config.c   |  58 ++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/console/uart.c       | 144 ++++++++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/include/bsp.h        |  47 ++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/include/irq.h        |  45 +++
>>>>  c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h    | 118 ++++++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/include/uart.h       |  42 +++
>>>>  c/src/lib/libbsp/or1k/or1ksim/irq/irq.c            |  42 +++
>>>>  .../or1k/or1ksim/make/custom/or1k_or1ksim.cfg      |   7 +
>>>>  c/src/lib/libbsp/or1k/or1ksim/preinstall.am        | 115 ++++++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/start/start.S        | 182 ++++++++++++
>>>>  c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds     |  41 +++
>>>>  c/src/lib/libbsp/or1k/or1ksim/timer/timer.c        |  64 +++++
>>>>  c/src/lib/libbsp/or1k/preinstall.am                |   7 +
>>>>  .../libbsp/or1k/shared/include/linker-symbols.h    |  79 ++++++
>>>>  c/src/lib/libbsp/or1k/shared/startup/linkcmds.base | 310 +++++++++++++++++++++
>>>>  24 files changed, 1613 insertions(+)
>>>>  create mode 100644 c/src/lib/libbsp/or1k/Makefile.am
>>>>  create mode 100644 c/src/lib/libbsp/or1k/acinclude.m4
>>>>  create mode 100644 c/src/lib/libbsp/or1k/configure.ac
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/README
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/bsp_specs
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/configure.ac
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/console/console-config.c
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/bsp.h
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/irq.h
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/include/uart.h
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/irq/irq.c
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/start/start.S
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds
>>>>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
>>>>  create mode 100644 c/src/lib/libbsp/or1k/preinstall.am
>>>>  create mode 100644 c/src/lib/libbsp/or1k/shared/include/linker-symbols.h
>>>>  create mode 100644 c/src/lib/libbsp/or1k/shared/startup/linkcmds.base
>>>> diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4 b/c/src/aclocal/rtems-cpu-subdirs.m4
>>>> index c5a4a19..9593d34 100644
>>>> --- a/c/src/aclocal/rtems-cpu-subdirs.m4
>>>> +++ b/c/src/aclocal/rtems-cpu-subdirs.m4
>>>> @@ -23,6 +23,7 @@ _RTEMS_CPU_SUBDIR([mips],[$1]);;
>>>>  _RTEMS_CPU_SUBDIR([moxie],[$1]);;
>>>>  _RTEMS_CPU_SUBDIR([nios2],[$1]);;
>>>>  _RTEMS_CPU_SUBDIR([no_cpu],[$1]);;
>>>> +_RTEMS_CPU_SUBDIR([or1k],[$1]);;
>>>>  _RTEMS_CPU_SUBDIR([powerpc],[$1]);;
>>>>  _RTEMS_CPU_SUBDIR([sh],[$1]);;
>>>>  _RTEMS_CPU_SUBDIR([sparc],[$1]);;
>>>> diff --git a/c/src/lib/libbsp/or1k/Makefile.am b/c/src/lib/libbsp/or1k/Makefile.am
>>>> new file mode 100644
>>>> index 0000000..0ce20e6
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/Makefile.am
>>>> @@ -0,0 +1,10 @@
>>>> +ACLOCAL_AMFLAGS = -I ../../../aclocal
>>>> +## Descend into the @RTEMS_BSP_FAMILY@ directory
>>>> +## Currently, the shared directory is not explicitly
>>>> +## added but it is present in the source tree.
>>>> +SUBDIRS = @RTEMS_BSP_FAMILY@
>>>> +include $(srcdir)/preinstall.am
>>>> +include $(top_srcdir)/../../../automake/subdirs.am
>>>> +include $(top_srcdir)/../../../automake/local.am
>>>> diff --git a/c/src/lib/libbsp/or1k/acinclude.m4 b/c/src/lib/libbsp/or1k/acinclude.m4
>>>> index 0000000..c593670
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/acinclude.m4
>>>> @@ -0,0 +1,10 @@
>>>> +# RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY)
>>>> +AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>> +  case "$1" in
>>>> +  or1ksim )
>>>> +    AC_CONFIG_SUBDIRS([or1ksim]);;
>>>> +    AC_MSG_ERROR([Invalid BSP]);;
>>>> +  esac
>>>> diff --git a/c/src/lib/libbsp/or1k/configure.ac b/c/src/lib/libbsp/or1k/configure.ac
>>>> index 0000000..96bba16
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/configure.ac
>>>> @@ -0,0 +1,19 @@
>>>> +# Process this file with autoconf to produce a configure script.
>>>> +AC_PREREQ([2.69])
>>>> +AC_INIT([rtems-c-src-lib-libbsp-or1k],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
>>>> +AC_CONFIG_SRCDIR([or1ksim])
>>>> +RTEMS_TOP(../../../../..)
>>>> +RTEMS_CANONICAL_TARGET_CPU
>>>> +AM_INIT_AUTOMAKE([no-define foreign 1.12.2])
>>>> +AM_MAINTAINER_MODE
>>>> +RTEMS_ENV_RTEMSBSP
>>>> +RTEMS_PROJECT_ROOT
>>>> +RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY])
>>>> +# Explicitly list all Makefiles here
>>>> +AC_CONFIG_FILES([Makefile])
>>>> +AC_OUTPUT
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/Makefile.am b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>> index 0000000..d5eb10c
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/Makefile.am
>>>> @@ -0,0 +1,109 @@
>>>> +# @file
>>>> +# @brief Makefile of LibBSP for the or1ksim BSP.
>>>> +ACLOCAL_AMFLAGS = -I ../../../../aclocal
>>>> +include $(top_srcdir)/../../../../automake/compile.am
>>>> +include_bspdir = $(includedir)/bsp
>>>> +#include_libcpudir = $(includedir)/libcpu
>>>> +dist_project_lib_DATA = bsp_specs
>>>> +#                  Header                                                     #
>>>> +include_bsp_HEADERS =
>>>> +include_HEADERS = include/bsp.h
>>>> +nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>>>> +include_bsp_HEADERS += ../shared/include/linker-symbols.h
>>>> +include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
>>>> +include_bsp_HEADERS += ../../shared/include/utility.h
>>>> +include_bsp_HEADERS += ../../shared/include/irq-generic.h
>>>> +include_bsp_HEADERS += ../../shared/include/irq-info.h
>>>> +include_bsp_HEADERS += ../../shared/include/stackalloc.h
>>>> +include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>>>> +include_bsp_HEADERS += ../../shared/tod.h
>>>> +include_bsp_HEADERS += ../../shared/include/tm27.h
>>>> +include_bsp_HEADERS += include/irq.h
>>>> +include_bsp_HEADERS += include/uart.h
>>>> +include_bsp_HEADERS += include/or1ksim.h
>>>> +nodist_include_HEADERS = ../../shared/include/coverhd.h \
>>>> +  include/bspopts.h
>>>> +#                  Data                                                       #
>>>> +noinst_LIBRARIES = libbspstart.a
>>>> +libbspstart_a_SOURCES = start/start.S
>>>> +project_lib_DATA = start.$(OBJEXT)
>>>> +project_lib_DATA += startup/linkcmds
>>>> +project_lib_DATA += ../shared/startup/linkcmds.base
>>>> +#                  LibBSP                                                     #
>>>> +noinst_LIBRARIES += libbsp.a
>>>> +libbsp_a_SOURCES =
>>>> +libbsp_a_CPPFLAGS =
>>>> +libbsp_a_LIBADD =
>>>> +# Startup
>>>> +libbsp_a_SOURCES += ../../shared/bspstart.c
>>>> +libbsp_a_SOURCES += ../../shared/bspreset.c
>>>> +# Shared
>>>> +libbsp_a_SOURCES += ../../shared/bootcard.c
>>>> +libbsp_a_SOURCES += ../../shared/bspclean.c
>>>> +libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
>>>> +libbsp_a_SOURCES += ../../shared/bsplibc.c
>>>> +libbsp_a_SOURCES += ../../shared/bsppost.c
>>>> +libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
>>>> +libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>>>> +libbsp_a_SOURCES += ../../shared/cpucounterread.c
>>>> +libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
>>>> +libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>>>> +libbsp_a_SOURCES += ../../shared/sbrk.c
>>>> +libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>>>> +# Console
>>>> +libbsp_a_SOURCES += ../../shared/console.c
>>>> +libbsp_a_SOURCES += ../../shared/console_control.c
>>>> +libbsp_a_SOURCES += ../../shared/console_read.c
>>>> +libbsp_a_SOURCES += ../../shared/console_select.c
>>>> +libbsp_a_SOURCES += ../../shared/console_write.c
>>>> +libbsp_a_SOURCES += console/console-config.c
>>>> +libbsp_a_SOURCES += console/uart.c
>>>> +# Timer
>>>> +libbsp_a_SOURCES += timer/timer.c
>>>> +# clock
>>>> +libbsp_a_SOURCES += clock/clockdrv.c ../../../shared/clockdrv_shell.h
>>>> +# IRQ
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>>>> +libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>>> +libbsp_a_SOURCES += irq/irq.c
>>>> +#                  Special Rules                                              #
>>>> +DISTCLEANFILES = include/bspopts.h
>>>> +include $(top_srcdir)/../../../../automake/local.am
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/README b/c/src/lib/libbsp/or1k/or1ksim/README
>>>> index 0000000..99d1edf
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/README
>>>> @@ -0,0 +1,17 @@
>>>> +This BSP should run only on or1ksim: the main simulator for or1k architecture.
>>>> +or1ksim should be used for testing purposes.
>>>> +svn co http://opencores.org/ocsvn/openrisc/openrisc/trunk/or1ksim
>>>> +cd or1ksim
>>>> +mkdir builddir_or1ksim
>>>> +cd builddir_or1ksim
>>>> +../configure --target=or32-elf --prefix=/opt/or1ksim
>>>> +make all
>>>> +make install
>>>> +export PATH=/opt/or1ksim/bin:$PATH
>>>> +Configuration file "sim.cfg" should be provided for complex board
>>>> +configurations at the current directory (which you run or1ksim from) or at
>>>> +~/.or1k/
>>>> +sim -f sim.cfg hello.exe
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/bsp_specs b/c/src/lib/libbsp/or1k/or1ksim/bsp_specs
>>>> index 0000000..446dafa
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/bsp_specs
>>>> @@ -0,0 +1,12 @@
>>>> +%rename endfile old_endfile
>>>> +%rename startfile old_startfile
>>>> +%rename link old_link
>>>> +*startfile:
>>>> +%{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems: \
>>>> +%{!qrtems_debug: start.o%s} \
>>>> +%{qrtems_debug: start_g.o%s}}}
>>>> +*link:
>>>> +%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N -e _start}
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>>> index 0000000..926e2b0
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/clock/clockdrv.c
>>>> @@ -0,0 +1,104 @@
>>>> + * @file
>>>> + * @ingroup bsp_clock
>>>> + * @brief or1ksim clock support.
>>>> + * or1ksim Clock driver
>>>> + * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>>>> + * The license and distribution terms for this file may be
>>>> + * found in the file LICENSE in this distribution or at
>>>> + * http://www.rtems.org/license/LICENSE
>>>> +#include <rtems.h>
>>>> +#include <bsp.h>
>>>> +#include <bsp/irq.h>
>>>> +#include <bsp/or1ksim.h>
>>>> +#include <rtems/score/cpu.h>
>>>> +#include <rtems/score/or1k-utility.h>
>>>> +/* The number of clock cycles before generating a tick timer interrupt. */
>>>> +#define TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT     0xFFED9
>>>> +#define OR1KSIM_CLOCK_CYCLE_TIME_NANOSECONDS  10
>>>> +/* This prototype is added here to Avoid warnings */
>>>> +void Clock_isr(void *arg);
>>>> +static void or1ksim_clock_at_tick(void)
>>>> +  uint32_t TTMR;
>>>> + /* For TTMR register,
>>>> +  * The least significant 28 bits are the number of clock cycles
>>>> +  * before generating a tick timer interrupt. While the most
>>>> +  * significant 4 bits are used for mode configuration, tick timer
>>>> +  * interrupt enable and pending interrupts status.
>>>> +  TTMR = (CPU_OR1K_SPR_TTMR_MODE_RESTART | CPU_OR1K_SPR_TTMR_IE |
>>>> +           (TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT & CPU_OR1K_SPR_TTMR_TP_MASK)
>>>> +         ) & ~(CPU_OR1K_SPR_TTMR_IP);
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_TTMR, TTMR);
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_TTCR, 0);
>>>> +static void or1ksim_clock_handler_install(proc_ptr new_isr, proc_ptr old_isr)
>>>> +  rtems_status_code sc = RTEMS_SUCCESSFUL;
>>>> +  old_isr = NULL;
>>>> +  _CPU_ISR_install_vector(OR1K_EXCEPTION_TICK_TIMER,
>>>> +                          new_isr,
>>>> +                          old_isr);
>>>> +  if (sc != RTEMS_SUCCESSFUL) {
>>>> +    rtems_fatal_error_occurred(0xdeadbeef);
>>>> +static void or1ksim_clock_initialize(void)
>>>> +  uint32_t sr;
>>>> +  or1ksim_clock_at_tick();
>>>> +   /* Enable tick timer */
>>>> +  sr = _OR1K_mfspr(CPU_OR1K_SPR_SR);
>>>> +  sr |= CPU_OR1K_SPR_SR_TEE;
>>>> +  _OR1K_mtspr(CPU_OR1K_SPR_SR, sr);
>>>> + static void or1ksim_clock_cleanup(void)
>>>> + *  Return the nanoseconds since last tick
>>>> +static uint32_t or1ksim_clock_nanoseconds_since_last_tick(void)
>>>> +  return
>>>> +  TTMR_NUM_OF_CLOCK_TICKS_INTERRUPT * OR1KSIM_CLOCK_CYCLE_TIME_NANOSECONDS;
>>>> +#define Clock_driver_support_at_tick() or1ksim_clock_at_tick()
>>>> +#define Clock_driver_support_initialize_hardware() or1ksim_clock_initialize()
>>>> +#define Clock_driver_support_install_isr(isr, old_isr) \
>>>> +  do {                                                 \
>>>> +    or1ksim_clock_handler_install(isr, old_isr);               \
>>>> +    old_isr = NULL;                                    \
>>>> +  } while (0)
>>>> +#define Clock_driver_support_shutdown_hardware() or1ksim_clock_cleanup()
>>>> +#define Clock_driver_nanoseconds_since_last_tick \
>>>> +  or1ksim_clock_nanoseconds_since_last_tick
>>>> +#include "../../../shared/clockdrv_shell.h"
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/configure.ac b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
>>>> index 0000000..8aff7e3
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/configure.ac
>>>> @@ -0,0 +1,30 @@
>>>> +# @file
>>>> +# @brief Configure script of LibBSP for or1ksim BSP.
>>>> +AC_PREREQ(2.69)
>>>> +AC_INIT([rtems-c-src-lib-libbsp-or1k-or1ksim],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
>>>> +AC_CONFIG_SRCDIR([bsp_specs])
>>>> +RTEMS_TOP(../../../../../..)
>>>> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
>>>> +RTEMS_BSP_CONFIGURE
>>>> +RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
>>>> +RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
>>>> +RTEMS_BSPOPTS_SET([BSP_OR1K_OR1KSIM_PERIPHCLK],[*],[100000000U])
>>>> +RTEMS_BSPOPTS_HELP([BSP_OR1K_OR1KSIM_PERIPHCLK],[or1ksim PERIPHCLK clock frequency in Hz])
>>>> +RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm])
>>>> +RTEMS_CANONICALIZE_TOOLS
>>>> +RTEMS_PROG_CCAS
>>>> +RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
>>>> +RTEMS_BSP_LINKCMDS
>>>> +AC_OUTPUT
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/console-config.c b/c/src/lib/libbsp/or1k/or1ksim/console/console-config.c
>>>> index 0000000..9853f20
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/console-config.c
>>>> @@ -0,0 +1,58 @@
>>>> + * @file
>>>> + * @ingroup or1ksim_uart
>>>> + * @brief Console Configuration.
>>>> + * Copyright (c) 2014 Hesham ALMatary
>>>> +#include <rtems/bspIo.h>
>>>> +#include <libchip/serial.h>
>>>> +#include <bspopts.h>
>>>> +#include <bsp/uart.h>
>>>> +console_tbl Console_Configuration_Ports [] = {
>>>> +      .sDeviceName = "/dev/ttyS0",
>>>> +      .deviceType = SERIAL_CUSTOM,
>>>> +      .pDeviceFns = &or1ksim_uart_fns,
>>>> +      .deviceProbe = NULL,
>>>> +      .pDeviceFlow = NULL,
>>>> +      .ulCtrlPort1 = OR1KSIM_BSP_UART_BASE,
>>>> +      .ulCtrlPort2 = 0,
>>>> +      .ulClock = OR1KSIM_UART_DEFAULT_BAUD,
>>>> +      .ulIntVector = OR1KSIM_BSP_UART_IRQ
>>>> +#define PORT_COUNT \
>>>> +  (sizeof(Console_Configuration_Ports) \
>>>> +    / sizeof(Console_Configuration_Ports [0]))
>>>> +unsigned long Console_Configuration_Count = PORT_COUNT;
>>>> +static void output_char(char c)
>>>> +  const console_fns *con =
>>>> +    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>>>> +  if (c == '\n') {
>>>> +    con->deviceWritePolled((int) Console_Port_Minor, '\r');
>>>> +  con->deviceWritePolled((int) Console_Port_Minor, c);
>>>> +BSP_output_char_function_type BSP_output_char = output_char;
>>>> +BSP_polling_getchar_function_type BSP_poll_char = NULL;
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/console/uart.c b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>>>> index 0000000..f1cfa09
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/console/uart.c
>>>> @@ -0,0 +1,144 @@
>>>> + * @file
>>>> + * @brief UART support.
>>>> +#include <libchip/sersupp.h>
>>>> +#include <bsp.h>
>>>> +#include <rtems/score/isr.h>
>>>> +static rtems_vector_number uart_get_irq_number(const console_tbl *ct)
>>>> +   return ct->ulIntVector;
>>>> +static uint32_t uart_get_baud(const console_tbl *ct)
>>>> +   return ct->ulClock;
>>>> +static void uart_set_baud(int baud)
>>>> +  int divisor = (OR1KSIM_BSP_CLOCK_FREQ) / (16 * baud);
>>>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) |=
>>>> +    OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB;
>>>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW) = divisor & 0xff;
>>>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH) =
>>>> +    (divisor >> 8) & 0xff;
>>>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) &=
>>>> +    ~(OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB);
>>>> +static void uart_initialize(int minor)
>>>> +  /* Disable all interrupts */
>>>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_INT_ENABLE) = 0x00;
>>>> +  /* Reset receiver and transmitter */
>>>> +   OR1KSIM_REG(OR1KSIM_BSP_UART_REG_FIFO_CTRL) =
>>>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO |
>>>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR  |
>>>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT  |
>>>> +     OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14;
>>>> +  /* Set data pattern configuration */
>>>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_CTRL) =
>>>> +    OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8 &
>>>> +      (OR1KSIM_BSP_UART_REG_LINE_CTRL_STOP |
>>>> +       OR1KSIM_BSP_UART_REG_LINE_CTRL_PARITY);
>>>> +  /* Set baud rate */
>>>> +  uart_set_baud(OR1KSIM_UART_DEFAULT_BAUD);
>>>> +static int uart_first_open(int major, int minor, void *arg)
>>>> +  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *) arg;
>>>> +  struct rtems_termios_tty *tty = (struct rtems_termios_tty *) oc->iop->data1;
>>>> +  const console_tbl *ct = Console_Port_Tbl [minor];
>>>> +  console_data *cd = &Console_Port_Data [minor];
>>>> +  cd->termios_data = tty;
>>>> +  rtems_termios_set_initial_baud(tty, ct->ulClock);
>>>> +  return 0;
>>>> +static int uart_last_close(int major, int minor, void *arg)
>>>> +  return 0;
>>>> +static int uart_read_polled(int minor)
>>>> +   return -1;
>>>> +static void uart_write_polled(int minor, char c)
>>>> +  unsigned char lsr;
>>>> +  const uint32_t transmit_finished =
>>>> +    (OR1KSIM_BSP_UART_REG_LINE_STATUS_TEMT |
>>>> +     OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE);
>>>> +  /* Wait until there is no pending data in the transmitter FIFO (empty) */
>>>> +  do {
>>>> +      lsr = OR1KSIM_REG(OR1KSIM_BSP_UART_REG_LINE_STATUS);
>>>> +  } while (!(lsr & OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE));
>>>> +  OR1KSIM_REG(OR1KSIM_BSP_UART_REG_TX) = c;
>>>> +  /* Wait until trasmit data is finished */
>>>> +  do {
>>>> +  } while ( (lsr & transmit_finished) != transmit_finished );
>>>> +static ssize_t uart_write_support_polled(
>>>> +  int minor,
>>>> +  const char *s,
>>>> +  size_t n
>>>> +  ssize_t i = 0;
>>>> +  for (i = 0; i < n; ++i){
>>>> +    uart_write_polled(minor, s [i]);
>>>> +  return n;
>>>> +static int uart_set_attributes(int minor, const struct termios *term)
>>>> +  return -1;
>>>> +const console_fns or1ksim_uart_fns = {
>>>> +  .deviceProbe = libchip_serial_default_probe,
>>>> +  .deviceFirstOpen = uart_first_open,
>>>> +  .deviceLastClose = uart_last_close,
>>>> +  .deviceRead = uart_read_polled,
>>>> +  .deviceWrite = uart_write_support_polled,
>>>> +  .deviceInitialize = uart_initialize,
>>>> +  .deviceWritePolled = uart_write_polled,
>>>> +  .deviceSetAttributes = uart_set_attributes,
>>>> +  .deviceOutputUsesInterrupts = false
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/bsp.h b/c/src/lib/libbsp/or1k/or1ksim/include/bsp.h
>>>> index 0000000..502e4d9
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/bsp.h
>>>> @@ -0,0 +1,47 @@
>>>> + * @file
>>>> + * @ingroup or1k_or1ksim
>>>> + * @brief Global BSP definitions.
>>>> +#ifndef LIBBSP_OR1K_OR1KSIM_H
>>>> +#define LIBBSP_OR1K_OR1KSIM_H
>>>> +#include <rtems.h>
>>>> +#include <rtems/console.h>
>>>> +#include <rtems/clockdrv.h>
>>>> +#include <bsp/default-initial-extension.h>
>>>> +#ifdef __cplusplus
>>>> +extern "C" {
>>>> +#endif /* __cplusplus */
>>>> +#define BSP_FEATURE_IRQ_EXTENSION
>>>> +#ifdef __cplusplus
>>>> +#endif /* LIBBSP_OR1K_OR1KSIM_H */
>>>> + * @defgroup or1k_or1ksim support
>>>> + * @ingroup bsp_or1k
>>>> + * @brief or1ksim support package
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/irq.h b/c/src/lib/libbsp/or1k/or1ksim/include/irq.h
>>>> index 0000000..be669d8
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/irq.h
>>>> @@ -0,0 +1,45 @@
>>>> + * @file
>>>> + * @ingroup or1ksim_interrupt
>>>> + * @brief Interrupt definitions.
>>>> +#ifndef LIBBSP_OR1K_OR1KSIM_IRQ_H
>>>> +#define LIBBSP_OR1K_OR1KSIM_IRQ_H
>>>> +#ifndef ASM
>>>> +#include <rtems.h>
>>>> +#include <rtems/irq.h>
>>>> +#include <rtems/irq-extension.h>
>>>> +#define BSP_INTERRUPT_VECTOR_MIN  0x100
>>>> +#define BSP_INTERRUPT_VECTOR_MAX  0x1F00
>>>> +/* Interrupt Identification Register */
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID_MSI    (0x00)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID_NO_INT (0x01)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID_THRI   (0x02)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID_RDI    (0x04)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID_ID     (0x06)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID_RLSI   (0x06)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID_TOI    (0x0c)
>>>> +/* Interrupt Enable Register */
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_RDI  (0x01)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_THRI (0x02)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_RLSI (0x04)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE_MSI  (0x08)
>>>> +#endif /* ASM */
>>>> +#endif /* LIBBSP_OR1K_OR1KSIM_IRQ_H */
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
>>>> index 0000000..8279566
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/or1ksim.h
>>>> @@ -0,0 +1,118 @@
>>>> + * @file
>>>> + * @ingroup or1ksim_reg
>>>> + * @brief Register definitions.
>>>> +#include <stdint.h>
>>>> + * @defgroup or1ksim_reg Register Definitions
>>>> + * @brief Register Definitions
>>>> + * @name Register Macros
>>>> + #define OR1KSIM_REG(x)           (*((volatile char *) (x)))
>>>> + #define OR1KSIM_BIT(n)           (1 << (n))
>>>> + * @name Internal OR1K UART Registers
>>>> +#define OR1KSIM_BSP_CLOCK_FREQ       100000000UL
>>>> +#define OR1KSIM_BSP_UART_BASE        0x90000000
>>>> +#define OR1KSIM_BSP_UART_REG_TX              (OR1KSIM_BSP_UART_BASE+0)
>>>> +#define OR1KSIM_BSP_UART_REG_RX              (OR1KSIM_BSP_UART_BASE+0)
>>>> +#define OR1KSIM_BSP_UART_REG_DEV_LATCH_LOW   (OR1KSIM_BSP_UART_BASE+1)
>>>> +#define OR1KSIM_BSP_UART_REG_DEV_LATCH_HIGH  (OR1KSIM_BSP_UART_BASE+1)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ENABLE      (OR1KSIM_BSP_UART_BASE+2)
>>>> +#define OR1KSIM_BSP_UART_REG_INT_ID          (OR1KSIM_BSP_UART_BASE+2)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL       (OR1KSIM_BSP_UART_BASE+2)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL       (OR1KSIM_BSP_UART_BASE+3)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL      (OR1KSIM_BSP_UART_BASE+4)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS     (OR1KSIM_BSP_UART_BASE+5)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS    (OR1KSIM_BSP_UART_BASE+6)
>>>> +#define OR1KSIM_BSP_UART_REG_SCRATCH         (OR1KSIM_BSP_UART_BASE+7)
>>>> +/* FIFO Control Register */
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_1    (0x00)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO  (0x01)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR   (0x02)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT   (0x03)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_DMA_SELECT   (0x08)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_4    (0x40)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_8    (0x80)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_14   (0xC0)
>>>> +#define OR1KSIM_BSP_UART_REG_FIFO_CTRL_TRIGGER_MASK (0xC0)
>>>> +/* Line Control Register */
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN5  (0x00)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN6  (0x01)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN7  (0x02)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_WLEN8  (0x03)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_STOP   (0x04)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_PARITY (0x08)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_EPAR   (0x10)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_SPAR   (0x20)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_SBC    (0x40)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_CTRL_DLAB   (0x80)
>>>> +/* Line Status Register */
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_DR   (0x01)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_OE   (0x02)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_PE   (0x04)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_FE   (0x08)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_BI   (0x10)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_THRE (0x20)
>>>> +#define OR1KSIM_BSP_UART_REG_LINE_STATUS_TEMT (0x40)
>>>> +/* Modem Control Register */
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_DTR  (0x01)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_RTS  (0x02)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_OUT1 (0x04)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_OUT2 (0x08)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_CTRL_LOOP (0x10)
>>>> +/* Modem Status Register */
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DCTS (0x01)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DDSR (0x02)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_TERI (0x04)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DDCD (0x08)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_CTS  (0x10)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DSR  (0x20)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_RI   (0x40)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_DCD  (0x80)
>>>> +#define OR1KSIM_BSP_UART_REG_MODEM_STATUS_ANY_DELTA (0x0F)
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/include/uart.h b/c/src/lib/libbsp/or1k/or1ksim/include/uart.h
>>>> index 0000000..92ed203
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/include/uart.h
>>>> @@ -0,0 +1,42 @@
>>>> + * @file
>>>> + * @defgroup or1ksim_uart UART Support
>>>> + * @brief Universal Asynchronous Receiver/Transmitter (UART) Support
>>>> +#ifndef LIBBSP_OR1K_OR1KSIM_UART_H
>>>> +#define LIBBSP_OR1K_OR1KSIM_UART_H
>>>> +#ifdef __cplusplus
>>>> +extern "C" {
>>>> +#define OR1KSIM_UART_DEFAULT_BAUD  115200
>>>> +#define OR1KSIM_BSP_UART_IRQ       13
>>>> +extern const console_fns or1ksim_uart_fns;
>>>> +#ifdef __cplusplus
>>>> +#endif /* LIBBSP_OR1K_OR1KSIM_UART_H */
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/irq/irq.c b/c/src/lib/libbsp/or1k/or1ksim/irq/irq.c
>>>> index 0000000..c3c4d6d
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/irq/irq.c
>>>> @@ -0,0 +1,42 @@
>>>> + * @file
>>>> + * @ingroup or1k_interrupt
>>>> + * @brief Interrupt support.
>>>> + * http://www.rtems.org/license/LICENSE.
>>>> +#include <bsp/irq-generic.h>
>>>> +/* Almost all of the jobs that the following functions should
>>>> + * do are implemented in cpukit
>>>> +void bsp_interrupt_handler_default(rtems_vector_number vector)
>>>> +    printk("spurious interrupt: %u\n", vector);
>>>> +rtems_status_code bsp_interrupt_facility_initialize()
>>>> +  return 0;
>>>> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
>>>> +  return 0;
>>>> +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
>>>> +  return 0;
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg b/c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg
>>>> index 0000000..fff00ae
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/make/custom/or1k_or1ksim.cfg
>>>> @@ -0,0 +1,7 @@
>>>> +include $(RTEMS_ROOT)/make/custom/default.cfg
>>>> +RTEMS_CPU = or1k
>>>> +CPU_CFLAGS = -O2
>>>> +CFLAGS_OPTIMIZE_V ?= -O0 -g
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/preinstall.am b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> index 0000000..29b37a6
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/preinstall.am
>>>> @@ -0,0 +1,115 @@
>>>> +## Automatically generated by ampolish3 - Do not edit
>>>> +if AMPOLISH3
>>>> +$(srcdir)/preinstall.am: Makefile.am
>>>> +       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>>>> +endif
>>>> +PREINSTALL_DIRS =
>>>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>> +all-local: $(TMPINSTALL_FILES)
>>>> +TMPINSTALL_FILES =
>>>> +CLEANFILES = $(TMPINSTALL_FILES)
>>>> +all-am: $(PREINSTALL_FILES)
>>>> +PREINSTALL_FILES =
>>>> +CLEANFILES += $(PREINSTALL_FILES)
>>>> +$(PROJECT_LIB)/$(dirstamp):
>>>> +       @$(MKDIR_P) $(PROJECT_LIB)
>>>> +       @: > $(PROJECT_LIB)/$(dirstamp)
>>>> +PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
>>>> +$(PROJECT_INCLUDE)/$(dirstamp):
>>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)
>>>> +       @: > $(PROJECT_INCLUDE)/$(dirstamp)
>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
>>>> +$(PROJECT_INCLUDE)/bsp/$(dirstamp):
>>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
>>>> +       @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
>>>> +PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
>>>> +$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
>>>> +$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>> +$(PROJECT_INCLUDE)/bsp/linker-symbols.h: ../shared/include/linker-symbols.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>>>> +$(PROJECT_INCLUDE)/bsp/mm.h: ../../../libbsp/shared/include/mm.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mm.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mm.h
>>>> +$(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
>>>> +$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>> +$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
>>>> +$(PROJECT_INCLUDE)/bsp/stackalloc.h: ../../shared/include/stackalloc.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/stackalloc.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/stackalloc.h
>>>> +$(PROJECT_INCLUDE)/bsp/uart-output-char.h: ../../shared/include/uart-output-char.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart-output-char.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart-output-char.h
>>>> +$(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
>>>> +$(PROJECT_INCLUDE)/bsp/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tm27.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tm27.h
>>>> +$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>>>> +$(PROJECT_INCLUDE)/bsp/uart.h: include/uart.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart.h
>>>> +$(PROJECT_INCLUDE)/bsp/or1ksim.h: include/or1ksim.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/or1ksim.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/or1ksim.h
>>>> +$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
>>>> +$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
>>>> +$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
>>>> +TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
>>>> +$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
>>>> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
>>>> +$(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(dirstamp)
>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>>>> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/start/start.S b/c/src/lib/libbsp/or1k/or1ksim/start/start.S
>>>> index 0000000..6942b52
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/start/start.S
>>>> @@ -0,0 +1,182 @@
>>>> + * Copyright (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>>>> +#include <bsp/linker-symbols.h>
>>>> +/* The following macro defines the first instructions every exception
>>>> + * should execute before jumping to its handler function from the
>>>> + * exception vector table. r3 is saved into the stack and loaded with
>>>> + * vector number before jumping to _ISR_Handler. r3 value is restored
>>>> + * back from _ISR_Handler after handling the exception and before
>>>> + * returning from interrupt.
>>>> +#define EXCEPTION_SETUP(vector) \
>>>> +  l.nop   ;\
>>>> +  l.addi  r1, r1, -4 ;\
>>>> +  l.sw    0(r1), r3; \
>>>> +  l.addi  r3, r0, vector; \
>>>> +  l.j     _ISR_Handler; \
>>>> +  l.nop
>>>> +  .extern bsp_start
>>>> +  .extern boot_card
>>>> +  .extern bsp_section_bss_begin
>>>> +  .extern bsp_section_bss_end
>>>> +  .extern  bsp_start_vector_table_end
>>>> +  .extern  bsp_start_vector_table_size
>>>> +  .extern  bsp_vector_table_size
>>>> +  .extern  bsp_section_stack_begin
>>>> +  .extern exception_frame_save
>>>> +  .extern _OR1K_Exception_Process
>>>> +  .extern _OR1K_Exception_default
>>>> +  .extern rtems_clock_tick
>>>> +  .extern _exit
>>>> +  .extern printk
>>>> +  .extern bsp_interrupt_handler_default
>>>> +  /* Global symbols */
>>>> +  .global  _start
>>>> +  .global bsp_start_vector_table_begin
>>>> +/* Popualte HW vector table */
>>>> +.section .vector, "ax"
>>>> +.org 0x100
>>>> +_reset:
>>>> +  l.j _start
>>>> +  l.nop
>>>> +.org 0x200
>>>> +_buserr:
>>>> +  EXCEPTION_SETUP(2)
>>>> +.org 0x300
>>>> +_dPageFault:
>>>> +  EXCEPTION_SETUP(3)
>>>> +.org 0x400
>>>> +_iPageFaule:
>>>> +  EXCEPTION_SETUP(4)
>>>> +.org 0x500
>>>> +_timer:
>>>> +  EXCEPTION_SETUP(5)
>>>> +.org 0x600
>>>> +_unalign:
>>>> +  EXCEPTION_SETUP(6)
>>>> +.org 0x700
>>>> +_undefIns:
>>>> +  EXCEPTION_SETUP(7)
>>>> +.org 0x800
>>>> +_exInt:
>>>> +  EXCEPTION_SETUP(8)
>>>> +.org 0x900
>>>> +_dTLB:
>>>> +  EXCEPTION_SETUP(9)
>>>> +.org 0xA00
>>>> +_iTLB:
>>>> +  EXCEPTION_SETUP(10)
>>>> +.org 0xB00
>>>> +_range:
>>>> +  EXCEPTION_SETUP(11)
>>>> +.org 0xC00
>>>> +_syscall:
>>>> +  EXCEPTION_SETUP(12)
>>>> +.org 0xD00
>>>> +_fp:
>>>> +  EXCEPTION_SETUP(13)
>>>> +.org 0xE00
>>>> +_trap:
>>>> +  EXCEPTION_SETUP(14)
>>>> +.org 0xF00
>>>> +_undef1:
>>>> +  EXCEPTION_SETUP(15)
>>>> +.org 0x1500
>>>> +_undef2:
>>>> +  EXCEPTION_SETUP(16)
>>>> +.org 0x1900
>>>> +_undef3:
>>>> +  EXCEPTION_SETUP(17)
>>>> +.org 0x1F00
>>>> +bsp_start_vector_table_begin:
>>>> +  .word 0
>>>> +  .word _start /* Reset */
>>>> +  .word _OR1K_Exception_default /* Bus Error */
>>>> +  .word _OR1K_Exception_default /* Data Page Fault */
>>>> +  .word _OR1K_Exception_default /* Instruction Page Fault */
>>>> +  .word _OR1K_Exception_default /* Tick timer */
>>>> +  .word _OR1K_Exception_default /* Alignment */
>>>> +  .word _OR1K_Exception_default /* Undefiend Instruction */
>>>> +  .word _OR1K_Exception_default /* External Interrupt */
>>>> +  .word _OR1K_Exception_default /* Data TLB Miss */
>>>> +  .word _OR1K_Exception_default /* Instruction TLB Miss */
>>>> +  .word _OR1K_Exception_default /* Range Exception */
>>>> +  .word _OR1K_Exception_default /* System Call */
>>>> +  .word _OR1K_Exception_default /* Floating Point Exception */
>>>> +  .word _OR1K_Exception_default /* Trap */
>>>> +  .word _OR1K_Exception_default /* Reserver for future use */
>>>> +  .word _OR1K_Exception_default /* Reserved for implementation-specific */
>>>> +  .word _OR1K_Exception_default /* Reserved for custom exceptions. */
>>>> +bsp_start_vector_table_end:
>>>> +  .section  ".bsp_start_text", "ax"
>>>> +  .type _start, at function
>>>> +_start:
>>>> +  /* Set SR register to Supervision mode */
>>>> +  l.ori  r1, r0, 0x1
>>>> +  l.mtspr r0, r1, 17
>>>> +  /* load stack and frame pointers */
>>>> +  l.movhi r1, hi(bsp_section_stack_begin)
>>>> +  l.ori   r1, r1, lo(bsp_section_stack_begin)
>>>> +  l.add   r2, r0, r1
>>>> +/* Clearing .bss */
>>>> +  l.movhi r13, hi(bsp_section_bss_begin)
>>>> +  l.ori   r13, r13, lo(bsp_section_bss_begin)
>>>> +  l.movhi r15, hi(bsp_section_bss_end)
>>>> +  l.ori   r15, r15, lo(bsp_section_bss_end)
>>>> +_loop_clear_bss:
>>>> +  l.sfgeu r13, r15
>>>> +  l.bf    _end_clear_bss
>>>> +  l.addi  r13, r13, 4
>>>> +  l.sw    0(r13), r0
>>>> +  l.j     _loop_clear_bss
>>>> +  l.nop
>>>> +_end_clear_bss:
>>>> +  l.j boot_card
>>>> +  l.nop
>>>> +/* Temporary code for unhandled exceptions */
>>>> +.section .text
>>>> +.align
>>>> +.global _unhandled_exception
>>>> +unhandled_exception:
>>>> +  l.nop
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds b/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds
>>>> index 0000000..a88db1f
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/startup/linkcmds
>>>> @@ -0,0 +1,41 @@
>>>> + * @file
>>>> + * @ingroup bsp_linker
>>>> + * @brief Memory map
>>>> +MEMORY
>>>> +      VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 8260
>>>> +      RAM   : org = 0x00002048, l = 0x1FFDFB8
>>>> +      UNEXPECTED_SECTIONS : ORIGIN = 0xffffffff, LENGTH = 0
>>>> +REGION_ALIAS ("REGION_START", RAM);
>>>> +REGION_ALIAS ("REGION_VECTOR", VECTOR_RAM);
>>>> +REGION_ALIAS ("REGION_TEXT", RAM);
>>>> +REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
>>>> +REGION_ALIAS ("REGION_RODATA", RAM);
>>>> +REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
>>>> +REGION_ALIAS ("REGION_DATA", RAM);
>>>> +REGION_ALIAS ("REGION_DATA_LOAD", RAM);
>>>> +REGION_ALIAS ("REGION_FAST_DATA", RAM);
>>>> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>>>> +REGION_ALIAS ("REGION_BSS", RAM);
>>>> +REGION_ALIAS ("REGION_WORK", RAM);
>>>> +REGION_ALIAS ("REGION_STACK", RAM);
>>>> +bsp_section_vector_begin = 0;
>>>> +bsp_section_stack_begin = 0x1FFDFB8;
>>>> +INCLUDE linkcmds.base
>>>> diff --git a/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c b/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
>>>> index 0000000..5d557bf
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/or1ksim/timer/timer.c
>>>> @@ -0,0 +1,64 @@
>>>> + * @file
>>>> + * @brief Benchmark timer support.
>>>> + * Copyright (c) 2014 by Hesham ALMatary
>>>> +#include <rtems.h>
>>>> +#include <rtems/btimer.h>
>>>> +#define OR1KSIM_NANOSECONDS_PER_CLK_CYCLE 10
>>>> +static bool benchmark_timer_find_average_overhead = false;
>>>> +static uint64_t benchmark_timer_base;
>>>> +void benchmark_timer_initialize(void)
>>>> +  benchmark_timer_base = _OR1K_mfspr(CPU_OR1K_SPR_TTCR);
>>>> +#define AVG_OVERHEAD  0
>>>> +#define LEAST_VALID   1
>>>> +uint32_t benchmark_timer_read( void )
>>>> +  uint64_t         clicks;
>>>> +  uint64_t         total;
>>>> +  uint64_t         delta;
>>>> +   *  Read the timer and see how many clicks (clock cycles)
>>>> +   *  has passed since timer initialization.
>>>> +  clicks = _OR1K_mfspr(CPU_OR1K_SPR_TTCR);
>>>> +  delta = clicks - benchmark_timer_base;
>>>> +  /* total in nanoseconds */
>>>> +  total = OR1KSIM_NANOSECONDS_PER_CLK_CYCLE * (delta);
>>>> +  if ( benchmark_timer_find_average_overhead == true )
>>>> +    return total;          /* in nanoseconds microsecond units */
>>>> +  else {
>>>> +    if ( total < LEAST_VALID )
>>>> +      return 0;            /* below timer resolution */
>>>> +      return (total - AVG_OVERHEAD);
>>>> +void benchmark_timer_disable_subtracting_average_overhead(bool find_flag)
>>>> +  benchmark_timer_find_average_overhead = find_flag;
>>>> diff --git a/c/src/lib/libbsp/or1k/preinstall.am b/c/src/lib/libbsp/or1k/preinstall.am
>>>> index 0000000..dba6cc4
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/preinstall.am
>>>> @@ -0,0 +1,7 @@
>>>> +if AMPOLISH3
>>>> +endif
>>>> diff --git a/c/src/lib/libbsp/or1k/shared/include/linker-symbols.h b/c/src/lib/libbsp/or1k/shared/include/linker-symbols.h
>>>> index 0000000..f0f8377
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/shared/include/linker-symbols.h
>>>> @@ -0,0 +1,79 @@
>>>> +#ifndef LIBBSP_OR1k_SHARED_LINKER_SYMBOLS_H
>>>> +#define LIBBSP_OR1k_SHARED_LINKER_SYMBOLS_H
>>>> +#ifdef __cplusplus
>>>> +extern "C" {
>>>> + * @defgroup or1k_linker Linker Support
>>>> + * @ingroup or1k_shared
>>>> + * @brief Linker support.
>>>> +#ifndef ASM
>>>> +  #define LINKER_SYMBOL(sym) extern char sym [];
>>>> +#else
>>>> +  #define LINKER_SYMBOL(sym) .extern sym
>>>> +#endif
>>>> +LINKER_SYMBOL(bsp_section_start_begin)
>>>> +LINKER_SYMBOL(bsp_section_start_end)
>>>> +LINKER_SYMBOL(bsp_section_start_size)
>>>> +LINKER_SYMBOL(bsp_section_vector_begin)
>>>> +LINKER_SYMBOL(bsp_section_vector_end)
>>>> +LINKER_SYMBOL(bsp_section_vector_size)
>>>> +LINKER_SYMBOL(bsp_section_text_begin)
>>>> +LINKER_SYMBOL(bsp_section_text_end)
>>>> +LINKER_SYMBOL(bsp_section_text_size)
>>>> +LINKER_SYMBOL(bsp_section_text_load_begin)
>>>> +LINKER_SYMBOL(bsp_section_text_load_end)
>>>> +LINKER_SYMBOL(bsp_section_rodata_begin)
>>>> +LINKER_SYMBOL(bsp_section_rodata_end)
>>>> +LINKER_SYMBOL(bsp_section_rodata_size)
>>>> +LINKER_SYMBOL(bsp_section_rodata_load_begin)
>>>> +LINKER_SYMBOL(bsp_section_rodata_load_end)
>>>> +LINKER_SYMBOL(bsp_section_data_begin)
>>>> +LINKER_SYMBOL(bsp_section_data_end)
>>>> +LINKER_SYMBOL(bsp_section_data_size)
>>>> +LINKER_SYMBOL(bsp_section_data_load_begin)
>>>> +LINKER_SYMBOL(bsp_section_data_load_end)
>>>> +LINKER_SYMBOL(bsp_section_bss_begin)
>>>> +LINKER_SYMBOL(bsp_section_bss_end)
>>>> +LINKER_SYMBOL(bsp_section_bss_size)
>>>> +LINKER_SYMBOL(bsp_section_work_begin)
>>>> +LINKER_SYMBOL(bsp_section_work_end)
>>>> +LINKER_SYMBOL(bsp_section_work_size)
>>>> +LINKER_SYMBOL(bsp_section_stack_begin)
>>>> +LINKER_SYMBOL(bsp_section_stack_end)
>>>> +LINKER_SYMBOL(bsp_section_stack_size)
>>>> +LINKER_SYMBOL(bsp_vector_table_begin)
>>>> +LINKER_SYMBOL(bsp_vector_table_end)
>>>> +LINKER_SYMBOL(bsp_vector_table_size)
>>>> +LINKER_SYMBOL(bsp_start_vector_table_begin)
>>>> +LINKER_SYMBOL(bsp_start_vector_table_end)
>>>> +LINKER_SYMBOL(bsp_start_vector_table_size)
>>>> +LINKER_SYMBOL(bsp_translation_table_base)
>>>> +LINKER_SYMBOL(bsp_translation_table_end)
>>>> +#ifdef __cplusplus
>>>> +#endif /* LIBBSP_OR1K_SHARED_LINKER_SYMBOLS_H */
>>>> diff --git a/c/src/lib/libbsp/or1k/shared/startup/linkcmds.base b/c/src/lib/libbsp/or1k/shared/startup/linkcmds.base
>>>> index 0000000..e773d79
>>>> --- /dev/null
>>>> +++ b/c/src/lib/libbsp/or1k/shared/startup/linkcmds.base
>>>> @@ -0,0 +1,310 @@
>>>> + * @file
>>>> + * @brief Linker command base file.
>>>> +OUTPUT_ARCH (or1k)
>>>> +ENTRY (_start)
>>>> + * Global symbols that may be defined externally
>>>> +bsp_start_vector_table_begin = 0x1F00;
>>>> +bsp_vector_table_size = DEFINED (bsp_vector_table_size) ? bsp_vector_table_size
>>>> +: 8260;
>>>> +/* 8192 for raw vector table, and 17 * 4 for handlers vector. */
>>>> +bsp_section_xbarrier_align  = DEFINED (bsp_section_xbarrier_align) ? bsp_section_xbarrier_align : 1;
>>>> +bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ? bsp_section_robarrier_align : 1;
>>>> +bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1;
>>>> +bsp_stack_align = DEFINED (bsp_stack_align) ? bsp_stack_align : 8;
>>>> +bsp_stack_main_size = DEFINED (bsp_stack_main_size) ? bsp_stack_main_size : 0;
>>>> +bsp_stack_main_size = ALIGN (bsp_stack_main_size, bsp_stack_align);
>>>> +bsp_processor_count = DEFINED (bsp_processor_count) ? bsp_processor_count : 1;
>>>> +SECTIONS {
>>>> +  .vector : ALIGN_WITH_INPUT {
>>>> +    *(.vector)
>>>> +    . = ALIGN(bsp_vector_table_size);
>>>> +    bsp_section_vector_end = .;
>>>> +  } > REGION_VECTOR AT > REGION_VECTOR
>>>> +  bsp_section_vector_size = bsp_section_vector_end - bsp_section_vector_begin;
>>>> +  bsp_vector_table_begin = bsp_section_vector_begin;
>>>> +  bsp_vector_table_end = bsp_vector_table_begin + bsp_vector_table_size;
>>>> +  .start : ALIGN_WITH_INPUT {
>>>> +    bsp_section_start_begin = .;
>>>> +    KEEP (*(.bsp_start_text))
>>>> +    KEEP (*(.bsp_start_data))
>>>> +    bsp_section_start_end = .;
>>>> +  } > REGION_START AT > REGION_START
>>>> +  bsp_section_start_size = bsp_section_start_end - bsp_section_start_begin;
>>>> +.xbarrier : ALIGN_WITH_INPUT {
>>>> +    . = ALIGN (bsp_section_xbarrier_align);
>>>> +.text : ALIGN_WITH_INPUT {
>>>> +    bsp_section_text_begin = .;
>>>> +    *(.text.unlikely .text.*_unlikely)
>>>> +    *(.text .stub .text.* .gnu.linkonce.t.*)
>>>> +    /* .gnu.warning sections are handled specially by elf32.em.  */
>>>> +    *(.gnu.warning)
>>>> +    *(.glue_7t) *(.glue_7) *(.vfp11_veneer) *(.v4_bx)
>>>> +  } > REGION_TEXT AT > REGION_TEXT_LOAD
>>>> +  .init : ALIGN_WITH_INPUT {
>>>> +    KEEP (*(.init))
>>>> +  .fini : ALIGN_WITH_INPUT {
>>>> +    KEEP (*(.fini))
>>>> +    bsp_section_text_end = .;
>>>> +  bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
>>>> +  bsp_section_text_load_begin = LOADADDR (.text);
>>>> +  bsp_section_text_load_end = bsp_section_text_load_begin + bsp_section_text_size;
>>>> +.robarrier : ALIGN_WITH_INPUT {
>>>> +    . = ALIGN (bsp_section_robarrier_align);
>>>> +  } > REGION_RODATA AT > REGION_RODATA
>>>> +.rodata : ALIGN_WITH_INPUT {
>>>> +    bsp_section_rodata_begin = .;
>>>> +    *(.rodata .rodata.* .gnu.linkonce.r.*)
>>>> +  } > REGION_RODATA AT > REGION_RODATA_LOAD
>>>> +.eh_frame : ALIGN_WITH_INPUT {
>>>> +               KEEP (*(.eh_frame))
>>>> +       .gcc_except_table : ALIGN_WITH_INPUT {
>>>> +               *(.gcc_except_table .gcc_except_table.*)
>>>> +       .tdata : ALIGN_WITH_INPUT {
>>>> +               _TLS_Data_begin = .;
>>>> +               *(.tdata .tdata.* .gnu.linkonce.td.*)
>>>> +               _TLS_Data_end = .;
>>>> +       .tbss : ALIGN_WITH_INPUT {
>>>> +               _TLS_BSS_begin = .;
>>>> +               *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
>>>> +               _TLS_BSS_end = .;
>>>> +       _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
>>>> +       _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
>>>> +       _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
>>>> +       _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
>>>> +       _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
>>>> +       _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
>>>> +       .preinit_array : ALIGN_WITH_INPUT {
>>>> +               PROVIDE_HIDDEN (__preinit_array_start = .);
>>>> +               KEEP (*(.preinit_array))
>>>> +               PROVIDE_HIDDEN (__preinit_array_end = .);
>>>> +       .init_array : ALIGN_WITH_INPUT {
>>>> +               PROVIDE_HIDDEN (__init_array_start = .);
>>>> +               KEEP (*(SORT(.init_array.*)))
>>>> +               KEEP (*(.init_array))
>>>> +               PROVIDE_HIDDEN (__init_array_end = .);
>>>> +       .fini_array : ALIGN_WITH_INPUT {
>>>> +               PROVIDE_HIDDEN (__fini_array_start = .);
>>>> +               KEEP (*(.fini_array))
>>>> +               KEEP (*(SORT(.fini_array.*)))
>>>> +               PROVIDE_HIDDEN (__fini_array_end = .);
>>>> +       .ctors : ALIGN_WITH_INPUT {
>>>> +               /* gcc uses crtbegin.o to find the start of
>>>> +                  the constructors, so we make sure it is
>>>> +                  first.  Because this is a wildcard, it
>>>> +                  doesn't matter if the user does not
>>>> +                  actually link against crtbegin.o; the
>>>> +                  linker won't look for a file to match a
>>>> +                  wildcard.  The wildcard also means that it
>>>> +                  doesn't matter which directory crtbegin.o
>>>> +                  is in.  */
>>>> +               KEEP (*crtbegin.o(.ctors))
>>>> +               KEEP (*crtbegin?.o(.ctors))
>>>> +               /* We don't want to include the .ctor section from
>>>> +                  the crtend.o file until after the sorted ctors.
>>>> +                  The .ctor section from the crtend file contains the
>>>> +                  end of ctors marker and it must be last */
>>>> +               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
>>>> +               KEEP (*(SORT(.ctors.*)))
>>>> +               KEEP (*(.ctors))
>>>> +       .dtors : ALIGN_WITH_INPUT {
>>>> +               KEEP (*crtbegin.o(.dtors))
>>>> +               KEEP (*crtbegin?.o(.dtors))
>>>> +               KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
>>>> +               KEEP (*(SORT(.dtors.*)))
>>>> +               KEEP (*(.dtors))
>>>> +       .data.rel.ro : ALIGN_WITH_INPUT {
>>>> +               *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
>>>> +               *(.data.rel.ro* .gnu.linkonce.d.rel.ro.*)
>>>> +       .jcr : ALIGN_WITH_INPUT {
>>>> +               KEEP (*(.jcr))
>>>> +       .interp : ALIGN_WITH_INPUT {
>>>> +               *(.interp)
>>>> +       .note.gnu.build-id : ALIGN_WITH_INPUT {
>>>> +               *(.note.gnu.build-id)
>>>> +       .hash : ALIGN_WITH_INPUT {
>>>> +               *(.hash)
>>>> +       .gnu.hash : ALIGN_WITH_INPUT {
>>>> +               *(.gnu.hash)
>>>> +       .dynsym : ALIGN_WITH_INPUT {
>>>> +               *(.dynsym)
>>>> +       .dynstr : ALIGN_WITH_INPUT {
>>>> +               *(.dynstr)
>>>> +       .gnu.version : ALIGN_WITH_INPUT {
>>>> +               *(.gnu.version)
>>>> +       .gnu.version_d : ALIGN_WITH_INPUT {
>>>> +               *(.gnu.version_d)
>>>> +       .gnu.version_r : ALIGN_WITH_INPUT {
>>>> +               *(.gnu.version_r)
>>>> +       .rel.dyn : ALIGN_WITH_INPUT {
>>>> +               *(.rel.init)
>>>> +               *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*)
>>>> +               *(.rel.fini)
>>>> +               *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*)
>>>> +               *(.rel.data.rel.ro* .rel.gnu.linkonce.d.rel.ro.*)
>>>> +               *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*)
>>>> +               *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*)
>>>> +               *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*)
>>>> +               *(.rel.ctors)
>>>> +               *(.rel.dtors)
>>>> +               *(.rel.got)
>>>> +               *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*)
>>>> +               PROVIDE_HIDDEN (__rel_iplt_start = .);
>>>> +               *(.rel.iplt)
>>>> +               PROVIDE_HIDDEN (__rel_iplt_end = .);
>>>> +               PROVIDE_HIDDEN (__rela_iplt_start = .);
>>>> +               PROVIDE_HIDDEN (__rela_iplt_end = .);
>>>> +       .rela.dyn : ALIGN_WITH_INPUT {
>>>> +               *(.rela.init)
>>>> +               *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
>>>> +               *(.rela.fini)
>>>> +               *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
>>>> +               *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
>>>> +               *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
>>>> +               *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
>>>> +               *(.rela.ctors)
>>>> +               *(.rela.dtors)
>>>> +               *(.rela.got)
>>>> +               *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
>>>> +               *(.rela.iplt)
>>>> +       .rel.plt : ALIGN_WITH_INPUT {
>>>> +               *(.rel.plt)
>>>> +       .rela.plt : ALIGN_WITH_INPUT {
>>>> +               *(.rela.plt)
>>>> +       .plt : ALIGN_WITH_INPUT {
>>>> +               *(.plt)
>>>> +       .iplt : ALIGN_WITH_INPUT {
>>>> +               *(.iplt)
>>>> +       .dynamic : ALIGN_WITH_INPUT {
>>>> +               *(.dynamic)
>>>> +       .got : ALIGN_WITH_INPUT {
>>>> +               *(.got.plt) *(.igot.plt) *(.got) *(.igot)
>>>> +       .rtemsroset : ALIGN_WITH_INPUT {
>>>> +               /* Special FreeBSD linker set sections */
>>>> +               __start_set_sysctl_set = .;
>>>> +               *(set_sysctl_*);
>>>> +               __stop_set_sysctl_set = .;
>>>> +               *(set_domain_*);
>>>> +               *(set_pseudo_*);
>>>> +               KEEP (*(SORT(.rtemsroset.*)))
>>>> +               bsp_section_rodata_end = .;
>>>> +  bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
>>>> +  bsp_section_rodata_load_begin = LOADADDR (.rodata);
>>>> +  bsp_section_rodata_load_end = bsp_section_rodata_load_begin + bsp_section_rodata_size;
>>>> +.rwbarrier : ALIGN_WITH_INPUT {
>>>> +    . = ALIGN (bsp_section_rwbarrier_align);
>>>> +  } > REGION_DATA AT > REGION_DATA
>>>> +.data : ALIGN_WITH_INPUT {
>>>> +    bsp_section_data_begin = .;
>>>> +    *(.data .data.* .gnu.linkonce.d.*)
>>>> +    SORT(CONSTRUCTORS)
>>>> +  } > REGION_DATA AT > REGION_DATA_LOAD
>>>> +  .data1 : ALIGN_WITH_INPUT {
>>>> +    *(.data1)
>>>> +  .rtemsrwset : ALIGN_WITH_INPUT {
>>>> +    KEEP (*(SORT(.rtemsrwset.*)))
>>>> +    bsp_section_data_end = .;
>>>> +  bsp_section_data_size = bsp_section_data_end - bsp_section_data_begin;
>>>> +  bsp_section_data_load_begin = LOADADDR (.data);
>>>> +  bsp_section_data_load_end = bsp_section_data_load_begin + bsp_section_data_size;
>>>> +  .bss : ALIGN_WITH_INPUT {
>>>> +    bsp_section_bss_begin = .;
>>>> +    *(.dynbss)
>>>> +    *(.bss .bss.* .gnu.linkonce.b.*)
>>>> +    *(COMMON)
>>>> +    bsp_section_bss_end = .;
>>>> +  } > REGION_BSS AT > REGION_BSS
>>>> +  bsp_section_bss_size = bsp_section_bss_end - bsp_section_bss_begin;
>>>> +.work : ALIGN_WITH_INPUT {
>>>> +     * The work section will occupy the remaining REGION_WORK region and
>>>> +     * contains the RTEMS work space and heap.
>>>> +    bsp_section_work_begin = .;
>>>> +    . += ORIGIN (REGION_WORK) + LENGTH (REGION_WORK) - ABSOLUTE (.);
>>>> +    bsp_section_work_end = .;
>>>> +  } > REGION_WORK AT > REGION_WORK
>>>> +  bsp_section_work_size = bsp_section_work_end - bsp_section_work_begin;
>>>> +  .stack : ALIGN_WITH_INPUT {
>>>> +    bsp_section_stack_end = .;
>>>> +  } > REGION_STACK AT > REGION_STACK
>>>> +  bsp_section_stack_size = bsp_section_stack_begin - bsp_section_stack_end;
>>>> +  RamBase = ORIGIN (REGION_WORK);
>>>> +  RamSize = LENGTH (REGION_WORK);
>>>> +  WorkAreaBase = bsp_section_work_begin;
>>>> +  HeapSize = 0;
>>>> 1.9.3
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
>> devel mailing list
>> devel at rtems.org
