[PATCH] Add new (first) OpenRISC BSP called or1ksim.
Wed Aug 20 20:44:26 UTC 2014
On 8/20/2014 3:06 PM, Hesham Moustafa wrote:
> Hi,
> On Wed, Aug 20, 2014 at 9:54 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> Thanks.
>> I just pushed this.  I did not compile it. Make sure it builds all tests
> What about the nop instruction? Should I add a conditional macros in
> the init.c file, or create a new macro to mirror l.nop to nop for or1k
> targets?
Temporarily add to the test. I think the idea of always having nop as a
pseudo-mnemonic in gas is still open. Christian for sure hasn't weighed
in yet.
>> for
>> you just like it did before.
> Thanks for pushing the code.
No problem. Hopefully it is ok. Easier to fix after getting the bulk in IMO.
>> How is the test pass/fail rate?
> How can I get this? Is there a script for running all tests or
> something similar?
rtems-tools/tester/rtems-test is a nice Python tool for running a set of
.exe's.
It has to be taught how to run the simulator for a particular BSP.
rtems-testing/sim-scripts the older framework which supports more simulators
at the moment but does not parallelize the runs. If you want to add it
to this,
I can help.
You should teach rtems-test about running the or1ksim. Chris can give
some advice on that.
Ideally both frameworks would support the or1ksim BSP but rtems-tester
is the new way and preferred.
>> Did you get ticker running?
> Ticker is running but there are still two issues. The first is with
> the very long delay of context switches. The second is about the
> printf and the possibility of broken context switch (which I debug
> currently). To get around the printf problem, I was adding an entry in
> buffer_test_io.h for or1k target to force tests to use printk. Gedare
> suggested not to push such a solution.
:) Hopefully I can take a few minutes and read the assembly for the ISR code
next to the SPARC. I need to reproduce what you have first though.
