[PATCH] Add new documentation section for OpenRISC CPU architecture.
Hesham Moustafa heshamelmatary at gmail.com
Wed Aug 20 20:55:44 UTC 2014
On Wed, Aug 20, 2014 at 10:51 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I pushed this.  You had the right idea to prod us. There is a lot
> of code flying right now and we want to not forget any of it.
> Some comments.
> + Turn list of implementations into a bullet list with URLs.
> + I turned on spell check in gvim and fixed some.
Thanks for fixing spelling. I will add the bullet list.
> If someone thinks there are other topics to address, please
> speak up.
> Is Thread Local Storage supported? I recall we turned it on
> in gcc.
or1k/shared/startup/linkcmds.base allocates a TLS section. But
or1k-context-initialize.c still does not know about TLS.
> --joel
> On 8/16/2014 11:30 AM, Hesham ALMatary wrote:
>>  doc/cpu_supplement/Makefile.am         |  6 +++
>>  doc/cpu_supplement/cpu_supplement.texi |  2 +
>>  doc/cpu_supplement/or1k.t              | 78 ++++++++++++++++++++++++++++++++++
>>  3 files changed, 86 insertions(+)
>>  create mode 100644 doc/cpu_supplement/or1k.t
>> diff --git a/doc/cpu_supplement/Makefile.am b/doc/cpu_supplement/Makefile.am
>> index 3083922..300ff78 100644
>> --- a/doc/cpu_supplement/Makefile.am
>> +++ b/doc/cpu_supplement/Makefile.am
>> @@ -23,6 +23,7 @@ GENERATED_FILES += m32r.texi
>>  GENERATED_FILES += m68k.texi
>>  GENERATED_FILES += microblaze.texi
>>  GENERATED_FILES += mips.texi
>> +GENERATED_FILES += or1k.texi
>>  GENERATED_FILES += powerpc.texi
>>  GENERATED_FILES += nios2.texi
>>  GENERATED_FILES += sh.texi
>> @@ -101,6 +102,11 @@ mips.texi: mips.t
>>           -u "Top" \
>>           -n "" < $< > $@
>> +or1k.texi: or1k.t
>> +     $(BMENU2) -p "" \
>> +         -u "Top" \
>> +         -n "" < $< > $@
>>  powerpc.texi: powerpc.t
>>       $(BMENU2) -p "" \
>>           -u "Top" \
>> diff --git a/doc/cpu_supplement/cpu_supplement.texi b/doc/cpu_supplement/cpu_supplement.texi
>> index 1087538..5c484d0 100644
>> --- a/doc/cpu_supplement/cpu_supplement.texi
>> +++ b/doc/cpu_supplement/cpu_supplement.texi
>> @@ -73,6 +73,7 @@
>>  * M68xxx and Coldfire Specific Information::
>>  * Xilinx MicroBlaze Specific Information::
>>  * MIPS Specific Information::
>> +* OpenRISC 1000 Specific Information::
>>  * Altera Nios II Specific Information::
>>  * PowerPC Specific Information::
>>  * SuperH Specific Information::
>> @@ -97,6 +98,7 @@
>>  @include microblaze.texi
>>  @include mips.texi
>>  @include nios2.texi
>> + at include or1k.texi
>>  @include powerpc.texi
>>  @include sh.texi
>>  @include sparc.texi
>> diff --git a/doc/cpu_supplement/or1k.t b/doc/cpu_supplement/or1k.t
>> new file mode 100644
>> index 0000000..219f23b
>> --- /dev/null
>> +++ b/doc/cpu_supplement/or1k.t
>> @@ -0,0 +1,78 @@
>> + at c
>> + at c  COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
>> + at c  All rights reserved.
>> + at ifinfo
>> + at end ifinfo
>> + at chapter OpenRISC 1000 Specific Information
>> +This chapter discusses the
>> + at uref{http://opencores.org/or1k/Main_Page, OpenRISC 1000 architecture}
>> +dependencies in this port of RTEMS. There are many implementations
>> +for OpenRISC like or1200 and mor1kx. Currently RTEMS supports basic
>> +features that all implementations should have.
>> + at subheading Architecture Documents
>> +For information on the OpenRISC 1000 architecture refer to the
>> + at uref{http://openrisc.github.io/or1k.html,OpenRISC 1000 architecture manual}.
>> + at section Calling Conventions
>> +Please refer to the
>> + at uref{http://openrisc.github.io/or1k.html#__RefHeading__504887_595890882,Function Calling Sequence}.
>> + at subsection Floating Point Unit
>> +A floating point unit is currently not supported.
>> + at section Memory Model
>> +A flat 32-bit memory model is supported.
>> + at section Interrupt Processing
>> +OpenRISC 1000 architecture has 13 exception types:
>> + at itemize @bullet
>> + at item Reset
>> + at item Bus Error
>> + at item Data Page Fault
>> + at item Instruction Page Fault
>> + at item Tick Timer
>> + at item Alignment
>> + at item Illegal Instruction
>> + at item External Interrupt
>> + at item D-TLB Miss
>> + at item I-TLB Miss
>> + at item Range
>> + at item System Call
>> + at item Floating Point
>> + at item Trap
>> + at end itemize
>> + at subsection Interrupt Levels
>> +There are only two levels: interrupts enabled and interrupts disabled.
>> + at subsection Interrupt Stack
>> +OpenRISC RTEMS port uses RTEMS SW interrupt stack.
>> +The stack for interrupts is allocated during interrupt driver initilization.
>> +When an  interrup entered, the _ISR_Handler routine is resposible for
>> +switching from the interrupted task stack to RTEMS SW interrupt stack.
>> + at section Default Fatal Error Processing
>> +The default fatal error handler for this architecture performs the
>> +following actions:
>> + at item disables operating system supported interrupts (IRQ),
>> + at item places the error code in @code{r0}, and
>> + at item executes an infinite loop to simulate a halt processor instruction.
>> + at end itemize
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
