[PATCH v2] bsp/tms570: implemented support functions to satisfy complete tests build requirements.
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Aug 21 13:38:24 UTC 2014
This patch enables to build all RTEMS tests for tms570ls3137_hdk_sdram
BSP variant in in default build. Debug build with --enable-rtems-debug set
has succeed for samples subset of tests as well.
 c/src/lib/libbsp/arm/tms570/Makefile.am            |  9 ++++
 .../lib/libbsp/arm/tms570/clock/benchmark_timer.c  | 61 +++++++++++++++++++++
 c/src/lib/libbsp/arm/tms570/clock/clock.c          |  4 +-
 .../lib/libbsp/arm/tms570/include/system-clocks.h  | 62 ++++++++++++++++++++++
 .../arm/tms570/make/custom/tms570ls3137_hdk.cfg    |  2 +-
 .../tms570/make/custom/tms570ls3137_hdk_intram.cfg |  2 +-
 .../tms570/make/custom/tms570ls3137_hdk_sdram.cfg  |  2 +-
 c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c  | 44 +++++++++++++++
 c/src/lib/libbsp/arm/tms570/preinstall.am          |  4 ++
 9 files changed, 186 insertions(+), 4 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c
 create mode 100644 c/src/lib/libbsp/arm/tms570/include/system-clocks.h
 create mode 100644 c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
diff --git a/c/src/lib/libbsp/arm/tms570/Makefile.am b/c/src/lib/libbsp/arm/tms570/Makefile.am
index 02d7b66..e66cf79 100644
--- a/c/src/lib/libbsp/arm/tms570/Makefile.am
+++ b/c/src/lib/libbsp/arm/tms570/Makefile.am
@@ -39,6 +39,7 @@ include_bsp_HEADERS += include/tms570-rti.h
 include_bsp_HEADERS += include/tms570-vim.h
 include_bsp_HEADERS += include/tms570-pom.h
 include_bsp_HEADERS += include/tms570-sci-driver.h
+include_bsp_HEADERS += include/system-clocks.h
 include_HEADERS += ../../shared/include/tm27.h
@@ -78,6 +79,7 @@ libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
 libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
 libbsp_a_SOURCES += ../../shared/sbrk.c
 libbsp_a_SOURCES += ../../shared/src/stackalloc.c
+libbsp_a_SOURCES += ../../shared/cpucounterdiff.c
 # Startup
 libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
@@ -105,6 +107,7 @@ libbsp_a_SOURCES += console/tms570-sci.c
 # Clock
 libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
 libbsp_a_SOURCES += clock/clock.c
+libbsp_a_SOURCES += clock/benchmark_timer.c
 # RTC
@@ -115,9 +118,15 @@ libbsp_a_SOURCES += clock/clock.c
 # Benchmark Timer
 # Misc
+libbsp_a_SOURCES += misc/cpucounterread.c
 # Watchdog
+# Cache
+libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
+libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
+libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
 # Start hooks
 libbsp_a_SOURCES += startup/bspstarthooks.c
diff --git a/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c b/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c
new file mode 100644
index 0000000..b45f0f4
--- /dev/null
+++ b/c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c
@@ -0,0 +1,61 @@
+ * @file benchmark_timer.c
+ * @ingroup tms570
+ * @brief clock functions definitions.
+ * Copyright (c) 2014 Pavel Pisa <pisa at cmp.felk.cvut.cz>
+ * Czech Technical University in Prague
+ * Zikova 1903/4
+ * 166 36 Praha 6
+ * Czech Republic
+ * Based on LPC24xx and LPC1768 BSP
+ * by embedded brains GmbH and others
+#include <stdlib.h>
+#include <rtems.h>
+#include <bsp.h>
+#include <bsp/system-clocks.h>
+#include <rtems/btimer.h>
+#include <rtems/timerdrv.h>
+bool benchmark_timer_find_average_overhead = false;
+static uint32_t benchmark_timer_base;
+void benchmark_timer_initialize(void)
+  benchmark_timer_base = _CPU_Counter_read();
+uint32_t benchmark_timer_read(void)
+  uint32_t delta = _CPU_Counter_read() - benchmark_timer_base;
+  if (benchmark_timer_find_average_overhead) {
+    return delta;
+  } else {
+    /* TODO check on hardware */
+    if (delta > 74) {
+      return delta - 74;
+    } else {
+      return 0;
+void benchmark_timer_disable_subtracting_average_overhead(bool find_average_overhead )
+  benchmark_timer_find_average_overhead = find_average_overhead;
diff --git a/c/src/lib/libbsp/arm/tms570/clock/clock.c b/c/src/lib/libbsp/arm/tms570/clock/clock.c
index 2a8bb5f..4dba949 100644
--- a/c/src/lib/libbsp/arm/tms570/clock/clock.c
+++ b/c/src/lib/libbsp/arm/tms570/clock/clock.c
@@ -29,6 +29,7 @@
 #include <bsp.h>
 #include <bsp/irq.h>
 #include <bsp/tms570-rti.h>
+#include <rtems/counter.h>
  *  holds HW counter value since last interrupt event
@@ -49,6 +50,8 @@ static void tms570_clock_driver_support_initialize_hardware( void )
   uint32_t microsec_per_tick = rtems_configuration_get_microseconds_per_tick();
+  rtems_counter_initialize_converter(BSP_PLL_OUT_CLOCK);
   /* Hardware specific initialize */
   TMS570_RTI.RTIGCTRL = 0;
   TMS570_RTI.RTICPUC0 = BSP_PLL_OUT_CLOCK /1000000 / 2; /* prescaler */
@@ -80,7 +83,6 @@ static void tms570_clock_driver_support_at_tick( void )
   TMS570_RTI.RTIINTFLAG = 0x00000001;
   tms570_rti_last_tick_fcr0 = TMS570_RTI.RTICOMP0 - TMS570_RTI.RTIUDCP0;
-  /* TMS570_RTI.RTICOMP0 += 1000; */
diff --git a/c/src/lib/libbsp/arm/tms570/include/system-clocks.h b/c/src/lib/libbsp/arm/tms570/include/system-clocks.h
index 0000000..d441ec4
--- /dev/null
+++ b/c/src/lib/libbsp/arm/tms570/include/system-clocks.h
@@ -0,0 +1,62 @@
+ * @ingroup tms570
+ * @brief System clocks.
+ * Zikova 1903/4
+ * 166 36 Praha 6
+ * Czech Republic
+#ifndef LIBBSP_ARM_TMS570_SYSTEM_CLOCKS_H
+#define LIBBSP_ARM_TMS570_SYSTEM_CLOCKS_H
+#include <bsp/tms570-rti.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup tms570_clock System Clocks
+ * @ingroup tms570
+ * @brief Returns current standard timer value in microseconds.
+ * This function uses RTI module free running counter 0 used
+ * which is used as system tick timebase as well.
+static inline unsigned tms570_timer(void)
+  uint32_t actual_fcr0 = TMS570_RTI.RTIFRC0;
+  return actual_fcr0;
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_TMS570_SYSTEM_CLOCKS_H */
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
index eb4a65f..e90414a 100644
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg
@@ -8,7 +8,7 @@ RTEMS_CPU = arm
 CPU_CFLAGS = -march=armv7-r -mthumb -mbig-endian
-CFLAGS_OPTIMIZE_V = -O2 -ggdb3 -DNDEBUG
+CFLAGS_OPTIMIZE_V = -O2 -ggdb
 BINEXT?=.bin
 # This defines the operations performed on the linked executable.
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg
 BINEXT?=.bin
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg
 BINEXT?=.bin
diff --git a/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c b/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
index 0000000..f25380c
--- /dev/null
+++ b/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
@@ -0,0 +1,44 @@
+ * @file
+ * @ingroup tms570_clocks
+ * Zikova 1903/4
+ * 166 36 Praha 6
+ * Czech Republic
+#include <rtems.h>
+#include <bsp.h>
+ * @brief returns the actual value of Cortex-R cycle counter register
+ * The register is incremented at each core clock period
+ * @retval x actual core clock counter value
+CPU_Counter_ticks _CPU_Counter_read(void)
+  uint32_t ticks;
+  asm volatile ("mrc p15, 0, %0, c9, c13, 0\n": "=r" (ticks));
+  return ticks;
diff --git a/c/src/lib/libbsp/arm/tms570/preinstall.am b/c/src/lib/libbsp/arm/tms570/preinstall.am
index 81dbad1..d7ac628 100644
--- a/c/src/lib/libbsp/arm/tms570/preinstall.am
+++ b/c/src/lib/libbsp/arm/tms570/preinstall.am
@@ -109,6 +109,10 @@ $(PROJECT_INCLUDE)/bsp/tms570-sci-driver.h: include/tms570-sci-driver.h $(PROJEC
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tms570-sci-driver.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tms570-sci-driver.h
+$(PROJECT_INCLUDE)/bsp/system-clocks.h: include/system-clocks.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/system-clocks.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/system-clocks.h
 $(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
1.9.1
