[PATCH] bsp/tms570: disable huge memory demanding tests for internal RAM build variant.
Pavel Pisa pisa at cmp.felk.cvut.cz
Thu Aug 21 14:57:47 UTC 2014
BSP completes build with tests and debug enabled for all three variants now
  tms570ls3137_hdk
  tms570ls3137_hdk_intram
  tms570ls3137_hdk_sdram
Even that all enabled tests builds for internal RAM variant, many
of them are expected to fail on hardware because whole tests
including code, data and runtime work area demands has to fit
into 256 kB of RAM.
 .../make/custom/tms570ls3137_hdk-testsuite.tcfg    | 13 ------------
 .../custom/tms570ls3137_hdk_intram-testsuite.tcfg  | 23 ++++++++++++++++++++++
 2 files changed, 23 insertions(+), 13 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg
b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg
index 6f722bc..b79994e 100644
--- a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg
@@ -4,16 +4,3 @@
 # Format is one line per test that is _NOT_ built.
-flashdisk01
-utf8proc01
-spstkalloc02
-fsdosfsname01
-jffs2_fserror
-jffs2_fslink
-jffs2_fspatheval
-jffs2_fspermission
-jffs2_fsrdwr
-jffs2_fssymlink
-jffs2_fstime
-pppd
-mghttpd01
diff --git a/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg
b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg
new file mode 100644
index 0000000..f4f00e8
--- /dev/null
+++ b/c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram-testsuite.tcfg
@@ -0,0 +1,23 @@
+# tms570ls3137 RTEMS Test Database.
+# Format is one line per test that is _NOT_ built.
+fileio
+iostream
+pppd
+loopback
+syscall01
+utf8proc01
+monitor02
+mghttpd01
+ftp01
+fsdosfsname01
+jffs2_fserror
+jffs2_fslink
+jffs2_fspatheval
+jffs2_fspermission
+jffs2_fsrdwr
+jffs2_fssymlink
+jffs2_fstime
1.9.1
