[PATCH] libchip/dwmac: Make PHY address user configurable.
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Aug 21 15:07:49 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
This patch allows the user to configure the PHY address for the DWMAC driver by
giving a pointer to a dwmac_user_cfg structure to network stak via
rtems_bsdnet_config.ifconfig->drv_ctrl.
c/src/libchip/network/dwmac-common.h | 1 +
c/src/libchip/network/dwmac.c | 31 +++++++++++++++++++------------
c/src/libchip/network/dwmac.h | 8 ++++++++
3 files changed, 28 insertions(+), 12 deletions(-)
diff --git a/c/src/libchip/network/dwmac-common.h b/c/src/libchip/network/dwmac-common.h
index b61b833..05bf941 100644
--- a/c/src/libchip/network/dwmac-common.h
+++ b/c/src/libchip/network/dwmac-common.h
@@ -227,6 +227,7 @@ typedef struct {
struct mbuf **mbuf_addr_rx;
struct mbuf **mbuf_addr_tx;
const dwmac_cfg *CFG;
+ int MDIO_BUS_ADDR;
} dwmac_common_context;
struct dwmac_common_core_ops {
diff --git a/c/src/libchip/network/dwmac.c b/c/src/libchip/network/dwmac.c
index 20d87dc..499e02b 100644
--- a/c/src/libchip/network/dwmac.c
+++ b/c/src/libchip/network/dwmac.c
@@ -131,7 +131,7 @@ static int dwmac_if_mdio_read(
if ( phy == -1 ) {
reg_value = MACGRP_GMII_ADDRESS_PHYSICAL_LAYER_ADDRESS_SET(
reg_value,
- self->CFG->MDIO_BUS_ADDR
+ self->MDIO_BUS_ADDR
} else {
@@ -187,7 +187,7 @@ static int dwmac_if_mdio_write(
if ( phy == -1 ) {
reg_value,
} else {
@@ -347,7 +347,7 @@ static int dwmac_if_interface_stats( void *arg )
volatile macgrp *macgrp = self->macgrp;
int media = 0;
bool media_ok = dwmac_if_media_status(
- self, &media, self->CFG->MDIO_BUS_ADDR );
+ self, &media, self->MDIO_BUS_ADDR );
uint32_t oui;
uint8_t model;
uint8_t revision;
@@ -364,7 +364,7 @@ static int dwmac_if_interface_stats( void *arg )
printf( "\n" );
eno = dwmac_get_phy_info(
self,
- self->CFG->MDIO_BUS_ADDR,
+ self->MDIO_BUS_ADDR,
&oui,
&model,
&revision );
@@ -372,7 +372,7 @@ static int dwmac_if_interface_stats( void *arg )
if ( eno == 0 ) {
printf( "PHY 0x%02x: OUI = 0x%04" PRIX32 ", Model = 0x%02" PRIX8 ", Rev = "
"0x%02" PRIX8 "\n",
oui,
model,
revision );
@@ -387,7 +387,7 @@ static int dwmac_if_interface_stats( void *arg )
} else {
- printf( "PHY %d communication error\n", self->CFG->MDIO_BUS_ADDR );
+ printf( "PHY %d communication error\n", self->MDIO_BUS_ADDR );
printf( "\nHardware counters:\n" );
@@ -1250,7 +1250,7 @@ static int dwmac_update_autonegotiation_params( dwmac_common_context *self )
uint32_t value = self->macgrp->mac_configuration;
int media = 0;
if ( media_ok ) {
@@ -2065,7 +2065,8 @@ static int dwmac_if_attach(
const dwmac_callback_cfg *CALLBACK = &driver_config->CALLBACK;
const dwmac_common_desc_ops *DESC_OPS =
(const dwmac_common_desc_ops *) driver_config->DESC_OPS->ops;
+ const dwmac_user_cfg *user_cfg =
+ (const dwmac_user_cfg *) bsd_config->drv_ctrl;
assert( self != NULL );
assert( bsd_config != NULL );
@@ -2135,9 +2136,15 @@ static int dwmac_if_attach(
if ( eno == 0 ) {
- assert( 32 >= driver_config->MDIO_BUS_ADDR );
+ if ( user_cfg == NULL ) {
+ self->MDIO_BUS_ADDR = driver_config->MDIO_BUS_ADDR;
+ } else {
+ self->MDIO_BUS_ADDR = user_cfg->MDIO_BUS_ADDR;
+ assert( 32 >= self->MDIO_BUS_ADDR );
- if ( 32 < driver_config->MDIO_BUS_ADDR ) {
+ if ( 32 < self->MDIO_BUS_ADDR ) {
eno = EINVAL;
@@ -2317,7 +2324,7 @@ int dwmac_if_read_from_phy(
if ( arg != NULL ) {
eno = dwmac_if_mdio_read(
self,
phy_reg,
&value );
@@ -2341,7 +2348,7 @@ int dwmac_if_write_to_phy(
eno = dwmac_if_mdio_write(
self,
phy_reg,
val );
diff --git a/c/src/libchip/network/dwmac.h b/c/src/libchip/network/dwmac.h
index 9ccf75a..2220aa7 100644
--- a/c/src/libchip/network/dwmac.h
+++ b/c/src/libchip/network/dwmac.h
@@ -31,6 +31,14 @@
extern "C" {
#endif /* __cplusplus */
+/** @brief DWMAC user configuration structure.
+ * Gives the user the possibility to overwrite some configuration data.
+typedef struct {
+} dwmac_user_cfg;
/** @brief PHY event.
* Data type to be used for PHY events and event sets.
1.8.4.5
