arm/nds - cache_manager.c build failure
Fri Aug 22 14:38:40 UTC 2014
Looks like this function needs a guard on #if
defined(CPU_INSTRUCTION_CACHE_ALIGNMENT)
see rtems_cache_invalidate_multiple_instruction_lines()
On Fri, Aug 22, 2014 at 10:30 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> I am guessing some conditional path isn't being covered right to
> get CPU_INSTRUCTION_CACHE_ALIGNMENT defined. Could
> someone please take a look at this and fix it?
> arm-rtems4.11-gcc --pipe -B../../../../../.././lib/
> -B../../../../../.././nds/lib/ -specs bsp_specs -qrtems
> -DHAVE_CONFIG_H
> -I../../../../../../../../rtems/c/src/lib/libbsp/arm/nds/../../shared/include
> -mstructure-size-boundary=8 -mcpu=arm9tdmi -mfpu=vfp -mfloat-abi=soft
> -mthumb-interwork  -O2 -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
> libbsp_a-cache_manager.o -MD -MP -MF .deps/libbsp_a-cache_manager.Tpo -c
> -o libbsp_a-cache_manager.o `test -f
> '../../../libcpu/shared/src/cache_manager.c' || echo
> '../../../../../../../../rtems/c/src/lib/libbsp/arm/nds/'`../../../libcpu/shared/src/cache_manager.c
> ../../../../../../../../rtems/c/src/lib/libbsp/arm/nds/../../../libcpu/shared/src/cache_manager.c:
> In function '_invalidate_multiple_instruction_lines_no_range_functions':
> ../../../../../../../../rtems/c/src/lib/libbsp/arm/nds/../../../libcpu/shared/src/cache_manager.c:458:40:
> error: 'CPU_INSTRUCTION_CACHE_ALIGNMENT' undeclared (first use in this
> function)
>    i_addr = (void *)((size_t)i_addr & ~(CPU_INSTRUCTION_CACHE_ALIGNMENT
> - 1));
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
