[PATCH 2/2] rtems: Add more clock tick functions
Fri Aug 22 15:12:02 UTC 2014
Add rtems_clock_ticks_later(), rtems_clock_ticks_later_us() and
rtems_clock_ticks_later_us().
FIXME: Patch is incomplete.  Documentation and tests are missing.  Just
for API review.
 cpukit/rtems/include/rtems/rtems/clock.h | 66 ++++++++++++++++++++++++++++++++
 1 file changed, 66 insertions(+)
diff --git a/cpukit/rtems/include/rtems/rtems/clock.h b/cpukit/rtems/include/rtems/rtems/clock.h
index ff71665..cee930e 100644
--- a/cpukit/rtems/include/rtems/rtems/clock.h
+++ b/cpukit/rtems/include/rtems/rtems/clock.h
@@ -34,6 +34,7 @@
 #include <rtems/score/tod.h>
+#include <rtems/config.h>
 #include <sys/time.h> /* struct timeval */
@@ -160,6 +161,71 @@ RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_get_ticks_since_boot(void)
+ * @brief Returns the ticks counter value delta ticks in the future.
+ * @param[in] delta The ticks delta value.
+ * @return The tick counter value delta ticks in the future.
+RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_ticks_later(
+  rtems_interval delta
+  return _Watchdog_Ticks_since_boot + delta;
+ * @brief Returns the ticks counter value at least delta microseconds in the
+ * future.
+ * @param[in] delta The delta value in microseconds.
+ * @return The tick counter value at least delta microseconds in the future.
+RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_ticks_later_us(
+  rtems_interval us_per_tick = rtems_configuration_get_microseconds_per_tick();
+  return _Watchdog_Ticks_since_boot + (delta + us_per_tick - 1) / us_per_tick;
+ * @brief Returns true if the current ticks counter value indicates a time
+ * before the time specified by the ticks value and false otherwise.
+ * @param[in] ticks The ticks value.
+ * This can be used to write busy loops with a timeout.
+ * @code
+ * status busy( void )
+ *   rtems_interval timeout = rtems_clock_ticks_later_us( 10000 );
+ *   do {
+ *     if ( ok() ) {
+ *       return success;
+ *   } while ( rtems_clock_ticks_before( timeout ) );
+ *   return timeout;
+ * @endcode
+ * @retval true The current ticks counter value indicates a time before the
+ * time specified by the ticks value.
+ * @retval false Otherwise.
+RTEMS_INLINE_ROUTINE bool rtems_clock_ticks_before(
+  rtems_interval ticks
+  return ( (int32_t) ticks - (int32_t) _Watchdog_Ticks_since_boot ) > 0;
  * @brief Obtain Ticks Per Seconds
  * This routine implements the rtems_clock_get_ticks_per_second
1.8.4.5
