powerpc/gwlcfm does not compile
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Aug 22 15:13:14 UTC 2014
Hi
More from the overnight build. Could someone fix this?
powerpc-rtems4.11-gcc --pipe -B../../../../.././lib/
-B../../../../.././gwlcfm/lib/ -specs bsp_specs -qrtems
-DPACKAGE_NAME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-powerpc\"
-DPACKAGE_VERSION=\"4.10.99.0\"
-DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-powerpc\ 4.10.99.0\"
-DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -DPACKAGE_URL=\"\"
-I. -I../../../../../../../rtems/c/src/lib/libcpu/powerpc -isystem
../../../../.././gwlcfm/lib/include -mcpu=8540 -meabi -msdata=sysv
-fno-common -msoft-float -D__ppc_generic -mstrict-align -O2 -g
-fno-keep-inline-functions -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
mpc55xx/misc/flash_support.o -MD -MP -MF $depbase.Tpo -c -o
../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c
mv -f $depbase.Tpo $depbase.Po
../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c:
In function 'mpc55xx_flash_copy_op':
../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c:482:30:
error: 'volatile struct FLASH_tag' has no member named 'BIUCR'
flash_biucr_r = FLASH.BIUCR.R;
../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c:483:14:
FLASH.BIUCR.B.PFLIM = 0;
../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc55xx/misc/flash_support.c:496:9:
warning: passing argument 1 of 'rtems_cache_flush_multiple_data_lines'
discards 'volatile' qualifier from pointer target type [enabled by default]
rtems_cache_flush_multiple_data_lines(flash, sizeof(flash[0]));
