[PATCH] bsp/tms570: implemented and tested initialization of Cortex-R performance counters.
Pavel Pisa
pisa at cmp.felk.cvut.cz
Fri Aug 22 15:20:46 UTC 2014
The code is written as BSP specific now but it should work for all
Cortex-A and R based CPUs and can be moved to ARM generic place in future.
StackOverflow suggested sequences of writes to the registers required
to start counters is used.
http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c | 88 +++++++++++++++++++++--
1 file changed, 84 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c b/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
index f25380c..3ce2f63 100644
--- a/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
+++ b/c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c
@@ -3,7 +3,14 @@
* @ingroup tms570_clocks
- * @brief System clocks.
+ * @brief Cortex-R performace counters
+ * The counters setup functions are these which has been suggested
+ * on StackOverflow
+ * Code is probably for use on Cortex-A without modifications as well.
+ * http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
@@ -14,9 +21,6 @@
* 166 36 Praha 6
* Czech Republic
- * Based on LPC24xx and LPC1768 BSP
- * by embedded brains GmbH and others
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.org/license/LICENSE.
@@ -27,6 +31,79 @@
#include <bsp.h>
+static int cpu_counter_initialized;
+ * @brief set mode of Cortex-R performance counters
+ * Based on example found on http://stackoverflow.com
+ * @param[in] do_reset if set, values of the counters are reset
+ * @param[in] enable_divider if set, CCNT counts clocks divided by 64
+ * @retval Void
+static inline void _CPU_Counter_init_perfcounters(
+ int32_t do_reset,
+ int32_t enable_divider
+ /* in general enable all counters (including cycle counter) */
+ int32_t value = 1;
+ /* peform reset */
+ if (do_reset)
+ value |= 2; /* reset all counters to zero */
+ value |= 4; /* reset cycle counter to zero */
+ if (enable_divider)
+ value |= 8; /* enable "by 64" divider for CCNT */
+ value |= 16;
+ /* program the performance-counter control-register */
+ asm volatile ("mcr p15, 0, %0, c9, c12, 0\t\n" :: "r"(value));
+ /* enable all counters */
+ asm volatile ("mcr p15, 0, %0, c9, c12, 1\t\n" :: "r"(0x8000000f));
+ /* clear overflows */
+ asm volatile ("mcr p15, 0, %0, c9, c12, 3\t\n" :: "r"(0x8000000f));
+ * @brief initialize Cortex-R performance counters subsystem
+ * @retval Void
+static void _CPU_Counter_initialize(void)
+ rtems_interrupt_level level;
+ rtems_interrupt_disable(level);
+ if ( cpu_counter_initialized ) {
+ rtems_interrupt_enable(level);
+ return;
+ /* enable user-mode access to the performance counter */
+ asm volatile ("mcr p15, 0, %0, c9, c14, 0\n\t" :: "r"(1));
+ /* disable counter overflow interrupts (just in case) */
+ asm volatile ("mcr p15, 0, %0, c9, c14, 2\n\t" :: "r"(0x8000000f));
+ _CPU_Counter_init_perfcounters(false, false);
+ cpu_counter_initialized = 1;
* @brief returns the actual value of Cortex-R cycle counter register
@@ -39,6 +116,9 @@
CPU_Counter_ticks _CPU_Counter_read(void)
uint32_t ticks;
+ if ( !cpu_counter_initialized ) {
+ _CPU_Counter_initialize();
asm volatile ("mrc p15, 0, %0, c9, c13, 0\n": "=r" (ticks));
return ticks;
1.9.1
