[PATCH] arinc653 support for virtualpok bsp
JustJanek
janekvoirschot at gmail.com
Sun Aug 24 01:26:25 UTC 2014
c/src/lib/libbsp/i386/virtualpok/Makefile.am | 18 +-
c/src/lib/libbsp/i386/virtualpok/arinc653_readme | 72 +++++++
.../lib/libbsp/i386/virtualpok/startup/bspstart.c | 4 +-
testsuites/samples/hello/init.c | 210 ++++++++++++++++++++-
4 files changed, 297 insertions(+), 7 deletions(-)
create mode 100644 c/src/lib/libbsp/i386/virtualpok/arinc653_readme
diff --git a/c/src/lib/libbsp/i386/virtualpok/Makefile.am b/c/src/lib/libbsp/i386/virtualpok/Makefile.am
index c65a002..c2e0b18 100644
--- a/c/src/lib/libbsp/i386/virtualpok/Makefile.am
+++ b/c/src/lib/libbsp/i386/virtualpok/Makefile.am
@@ -6,6 +6,7 @@ include $(top_srcdir)/../../../../automake/compile.am
include $(top_srcdir)/../../bsp.am
include_bspdir = $(includedir)/bsp
+include_arinc653dir = $(includedir)/arinc653
dist_project_lib_DATA = bsp_specs
@@ -19,6 +20,19 @@ nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
DISTCLEANFILES = include/bspopts.h
noinst_PROGRAMS =
+include_arinc653_HEADERS = $(POK_PATH)/libpok/include/arinc653/types.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/process.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/partition.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/blackboard.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/time.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/buffer.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/error.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/event.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/queueing.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/sampling.h
+include_arinc653_HEADERS += $(POK_PATH)/libpok/include/arinc653/semaphore.h
include_bsp_HEADERS = irq/irq.h
include_bsp_HEADERS += ../../shared/include/irq-generic.h
#include_bsp_HEADERS +=
@@ -70,8 +84,10 @@ libpokpart.a :
ar t libpart.a > libpart.list
sed -e "s/\.lo/\.o/g" libpart.list > libpart.o.list
ar x libpart.a
- rename .lo .o `cat libpart.list`
+# rename .lo .o `cat libpart.list`
+ cat libpart.list | rename 's/.lo/.o/g'
ar q libbsp.a `cat libpart.o.list`
+ sed -i '/#include <types.h>/d' ../../../../../../virtualpok/lib/include/arinc653/types.h
# ar cru libpokpart.a `cat libpart.o.list`
# rm `cat libpart.o.list` is optional as all files get overwritten with new
# ones by 'ar x'. But I think it's bad style to remove object files during
diff --git a/c/src/lib/libbsp/i386/virtualpok/arinc653_readme b/c/src/lib/libbsp/i386/virtualpok/arinc653_readme
new file mode 100644
index 0000000..ac82873
--- /dev/null
+++ b/c/src/lib/libbsp/i386/virtualpok/arinc653_readme
@@ -0,0 +1,72 @@
+Guide to get POK's arinc653 calls working on RTEMS.
+This guide will go through the steps that are necessary to get arinc653 calls
+from POK working on an RTEMS partition and to be able to run an example project
+that goes through at least one arinc653 call of each arinc653 subset (buffer,
+blackboard, partition, time etc.). As this guide won't go into detail
+please refer to either the arinc653 wiki on RTEMS wiki
+(http://www.rtems.org/wiki/index.php/Main_Page) or to justjnk.blogspot.nl for
+more details.
+Note: Make sure your environment can at least run the default "hello world" for
+RTEMS on POK (i.e. the patches for virtualpok are applied to your RTEMS
+directory).
+1. Apply the patch arinc653 patch to your rtems environment and the
+pok patches to your pok environment.
+2. Go to $POK and make sure the POK_PATH environment variable is set to the folder
+of your $POK directory.
+3. Go to $POK/examples/rtems-guest and use the command 'make'. A new folder
+named generated-code/ should either be added (if it wasn't there yet). Add the
+following macros to $POK/examples/rtems-guest/generated-code/cpu/part1/deployment.h
+Note: Compilation will most likely fail due to an error with 'C_dispatch_isr'. This
+is okay, you can continue the steps of this guide.
+#define POK_CONFIG_NB_BLACKBOARDS 2
+#define POK_CONFIG_NB_BUFFERS 2
+#define POK_CONFIG_ARINC653_NB_SEMAPHORES 2
+#define POK_CONFIG_NB_EVENTS 2
+#define POK_CONFIG_ARINC653_NB_EVENTS 2
+#define POK_NEEDS_BLACKBOARDS 1
+#define POK_NEEDS_ARINC653_BLACKBOARD 1
+#define POK_NEEDS_BUFFER 1
+#define POK_NEEDS_ARINC653_BUFFER 1
+#define POK_NEEDS_ARINC653_EVENT 1
+#define POK_NEEDS_ARINC653_ERROR 1
+#define POK_NEEDS_ARINC653_QUEUEING 1
+#define POK_NEEDS_ARINC653_SAMPLING 1
+#define POK_NEEDS_ARINC653_SEMAPHORE 1
+4. Go to $POK/examples/rtems-guest/generated-code and run the command 'make all'
+Note: Similar to step 3, this will throw an error about 'C_dispatch_isr'. You can
+continue the steps in this guide.
+5. Copy-paste $POK/examples/rtems-guest/generated-code/cpu/part1/libpart.a to
+$RTEMS/c/src/lib/libbsp/i386/virtualpok.
+6. Use './bootstrap -p' at your rtems directory's root.
+7. Build RTEMS with the following configuration line:
+--target=i386-rtems4.11 --enable-rtemsbsp=virtualpok --enable-paravirt
+--disable-cxx --disable-networking --disable-posix --enable-maintainter-mode
+--enable-tests --disable-multiprocessing USE_COM1_AS_CONSOLE=1
+BSP_PRESS_KEY_FOR_RESET=0
+For example:
+mkdir pc386_arinc653
+cd pc386_arinc653
+$RTEMS/configure --target=i386-rtems4.11 --enable-rtemsbsp=virtualpok
+ --enable-paravirt --disable-cxx --disable-networking --disable-posix
+ --enable-maintainter-mode --enable-tests --disable-multiprocessing
+ USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
+8. Copy-paste <build_dir>/i386-rtems4.11/c/virtualpok/testsuites/samples/hello/hello.exe
+to $POK/examples/rtems-guest
+9. go to $POK/examples/rtems-guest and run "./copy_rebuild_kernel.sh hello.exe"
+10. If everything went well you can now run "make run" in $POK/examples/rtems-guest
+and the arinc653 calls example will run.
diff --git a/c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c b/c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
index 3464ee0..6b0686e 100644
--- a/c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
+++ b/c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
@@ -34,8 +34,8 @@ void bsp_start( void )
_BSP_Virtual_Char_write( "Hello RTEMS World\n" );
// Initialize IRQ management
- rtems_irq_mngt_init();
+ //rtems_irq_mngt_init();
// Register clock driver
- Clock_driver_install_handler();
+ //Clock_driver_install_handler();
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index d8fe450..de9329d 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -11,15 +11,47 @@
#include "config.h"
#endif
+#define POK_NEEDS_ARINC653_PARTITION 1
+#define POK_NEEDS_ARINC653_PROCESS 1
+#define POK_NEEDS_ARINC653_TIME 1
#include <rtems/test.h>
#include <bsp.h> /* for device driver prototypes */
+#include <arinc653/types.h>
+#include <arinc653/partition.h>
+#include <arinc653/process.h>
+#include <arinc653/time.h>
+#include <arinc653/error.h>
+#include <arinc653/blackboard.h>
+#include <arinc653/buffer.h>
+#include <arinc653/event.h>
+#include <arinc653/semaphore.h>
+#include <arinc653/sampling.h>
+#include <arinc653/queueing.h>
/* forward declarations to avoid warnings */
rtems_task Init(rtems_task_argument argument);
+void arinc653_test_partition(void);
+void arinc653_test_process(void);
+void arinc653_test_time(void);
+void arinc653_test_error(void);
+void arinc653_test_blackboard(void);
+void arinc653_test_buffer(void);
+void arinc653_test_event(void);
+void arinc653_test_semaphore(void);
+void arinc653_test_sampling(void);
+void arinc653_test_queueing(void);
const char rtems_test_name[] = "HELLO WORLD";
@@ -27,12 +59,182 @@ rtems_task Init(
rtems_task_argument ignored
- rtems_test_begin();
- printf( "Hello World\n" );
- rtems_test_end();
- exit( 0 );
+ arinc653_test_partition();
+ arinc653_test_process();
+ arinc653_test_time();
+ arinc653_test_error();
+ arinc653_test_blackboard();
+ arinc653_test_buffer();
+ arinc653_test_event();
+ arinc653_test_semaphore();
+ arinc653_test_sampling();
+ arinc653_test_queueing();
+ exit( 0 );
+void arinc653_test_partition()
+ printf("arinc653_test_partition start\n");
+ PARTITION_STATUS_TYPE partition_status;
+ RETURN_CODE_TYPE ret;
+ GET_PARTITION_STATUS(&partition_status, &ret);
+ printf("OPERATING_MODE_TYPE after GET_PARTITION_STATUS: %d\n", (int)partition_status.OPERATING_MODE);
+ printf("Return after GET_PARTITION_STATUS: %d\n", (int)ret);
+ printf("arinc653_test_partition stop\n\n");
+void arinc653_test_process()
+ printf("arinc653_test_process start\n");
+ PROCESS_ID_TYPE PROCESS_ID;
+ RETURN_CODE_TYPE RETURN_CODE;
+ GET_MY_ID (
+ /*out*/ &PROCESS_ID,
+ /*out*/ &RETURN_CODE );
+ printf("PROCESS_ID after GET_MY_ID: %d\n", (int)PROCESS_ID);
+ printf("RETURN_CODE after GET_MY_ID: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_process stop\n\n");
+void arinc653_test_time()
+ printf("arinc653_test_time start\n");
+ RETURN_CODE_TYPE return_code;
+ PERIODIC_WAIT (
+ /*out*/ &return_code );
+ printf("return_code after PERIODIC_WAIT: %d\n", (int)return_code);
+ printf("arinc653_test_time stop\n\n");
+void arinc653_test_error()
+ printf("arinc653_test_error start\n");
+ ERROR_STATUS_TYPE ERROR_STATUS;
+ GET_ERROR_STATUS (&ERROR_STATUS,
+ &RETURN_CODE);
+ printf("ERROR_STATUS.ERROR_CODE after GET_ERROR_STATUS: %d\n", (int)ERROR_STATUS.ERROR_CODE);
+ printf("RETURN_CODE after GET_ERROR_STATUS: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_error stop\n\n");
+void arinc653_test_blackboard()
+ printf("arinc653_test_blackboard start\n");
+ BLACKBOARD_ID_TYPE BLACKBOARD_ID;
+ CREATE_BLACKBOARD (
+ /*in */ "RTEMS_arinc_blackboard",
+ /*in */ 5,
+ /*out*/ &BLACKBOARD_ID,
+ printf("BLACKBOARD_ID after CREATE_BLACKBOARD: %d\n", (int)BLACKBOARD_ID);
+ printf("RETURN_CODE after CREATE_BLACKBOARD: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_blackboard stop\n\n");
+void arinc653_test_buffer()
+ printf("arinc653_test_buffer start\n");
+ BUFFER_ID_TYPE BUFFER_ID;
+ CREATE_BUFFER (
+ /*in */ "RTEMS_arinc_buffer",
+ /*in */ 5,
+ /*in */ 4,
+ /*in */ FIFO,
+ /*out*/ &BUFFER_ID,
+ printf("BUFFER_ID after CREATE_BUFFER: %d\n", (int)BUFFER_ID);
+ printf("RETURN_CODE after CREATE_BUFFER: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_buffer stop\n\n");
+void arinc653_test_event()
+ printf("arinc653_test_event start\n");
+ EVENT_ID_TYPE EVENT_ID;
+ CREATE_EVENT (
+ /*IN */ "RTEMS_arinc_event",
+ /*OUT*/ &EVENT_ID,
+ /*OUT*/ &RETURN_CODE );
+ printf("EVENT_ID after CREATE_EVENT: %d\n", (int)EVENT_ID);
+ printf("RETURN_CODE after CREATE_EVENT: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_event stop\n\n");
+void arinc653_test_semaphore()
+ printf("arinc653_test_semaphore start\n");
+ SEMAPHORE_ID_TYPE SEMAPHORE_ID;
+ CREATE_SEMAPHORE (
+ /*IN */ "RTEMS_arinc_sem",
+ /*IN */ 1,
+ /*IN */ 4,
+ /*IN */ FIFO,
+ /*OUT*/ &SEMAPHORE_ID,
+ printf("SEMAPHORE_ID after CREATE_SEMAPHORE: %d\n", (int)SEMAPHORE_ID);
+ printf("RETURN_CODE after CREATE_SEMAPHORE: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_semaphore stop\n\n");
+void arinc653_test_sampling()
+ printf("arinc653_test_sampling start\n");
+ SAMPLING_PORT_ID_TYPE SAMPLING_PORT_ID;
+ CREATE_SAMPLING_PORT (
+ /*in */ "RTEMS_arinc_sampling",
+ /*in */ 5,
+ /*in */ SOURCE,
+ /*in */ 5000,
+ /*out*/ &SAMPLING_PORT_ID,
+ printf("SAMPLING_PORT_ID after CREATE_SAMPLING_PORT: %d\n", (int)SAMPLING_PORT_ID);
+ printf("RETURN_CODE after CREATE_SAMPLING_PORT: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_sampling stop\n\n");
+void arinc653_test_queueing()
+ printf("arinc653_test_queueing start\n");
+ QUEUING_PORT_ID_TYPE QUEUING_PORT_ID;
+ CREATE_QUEUING_PORT (
+ /*in */ "RTEMS_arinc_queueing",
+ /*in */ 5,
+ /*in */ 3,
+ /*in */ SOURCE,
+ /*in */ FIFO,
+ /*out*/ &QUEUING_PORT_ID,
+ printf("QUEUING_PORT_ID after CREATE_QUEUING_PORT: %d\n", (int)QUEUING_PORT_ID);
+ printf("RETURN_CODE after CREATE_QUEUING_PORT: %d\n", (int)RETURN_CODE);
+ printf("arinc653_test_queueing stop\n\n");
/* NOTICE: the clock driver is explicitly disabled */
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
1.9.1
