[PATCH 2/2] rtems: Add more clock tick functions
Sun Aug 24 08:54:15 UTC 2014
On 08/22/2014 10:14 PM, Pavel Pisa wrote:
>>> +RTEMS_INLINE_ROUTINE bool rtems_clock_ticks_before(
>>> > >+  rtems_interval ticks
>>> > >+  return ( (int32_t) ticks - (int32_t) _Watchdog_Ticks_since_boot ) > 0;
>> >Why not just return _Watchdog_Ticks_since_boot < ticks;
Yes, this doesn't work if the counter overflows.
> For sure not, to have correctly working overflow arithmetics
> it is required to use subtraction of unsigned types and then
> to limit result to signed type of same size.
> Overflow of subtraction of signed types is undefined according
> to the C standard. The implementation causing exception is correct
> but seldom used (can be enabled for MIPS on GCC). But comparison
> is often optimized. So for example next code
Conversion of too large unsigned integers to singed integers is also
undefined.  I assume two's complement arithmetic here.
> int fnc(int32_t x)
>    if ((x + 0x7fffffff) < -0x10000000) {
>      return 1;
>    } else {
>      return 0;
> can be legally optimized to
> int fnc(int32_t x)
>    return 0;
> because for any valid x number <-0x80000000;0x7fffffff>
> arithmetic value of the sum cannot be smaller than -1.
> And this kind of optimization is seen in reality.
> So even Sebastian's above code which tries to prevent
> overflow case can be misoptimized and broken.
> Correct is
>    return ( (int32_t) ( (uint32_t) ticks - (uint32_t) _Watchdog_Ticks_since_boot ) ) > 0;
This version works also with two's complement arithmetic.  I don't think
the compiler can optimize my version in the same way as your example,
since _Watchdog_Ticks_since_boot is a global volatile variable.  Linux
uses the same approach for time_before().
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
