[PATCH 2/2] rtems: Add more clock tick functions
Sun Aug 24 08:57:43 UTC 2014
On 08/24/2014 05:02 AM, Chris Johns wrote:
> On 23/08/2014 1:12 am, Sebastian Huber wrote:
>> Add rtems_clock_ticks_later(), rtems_clock_ticks_later_us() and
>> rtems_clock_ticks_later_us().
>> FIXME: Patch is incomplete.  Documentation and tests are missing.  Just
>> for API review.
>>   cpukit/rtems/include/rtems/rtems/clock.h | 66
>>   1 file changed, 66 insertions(+)
>> diff --git a/cpukit/rtems/include/rtems/rtems/clock.h
>> b/cpukit/rtems/include/rtems/rtems/clock.h
>> index ff71665..cee930e 100644
>> --- a/cpukit/rtems/include/rtems/rtems/clock.h
>> +++ b/cpukit/rtems/include/rtems/rtems/clock.h
>> @@ -34,6 +34,7 @@
>>   #include <rtems/score/tod.h>
>>   #include <rtems/rtems/status.h>
>>   #include <rtems/rtems/types.h>
>> +#include <rtems/config.h>
>>   #include <sys/time.h> /* struct timeval */
>> @@ -160,6 +161,71 @@ RTEMS_INLINE_ROUTINE rtems_interval
>> rtems_clock_get_ticks_since_boot(void)
>> + * @brief Returns the ticks counter value delta ticks in the future.
>> + * @param[in] delta The ticks delta value.
>> + * @return The tick counter value delta ticks in the future.
>> +RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_ticks_later(
>> +  rtems_interval delta
>> +  return _Watchdog_Ticks_since_boot + delta;
>> + * @brief Returns the ticks counter value at least delta
>> microseconds in the
>> + * future.
>> + * @param[in] delta The delta value in microseconds.
>> + * @return The tick counter value at least delta microseconds in the
>> future.
>> +RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_ticks_later_us(
> This should be rtems_clock_ticks_later_usec. When I first saw this I
> though it meant 'us' as in 'you and me'.
Ok.
> The calls names make sense from a programming point of view but from a
> user point of view they are sort of forwards and backwards. For
> example rtems_clock_ticks_later_us is the "the clock tick so many
> micro-seconds later where later implies now" or
> 'rtems_clock_tick_usecs_later' and following this I suppose
> 'rtems_clock_ticks_later' becomes 'rtems_clock_tick_ticks_later' ?
What about rtems_clock_tick_later() and rtems_clock_tick_before()? In
the context it should be clear what they do, e.g.
+ * @code
+ * status busy( void )
+ *   rtems_interval timeout = rtems_clock_tick_later_usec( 10000 );
+ *   do {
+ *     if ( ok() ) {
+ *       return success;
+ *   } while ( rtems_clock_tick_before( timeout ) );
+ *   return timeout;
+ * @endcode
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
