[PATCH] score: Define _CPU_Start_multitasking only for LEON SPARC, not SPARC in general
Mon Aug 25 10:10:46 UTC 2014
On 25/08/14 11:45, Daniel Cederman wrote:
>   cpukit/score/cpu/sparc/rtems/score/cpu.h |    2 ++
>   1 file changed, 2 insertions(+)
> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> index 9c38b55..d4c2ef0 100644
> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
> @@ -1203,9 +1203,11 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
>     void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
> +  #if defined(__leon__)
>     void _BSP_Start_multitasking( Context_Control *heir )
>       RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
>     #define _CPU_Start_multitasking _BSP_Start_multitasking
> +  #endif
In case it is LEON specific, then it should have a LEON specific name.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
