[PATCH V2] score: Define _CPU_Start_multitasking only for LEON SPARC, not SPARC in general
Daniel Cederman
cederman at gaisler.com
Mon Aug 25 10:59:34 UTC 2014
Rename _BSP_Start_multitasking to _LEON3_Start_multitasking to show that
it is LEON specific
c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c | 2 +-
cpukit/score/cpu/sparc/rtems/score/cpu.h | 6 ++++--
2 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c b/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
index 9166ad5..b7c347e 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c
@@ -82,7 +82,7 @@ void _CPU_SMP_Send_interrupt(uint32_t target_processor_index)
LEON3_IrqCtrl_Regs->force[target_processor_index] = 1 << LEON3_MP_IRQ;
-void _BSP_Start_multitasking(
+void _LEON3_Start_multitasking(
Context_Control *heir
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 9c38b55..e44ab71 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1203,9 +1203,11 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
- void _BSP_Start_multitasking( Context_Control *heir )
+ #if defined(__leon__)
+ void _LEON3_Start_multitasking( Context_Control *heir )
RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
- #define _CPU_Start_multitasking _BSP_Start_multitasking
+ #define _CPU_Start_multitasking _LEON3_Start_multitasking
+ #endif
static inline void _CPU_SMP_Processor_event_broadcast( void )
1.7.9.5
