Using rtl-host in covor - some questions
Krzysztof Mięsowicz
krzysztof.miesowicz at gmail.com
Mon Aug 25 11:17:16 UTC 2014
2014-08-24 5:32 GMT+02:00 Chris Johns <chrisj at rtems.org>:
> On 23/08/2014 2:54 pm, Krzysztof Mięsowicz wrote:
>> Where should I place this image? Is there any RTEMS ftp or something
>> like this where could I put it, or maybe should I just push it to some
>> Dropbox or sth and download it with RSB?
> There is ftp.rtems.org and that is where the image can be placed. Maybe a
> binary under rtems-tools.git. I am not sure.
> I need to add something like '%fetch' to the RSB to allow a configuration
> file the ability to do this.
A binary under rtems-tools repo is probably simpler for now - it could be
placed in the same directory as other coverage-related files from
rtems-testing repo like some css files, and configuration file introduced
by me.
> Chris, should I move rtl-host repo into rtems-tools or wait for your
>> action?
> There are a couple if issues to resolve. First is how to merge the commit
> history from the rtl-host repo into the rtems-tools repo. I would like the
> commit history to be present so the history of who has worked on the code
> is maintained. Second, what is the structure in the rtems-tools repo and
> how to we integrate the various bits under a waf build tree ?
About the structure - on my PC I copied rtl-host directory just into
rtems-tools directory, so tree output is as follows:
rtems-tools
├── doc
│ ├── asciidoc
│ └── images
├── rtemstoolkit
├── rtl-host
│ ├── build-linux2
│ ├── elftoolchain
│ ├── libiberty
│ ├── waf-tools
│ └── win32
├── tester
│ ├── config
│ ├── covoar
│ ├── rt
│ └── rtems
└── tools
├── 4.10
├── 4.11
├── 4.9
└── libffi
Then, I was able to point from covoar/wscript to rtl-host/build-linux2 dir
where librld.a is placed, and link with this library. I think this is not
perfect solution, because rtl-host must be built independently before
covoar - but it works for now. You can find diff for covoar wscript
attached.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140825/63a0155c/attachment.html>
diff --git a/tester/covoar/wscript b/tester/covoar/wscript
index 88add6e..8cb33bf 100644
--- a/tester/covoar/wscript
+++ b/tester/covoar/wscript
@@ -46,6 +46,16 @@ APPNAME='covoar'
top = '.'
out = 'build'
+# Paths to rtl-host
+rtl_host_build_dir = "./../../rtl-host/build-linux2"
+rtl_host_dir = "./../../rtl-host"
+rtl_includes = ['../../rtl-host',
+ '../../rtl-host/elftoolchain/common',
+ '../../rtl-host/elftoolchain/libelf',
+ '../../rtl-host/libiberty']
def options(opt):
opt.load('compiler_cxx')
@@ -54,8 +64,12 @@ def configure(conf):
conf.check_cc(function_name='open64', header_name="stdlib.h", mandatory = False)
conf.check_cc(function_name='stat64', header_name="stdlib.h", mandatory = False)
conf.write_config_header('covoar-config.h')
+ conf.env.STLIBPATH_RLD = conf.path.abspath() + '/../../rtl-host/build-linux2'
+ conf.env.STLIB_RLD = ['rld','iberty','elf']
+ #conf.env.append_value('STLIBPATH', [conf.path.abspath() + '/../../rtl-host/build-linux2'])
def build(bld):
bld.stlib(target = 'ccovoar',
source = ['app_common.cc',
'ConfigFile.cc',
@@ -89,9 +103,15 @@ def build(bld):
'Target_lm32.cc',
'Target_m68k.cc',
'Target_powerpc.cc',
- 'Target_sparc.cc'],
+ 'Target_sparc.cc',
+ 'SymbolSet.cpp',
+ 'SymbolSetReader.cpp'],
cflags = ['-O2', '-g'],
- includes = ['.'])
+ cxxflags = ['-std=c++11', '-O2', '-g'],
+# libpath = rtl_host_build_dir,
+# lib = 'rld',
+ includes = ['.',
+ './symbolGen'] + rtl_includes)
bld.program(target = 'trace-converter',
source = ['TraceConverter.cc',
@@ -106,12 +126,12 @@ def build(bld):
bld.program(target = 'covoar',
source = ['covoar.cc'],
- use = 'ccovoar',
+ use = ['ccovoar','RLD'],
includes = ['.'])
- use = 'ccovoar',
includes = ['.'])
