[PATCH] score: Define _CPU_Start_multitasking only for LEON SPARC, not SPARC in general
Mon Aug 25 16:44:21 UTC 2014
On 08/25/2014 05:04 PM, Joel Sherrill wrote:
> On 8/25/2014 5:10 AM, Sebastian Huber wrote:
>> On 25/08/14 11:45, Daniel Cederman wrote:
>>>    cpukit/score/cpu/sparc/rtems/score/cpu.h |    2 ++
>>>    1 file changed, 2 insertions(+)
>>> diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>>> index 9c38b55..d4c2ef0 100644
>>> --- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
>>> +++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
>>> @@ -1203,9 +1203,11 @@ register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
>>>      void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
>>> +  #if defined(__leon__)
>>>      void _BSP_Start_multitasking( Context_Control *heir )
>>>        RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
>>>      #define _CPU_Start_multitasking _BSP_Start_multitasking
>>> +  #endif
>> In case it is LEON specific, then it should have a LEON specific name.
> What's the overall rationale?
If its mandated by the CPU port, e.g. all the stuff defined by
no_cpu/cpu.h, then it should be _CPU_*.  In case all BSPs of a CPU port
must implement a CPU port function, then it is _BSP_*.  In case only
certain multilib variants implement it specifically, then they should
have an appropriate multilib specific prefix, e.g. _LEON3_* or
_ARMV7M_*.  Does this make sense?  Maybe we should add this stuff to the
CPU supplement.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
