[PATCH 1/5] sptests/spcache01: Make inline assembly conditional to account for OpenRISC l.nop instruction.
Hesham Moustafa heshamelmatary at gmail.com
Tue Aug 26 13:53:00 UTC 2014
Hi,
On Mon, Aug 25, 2014 at 6:15 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I pushed all of this set and will be testing soon.
Great, Thanks!
> Can you post your simulator configuration file?
Here it's https://github.com/heshamelmatary/or1k-rtems/blob/master/sim.cfg
Should I include it part of the or1ksim BSP directory (or anywhere else)?
> --joel
> On 8/22/2014 3:20 PM, Hesham ALMatary wrote:
>>  testsuites/sptests/spcache01/init.c | 6 +++++-
>>  1 file changed, 5 insertions(+), 1 deletion(-)
>> diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
>> index 2c9d184..ad9b54f 100644
>> --- a/testsuites/sptests/spcache01/init.c
>> +++ b/testsuites/sptests/spcache01/init.c
>> @@ -27,7 +27,11 @@
>>  const char rtems_test_name[] = "SPCACHE 1";
>> -#define I() __asm__ volatile ("nop")
>> +#ifdef __or1k__
>> +  #define I() __asm__ volatile ("l.nop")
>> +#else
>> +  #define I() __asm__ volatile ("nop")
>> +#endif
>>  #define I8() I(); I(); I(); I(); I(); I(); I(); I()
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
