[PATCH 1/5] sptests/spcache01: Make inline assembly conditional to account for OpenRISC l.nop instruction.
Tue Aug 26 14:09:12 UTC 2014
On 8/26/2014 8:53 AM, Hesham Moustafa wrote:
> Hi,
> On Mon, Aug 25, 2014 at 6:15 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> I pushed all of this set and will be testing soon.
> Great, Thanks!
No problem. We know this is a work in progress and it is better to
keep the delta small as progress is made.
>> Can you post your simulator configuration file?
> Here it's https://github.com/heshamelmatary/or1k-rtems/blob/master/sim.cfg
> Should I include it part of the or1ksim BSP directory (or anywhere else)?
In the BSP Readme would be great.  We really need the simulator run
scripts to
support this simulator. That also captures the information.
+ rtems-testing/sim-scripts
+ rtems-tools/tester
I don't expect it to be hard to add to both once the or1ksim is built by
the RSB.
FWIW that's what I am waiting for to help debug/test if that gives you
incentive. :)
--joel
>> --joel
>> On 8/22/2014 3:20 PM, Hesham ALMatary wrote:
>>>  testsuites/sptests/spcache01/init.c | 6 +++++-
>>>  1 file changed, 5 insertions(+), 1 deletion(-)
>>> diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
>>> index 2c9d184..ad9b54f 100644
>>> --- a/testsuites/sptests/spcache01/init.c
>>> +++ b/testsuites/sptests/spcache01/init.c
>>> @@ -27,7 +27,11 @@
>>>  const char rtems_test_name[] = "SPCACHE 1";
>>> -#define I() __asm__ volatile ("nop")
>>> +#ifdef __or1k__
>>> +  #define I() __asm__ volatile ("l.nop")
>>> +#else
>>> +  #define I() __asm__ volatile ("nop")
>>> +#endif
>>>  #define I8() I(); I(); I(); I(); I(); I(); I(); I()
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
