[PATCH 1/5] sptests/spcache01: Make inline assembly conditional to account for OpenRISC l.nop instruction.
Hesham Moustafa heshamelmatary at gmail.com
Tue Aug 26 14:38:15 UTC 2014
On Tue, Aug 26, 2014 at 4:09 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 8/26/2014 8:53 AM, Hesham Moustafa wrote:
>> Hi,
>> On Mon, Aug 25, 2014 at 6:15 PM, Joel Sherrill
>>> I pushed all of this set and will be testing soon.
>> Great, Thanks!
> No problem. We know this is a work in progress and it is better to
> keep the delta small as progress is made.
>>> Can you post your simulator configuration file?
>> Here it's https://github.com/heshamelmatary/or1k-rtems/blob/master/sim.cfg
>> Should I include it part of the or1ksim BSP directory (or anywhere else)?
> In the BSP Readme would be great.  We really need the simulator run
> scripts to
> support this simulator. That also captures the information.
The whole configuration file (sim.cfg) content into README?
> + rtems-testing/sim-scripts
I can start with this one, would it make sense to make the or1ksim
script creates a sim.cfg file (with parameterized configurations)?
> + rtems-tools/tester
> I don't expect it to be hard to add to both once the or1ksim is built by
> the RSB.
> FWIW that's what I am waiting for to help debug/test if that gives you
> incentive. :)
> --joel
>>> --joel
>>> On 8/22/2014 3:20 PM, Hesham ALMatary wrote:
>>>>  testsuites/sptests/spcache01/init.c | 6 +++++-
>>>>  1 file changed, 5 insertions(+), 1 deletion(-)
>>>> diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
>>>> index 2c9d184..ad9b54f 100644
>>>> --- a/testsuites/sptests/spcache01/init.c
>>>> +++ b/testsuites/sptests/spcache01/init.c
>>>> @@ -27,7 +27,11 @@
>>>>  const char rtems_test_name[] = "SPCACHE 1";
>>>> -#define I() __asm__ volatile ("nop")
>>>> +#ifdef __or1k__
>>>> +  #define I() __asm__ volatile ("l.nop")
>>>> +#else
>>>> +  #define I() __asm__ volatile ("nop")
>>>> +#endif
>>>>  #define I8() I(); I(); I(); I(); I(); I(); I(); I()
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
