[PATCH] sim-scripts: Add new or1ksim OpenRISC simulator script.
Hesham ALMatary heshamelmatary at gmail.com
Tue Aug 26 17:50:09 UTC 2014
 sim-scripts/or1ksim.in | 155 +++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 155 insertions(+)
 create mode 100644 sim-scripts/or1ksim.in
diff --git a/sim-scripts/or1ksim.in b/sim-scripts/or1ksim.in
new file mode 100644
index 0000000..3f59e47
--- /dev/null
+++ b/sim-scripts/or1ksim.in
@@ -0,0 +1,155 @@
+#  or1k/or1ksim Support
+bspSupportsGDBServerMode="yes"
+runBSP=or32-elf-sim
+bspTreeFile=sim.cfg
+runARGS()
+  echo "-f ${bspTreeFile} ${1}"
+checkBSPFaults()
+  return 0
+bspLimit()
+  testname=$1
+  case ${testname} in
+    *stackchk*)limit=5 ;;
+    *fatal*)   limit=1 ;;
+    *minimum*) limit=1 ;;
+    *psxtime*) limit=180 ;;
+    *)         limit=60 ;;
+  esac
+  echo ${limit}
+bspGeneratesGDBCommands="yes"
+gdbServerARGS()
+  echo "-c ${bspTreeFile}"
+bspGenerateGDBCommands()
+cat <<EOF
+tar remote :50001
+EOF
+### Generate the or1ksim device tree based upon the type of application being run
+bspGenerateDeviceTree()
+cat <<EOF
+section memory
+  name     =      "RAM"
+  random_seed = 12345
+  type        = random
+  ce       =          0
+  mc       =          0
+  baseaddr = 0x00000000
+  size     = 0x08000000
+  delayr   =          1
+  delayw   =          2
+end
+section immu
+  enabled = 0
+  nsets = 64
+  nways = 1
+  pagesize = 8192
+  hitdelay = 0
+  missdelay = 0
+end
+section dmmu
+  enabled = 0
+  nsets = 64
+  nways = 1
+  pagesize = 8192
+  hitdelay = 0
+  missdelay = 0
+end
+section mc
+  enabled = 0
+  baseaddr = 0x90000000
+  POC = 0x0000000a                 /* 32 bit SSRAM */
+  index = 0
+end
+section ic
+  enabled   =   0
+  nsets     = 256
+  nways     =   1
+  blocksize =  16
+  hitdelay  =  20
+  missdelay =  20
+end
+section dc
+  enabled = 0
+  nsets = 256
+  nways = 1
+  blocksize = 16
+  load_hitdelay = 0
+  load_missdelay = 0
+  store_hitdelay = 0
+  store_missdelay = 0
+end
+section pic
+  enabled = 1
+  edge_trigger = 1
+end
+section sim
+  verbose  =  1
+  debug    =  0
+  profile  =  0
+  history  =  0
+  clkcycle = 10ns		/* 100MHz clock */
+end
+section VAPI
+  enabled = 1
+  server_port = 50000
+  log_enabled = 1
+  vapi_log_file = "vapi.log"
+end
+section cpu
+  ver = 0x12
+  cfg = 0x00
+  rev = 0x0001
+  superscalar = 0
+  hazards = 0
+  dependstats = 0
+  sbuf_len = 100
+end
+section debug
+ enabled = 1
+ rsp_enabled = 1
+ rsp_port = 50001
+end
+section uart
+  enabled  = 1
+  #channel = "xterm"
+  channel = "file:uart0.rx,uart0.tx"
+  irq = 2
+  16550    = 1
+end
+section pm
+  enabled = 1
+end
+EOF
+bspGeneratesDeviceTree="yes"
1.9.3
