[PATCH] sim-scripts: Add new or1ksim OpenRISC simulator script.
Hesham Moustafa heshamelmatary at gmail.com
Tue Aug 26 18:00:51 UTC 2014
Hi,
The first patch did not include the Makefile modifications, the
previous reply did.
Thanks,
Hesham
On Tue, Aug 26, 2014 at 7:59 PM, Hesham ALMatary
<heshamelmatary at gmail.com> wrote:
>  sim-scripts/Makefile   |   5 +-
>  sim-scripts/or1ksim.in | 155 +++++++++++++++++++++++++++++++++++++++++++++++++
>  2 files changed, 159 insertions(+), 1 deletion(-)
>  create mode 100644 sim-scripts/or1ksim.in
> diff --git a/sim-scripts/Makefile b/sim-scripts/Makefile
> index 9d9baaf..e45feae 100644
> --- a/sim-scripts/Makefile
> +++ b/sim-scripts/Makefile
> @@ -1,6 +1,6 @@
>  INSTALL_DIR=../bin
>  GDBSIM_SCRIPTS=bf537Stamp ezkit533 gdbarmsim h8sim jmr3904 lm32_evr \
> -  m32csim m32rsim psim sis simsh v850sim
> +  m32csim m32rsim or1ksim psim sis simsh v850sim
>  SKYEYE_SCRIPTS=ant5206 bf537Stamp-skyeye csb337 csb350 csb360 edb7312 \
>    ezkit533-skyeye gumstix rtl22xx smdk2410 leon2-skyeye
> @@ -130,6 +130,9 @@ m32csim m32csim-gdb: gdb-sim-run.in gdb-sim.in m32csim.in
>  m32rsim m32rsim-gdb: gdb-sim-run.in gdb-sim.in m32rsim.in
>         ./mkrun yes M32R m32r m32rsim
> +or1ksim or1ksim-gdb: or1ksim.in
> +       ./mkrun yes OR1K or1k or1ksim
>  psim psim-gdb: gdb-sim-run.in gdb-sim.in psim.in
>         ./mkrun yes PowerPC powerpc psim
> diff --git a/sim-scripts/or1ksim.in b/sim-scripts/or1ksim.in
> new file mode 100644
> index 0000000..3f59e47
> --- /dev/null
> +++ b/sim-scripts/or1ksim.in
> @@ -0,0 +1,155 @@
> +#  or1k/or1ksim Support
> +bspSupportsGDBServerMode="yes"
> +runBSP=or32-elf-sim
> +bspTreeFile=sim.cfg
> +runARGS()
> +  echo "-f ${bspTreeFile} ${1}"
> +checkBSPFaults()
> +  return 0
> +bspLimit()
> +  testname=$1
> +  case ${testname} in
> +    *stackchk*)limit=5 ;;
> +    *fatal*)   limit=1 ;;
> +    *minimum*) limit=1 ;;
> +    *psxtime*) limit=180 ;;
> +    *)         limit=60 ;;
> +  esac
> +  echo ${limit}
> +bspGeneratesGDBCommands="yes"
> +gdbServerARGS()
> +  echo "-c ${bspTreeFile}"
> +bspGenerateGDBCommands()
> +cat <<EOF
> +tar remote :50001
> +EOF
> +### Generate the or1ksim device tree based upon the type of application being run
> +bspGenerateDeviceTree()
> +cat <<EOF
> +section memory
> +  name     =      "RAM"
> +  random_seed = 12345
> +  type        = random
> +  ce       =          0
> +  mc       =          0
> +  baseaddr = 0x00000000
> +  size     = 0x08000000
> +  delayr   =          1
> +  delayw   =          2
> +end
> +section immu
> +  enabled = 0
> +  nsets = 64
> +  nways = 1
> +  pagesize = 8192
> +  hitdelay = 0
> +  missdelay = 0
> +end
> +section dmmu
> +  enabled = 0
> +  nsets = 64
> +  nways = 1
> +  pagesize = 8192
> +  hitdelay = 0
> +  missdelay = 0
> +end
> +section mc
> +  enabled = 0
> +  baseaddr = 0x90000000
> +  POC = 0x0000000a                 /* 32 bit SSRAM */
> +  index = 0
> +end
> +section ic
> +  enabled   =   0
> +  nsets     = 256
> +  nways     =   1
> +  blocksize =  16
> +  hitdelay  =  20
> +  missdelay =  20
> +end
> +section dc
> +  enabled = 0
> +  nsets = 256
> +  nways = 1
> +  blocksize = 16
> +  load_hitdelay = 0
> +  load_missdelay = 0
> +  store_hitdelay = 0
> +  store_missdelay = 0
> +end
> +section pic
> +  enabled = 1
> +  edge_trigger = 1
> +end
> +section sim
> +  verbose  =  1
> +  debug    =  0
> +  profile  =  0
> +  history  =  0
> +  clkcycle = 10ns              /* 100MHz clock */
> +end
> +section VAPI
> +  enabled = 1
> +  server_port = 50000
> +  log_enabled = 1
> +  vapi_log_file = "vapi.log"
> +end
> +section cpu
> +  ver = 0x12
> +  cfg = 0x00
> +  rev = 0x0001
> +  superscalar = 0
> +  hazards = 0
> +  dependstats = 0
> +  sbuf_len = 100
> +end
> +section debug
> + enabled = 1
> + rsp_enabled = 1
> + rsp_port = 50001
> +end
> +section uart
> +  enabled  = 1
> +  #channel = "xterm"
> +  channel = "file:uart0.rx,uart0.tx"
> +  irq = 2
> +  16550    = 1
> +end
> +section pm
> +  enabled = 1
> +end
> +EOF
> +bspGeneratesDeviceTree="yes"
> 1.9.3
