[PATCH] sim-scripts: Add new or1ksim OpenRISC simulator script.
Hesham Moustafa heshamelmatary at gmail.com
Tue Aug 26 19:06:49 UTC 2014
Hi,
On Tue, Aug 26, 2014 at 8:47 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> This looks good except that it is missing a comment for the commit.
> Can you add that and resubmit?
Done. Is it Ok to submit the sim.cfg and README change for or1ksim BSP too?
> Thanks.
> On 8/26/2014 12:59 PM, Hesham ALMatary wrote:
>>  sim-scripts/Makefile   |   5 +-
>>  sim-scripts/or1ksim.in | 155 +++++++++++++++++++++++++++++++++++++++++++++++++
>>  2 files changed, 159 insertions(+), 1 deletion(-)
>>  create mode 100644 sim-scripts/or1ksim.in
>> diff --git a/sim-scripts/Makefile b/sim-scripts/Makefile
>> index 9d9baaf..e45feae 100644
>> --- a/sim-scripts/Makefile
>> +++ b/sim-scripts/Makefile
>> @@ -1,6 +1,6 @@
>>  INSTALL_DIR=../bin
>>  GDBSIM_SCRIPTS=bf537Stamp ezkit533 gdbarmsim h8sim jmr3904 lm32_evr \
>> -  m32csim m32rsim psim sis simsh v850sim
>> +  m32csim m32rsim or1ksim psim sis simsh v850sim
>>  SKYEYE_SCRIPTS=ant5206 bf537Stamp-skyeye csb337 csb350 csb360 edb7312 \
>>    ezkit533-skyeye gumstix rtl22xx smdk2410 leon2-skyeye
>> @@ -130,6 +130,9 @@ m32csim m32csim-gdb: gdb-sim-run.in gdb-sim.in m32csim.in
>>  m32rsim m32rsim-gdb: gdb-sim-run.in gdb-sim.in m32rsim.in
>>       ./mkrun yes M32R m32r m32rsim
>> +or1ksim or1ksim-gdb: or1ksim.in
>> +     ./mkrun yes OR1K or1k or1ksim
>>  psim psim-gdb: gdb-sim-run.in gdb-sim.in psim.in
>>       ./mkrun yes PowerPC powerpc psim
>> diff --git a/sim-scripts/or1ksim.in b/sim-scripts/or1ksim.in
>> new file mode 100644
>> index 0000000..3f59e47
>> --- /dev/null
>> +++ b/sim-scripts/or1ksim.in
>> @@ -0,0 +1,155 @@
>> +#  or1k/or1ksim Support
>> +bspSupportsGDBServerMode="yes"
>> +runBSP=or32-elf-sim
>> +bspTreeFile=sim.cfg
>> +runARGS()
>> +  echo "-f ${bspTreeFile} ${1}"
>> +checkBSPFaults()
>> +  return 0
>> +bspLimit()
>> +  testname=$1
>> +  case ${testname} in
>> +    *stackchk*)limit=5 ;;
>> +    *fatal*)   limit=1 ;;
>> +    *minimum*) limit=1 ;;
>> +    *psxtime*) limit=180 ;;
>> +    *)         limit=60 ;;
>> +  esac
>> +  echo ${limit}
>> +bspGeneratesGDBCommands="yes"
>> +gdbServerARGS()
>> +  echo "-c ${bspTreeFile}"
>> +bspGenerateGDBCommands()
>> +cat <<EOF
>> +tar remote :50001
>> +EOF
>> +### Generate the or1ksim device tree based upon the type of application being run
>> +bspGenerateDeviceTree()
>> +cat <<EOF
>> +section memory
>> +  name     =      "RAM"
>> +  random_seed = 12345
>> +  type        = random
>> +  ce       =          0
>> +  mc       =          0
>> +  baseaddr = 0x00000000
>> +  size     = 0x08000000
>> +  delayr   =          1
>> +  delayw   =          2
>> +end
>> +section immu
>> +  enabled = 0
>> +  nsets = 64
>> +  nways = 1
>> +  pagesize = 8192
>> +  hitdelay = 0
>> +  missdelay = 0
>> +end
>> +section dmmu
>> +  enabled = 0
>> +  nsets = 64
>> +  nways = 1
>> +  pagesize = 8192
>> +  hitdelay = 0
>> +  missdelay = 0
>> +end
>> +section mc
>> +  enabled = 0
>> +  baseaddr = 0x90000000
>> +  POC = 0x0000000a                 /* 32 bit SSRAM */
>> +  index = 0
>> +end
>> +section ic
>> +  enabled   =   0
>> +  nsets     = 256
>> +  nways     =   1
>> +  blocksize =  16
>> +  hitdelay  =  20
>> +  missdelay =  20
>> +end
>> +section dc
>> +  enabled = 0
>> +  nsets = 256
>> +  nways = 1
>> +  blocksize = 16
>> +  load_hitdelay = 0
>> +  load_missdelay = 0
>> +  store_hitdelay = 0
>> +  store_missdelay = 0
>> +end
>> +section pic
>> +  enabled = 1
>> +  edge_trigger = 1
>> +end
>> +section sim
>> +  verbose  =  1
>> +  debug    =  0
>> +  profile  =  0
>> +  history  =  0
>> +  clkcycle = 10ns            /* 100MHz clock */
>> +end
>> +section VAPI
>> +  enabled = 1
>> +  server_port = 50000
>> +  log_enabled = 1
>> +  vapi_log_file = "vapi.log"
>> +end
>> +section cpu
>> +  ver = 0x12
>> +  cfg = 0x00
>> +  rev = 0x0001
>> +  superscalar = 0
>> +  hazards = 0
>> +  dependstats = 0
>> +  sbuf_len = 100
>> +end
>> +section debug
>> + enabled = 1
>> + rsp_enabled = 1
>> + rsp_port = 50001
>> +end
>> +section uart
>> +  enabled  = 1
>> +  #channel = "xterm"
>> +  channel = "file:uart0.rx,uart0.tx"
>> +  irq = 2
>> +  16550    = 1
>> +end
>> +section pm
>> +  enabled = 1
>> +end
>> +EOF
>> +bspGeneratesDeviceTree="yes"
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
