[PATCH] Add or1ksim (sim.cfg) configuration file and edit README.
Hesham ALMatary
heshamelmatary at gmail.com
Tue Aug 26 19:42:47 UTC 2014
OpenRISC/or1ksim BSP: The new sim.cfg file configures or1ksim emulator with HW
capabilities that the current RTEMS/or1ksim BSP supports.
README: HOWTO run the or1ksim simulator.
c/src/lib/libbsp/or1k/or1ksim/README | 20 ++++++-
c/src/lib/libbsp/or1k/or1ksim/sim.cfg | 104 ++++++++++++++++++++++++++++++++++
2 files changed, 123 insertions(+), 1 deletion(-)
create mode 100644 c/src/lib/libbsp/or1k/or1ksim/sim.cfg
diff --git a/c/src/lib/libbsp/or1k/or1ksim/README b/c/src/lib/libbsp/or1k/or1ksim/README
index 43b4703..dfa3cb1 100644
--- a/c/src/lib/libbsp/or1k/or1ksim/README
+++ b/c/src/lib/libbsp/or1k/or1ksim/README
@@ -14,4 +14,22 @@ Configuration file "sim.cfg" should be provided for complex board
configurations at the current directory (which you run or1ksim from) or at
~/.or1k/
-sim -f sim.cfg hello.exe
+The current sim.cfg file that configures or1ksim emulator to RTEMS/or1ksim BSP
+is at the same directory as this README. You can also use or1ksim script from
+rtems-tools/sim-scripts.
+From command line type:
+sim -f sim.cfg $PATH_TO_RTEMS_EXE
+or (if you use a stable or1ksim release)
+or32-elf-sim -f sim.cfg $PATH_TO_RTEMS_EXE
+from sim-scripts:
+or1ksim $PATH_TO_RTEMS_EXE
+and then attach GDB to or1ksim from another terminal by running
+or1ksim-gdb $PATH_TO_RTEMS_EXE
diff --git a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
new file mode 100644
index 0000000..cfc3d2b
--- /dev/null
+++ b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
@@ -0,0 +1,104 @@
+section memory
+ name = "RAM"
+ random_seed = 12345
+ type = random
+ ce = 0
+ mc = 0
+ baseaddr = 0x00000000
+ size = 0x08000000
+ delayr = 1
+ delayw = 2
+end
+section immu
+ enabled = 0
+ nsets = 64
+ nways = 1
+ pagesize = 8192
+ hitdelay = 0
+ missdelay = 0
+end
+section dmmu
+ enabled = 0
+ nsets = 64
+ nways = 1
+ pagesize = 8192
+ hitdelay = 0
+ missdelay = 0
+end
+section mc
+ enabled = 0
+ baseaddr = 0x90000000
+ POC = 0x0000000a /* 32 bit SSRAM */
+ index = 0
+end
+section ic
+ enabled = 0
+ nsets = 256
+ nways = 1
+ blocksize = 16
+ hitdelay = 20
+ missdelay = 20
+end
+section dc
+ enabled = 0
+ nsets = 256
+ nways = 1
+ blocksize = 16
+ load_hitdelay = 0
+ load_missdelay = 0
+ store_hitdelay = 0
+ store_missdelay = 0
+end
+section pic
+ enabled = 1
+ edge_trigger = 1
+end
+section sim
+ verbose = 1
+ debug = 0
+ profile = 0
+ history = 0
+ clkcycle = 10ns /* 100MHz clock */
+end
+section VAPI
+ enabled = 1
+ server_port = 50000
+ log_enabled = 1
+ vapi_log_file = "vapi.log"
+end
+section cpu
+ ver = 0x12
+ cfg = 0x00
+ rev = 0x0001
+ superscalar = 0
+ hazards = 0
+ dependstats = 0
+ sbuf_len = 100
+end
+section debug
+ enabled = 1
+ rsp_enabled = 1
+ rsp_port = 50001
+end
+section uart
+ enabled = 1
+ #channel = "xterm"
+ channel = "file:uart0.rx,uart0.tx"
+ irq = 2
+ 16550 = 1
+end
+section pm
+ enabled = 1
+end
1.9.3
