[PATCH 2/2] capture01: Add multiple calls of the test so that several create/delete of tasks is called.
Jennifer Averett jennifer.averett at oarcorp.com
Tue Aug 26 20:16:12 UTC 2014
 testsuites/libtests/capture01/init.c   | 33 ++++++++++++++++++++++++---------
 testsuites/libtests/capture01/system.h |  2 +-
 testsuites/libtests/capture01/test1.c  | 10 +++++-----
 3 files changed, 30 insertions(+), 15 deletions(-)
diff --git a/testsuites/libtests/capture01/init.c b/testsuites/libtests/capture01/init.c
index fc06597..fa92cb8 100644
--- a/testsuites/libtests/capture01/init.c
+++ b/testsuites/libtests/capture01/init.c
@@ -113,7 +113,7 @@ static void cwlist ()
-static void ctrace()
+void ctrace()
   rtems_status_code       sc;
   bool                    csv = false;
@@ -159,7 +159,6 @@ static void ctrace()
                  (rec->events >> RTEMS_CAPTURE_CURR_PRIORITY_EVENT) & 0xff,
                  (rec->events >> RTEMS_CAPTURE_EVENT_START),
                  (uint64_t) rec->time);
-      else
         uint32_t event;
         int      e;
@@ -170,12 +169,10 @@ static void ctrace()
           if (event & 1)
+            char name[5];
+            rtems_capture_name_to_string( rec->task->name, 5, name );
             rtems_monitor_dump_id (rtems_capture_task_id (rec->task));
-            fprintf (stdout, " %c%c%c%c",
-                     (char) (rec->task->name >> 24) & 0xff,
-                     (char) (rec->task->name >> 16) & 0xff,
-                     (char) (rec->task->name >> 8) & 0xff,
-                     (char) (rec->task->name >> 0) & 0xff);
+            fprintf (stdout, " %5s", name );
             fprintf (stdout, " %3" PRId32 " %3" PRId32 " %s\n",
                     (rec->events >> RTEMS_CAPTURE_REAL_PRIORITY_EVENT) & 0xff,
@@ -215,7 +212,7 @@ rtems_task Init(
   rtems_task_set_priority(RTEMS_SELF, 20, &old_priority);
   rtems_task_mode(RTEMS_PREEMPT,  RTEMS_PREEMPT_MASK, &old_mode);
-  sc = rtems_capture_open (5000, NULL);
+  sc = rtems_capture_open (5000, 20, NULL);
   ASSERT_SC(sc);
   sc = rtems_capture_watch_ceiling (100);
@@ -242,10 +239,28 @@ rtems_task Init(
   sc = rtems_capture_control (true);
   ASSERT_SC(sc);
-  capture_test_1();
+  capture_test_1(0);
+  ctrace();
+  ctrace();
+  capture_test_1(1);
+  ctrace();
+  capture_test_1(3);
+  ctrace();
+  ctrace();
+  capture_test_1(4);
+  capture_test_1(5);
+  capture_test_1(6);
   ctrace();
   ctrace();
+  ctrace();
+  ctrace();
+  ctrace();
   rtems_test_end();
   exit( 0 );
diff --git a/testsuites/libtests/capture01/system.h b/testsuites/libtests/capture01/system.h
index 62c221f..e586b30 100644
--- a/testsuites/libtests/capture01/system.h
+++ b/testsuites/libtests/capture01/system.h
@@ -20,7 +20,7 @@ rtems_task Init(
   rtems_task_argument argument
-void capture_test_1(void);
+void capture_test_1(int start);
 /* configuration information */
diff --git a/testsuites/libtests/capture01/test1.c b/testsuites/libtests/capture01/test1.c
index 5e334fc..63de241 100644
--- a/testsuites/libtests/capture01/test1.c
+++ b/testsuites/libtests/capture01/test1.c
@@ -109,7 +109,7 @@ capture_CT1c (rtems_task_argument arg)
   rtems_task_delete (RTEMS_SELF);
-void capture_test_1 ()
+void capture_test_1 (int start)
   rtems_name        name;
@@ -121,7 +121,7 @@ void capture_test_1 ()
   capture_CT1b_deleted = 0;
   capture_CT1c_deleted = 0;
-  name = rtems_build_name('C', 'T', 'm', '1');
+  name = rtems_build_name('C', 'T', 'm', '1'+start);
   sc = rtems_semaphore_create (name, 1,
                                RTEMS_PRIORITY | RTEMS_BINARY_SEMAPHORE |
@@ -135,7 +135,7 @@ void capture_test_1 ()
     return;
-  name = rtems_build_name('C', 'T', '1', 'a');
+  name = rtems_build_name('C', 'T', '1'+start, 'a');
   sc = rtems_task_create (name, 102, 2 * 1024,
                           RTEMS_NO_FLOATING_POINT | RTEMS_LOCAL,
@@ -163,7 +163,7 @@ void capture_test_1 ()
   capture_wait (1000);
-  name = rtems_build_name('C', 'T', '1', 'b');
+  name = rtems_build_name('C', 'T', '1'+start, 'b');
   sc = rtems_task_create (name, 101, 2 * 1024,
@@ -193,7 +193,7 @@ void capture_test_1 ()
-  name = rtems_build_name('C', 'T', '1', 'c');
+  name = rtems_build_name('C', 'T', '1'+start, 'c');
   sc = rtems_task_create (name, 100, 2 * 1024,
1.8.1.4
