[PATCH] sim-scripts: Add new or1ksim OpenRISC simulator script.
Tue Aug 26 20:32:09 UTC 2014
This is merged.
You should now be able to run all tests with or1ksim `find . -name "*.exe"`
But you may also want to specify the time limit argument (-l seconds) since
many may not run correctly.
If you know abort/error messages where the simulator reports that the code
barfs but doesn't exit, those can be added.
Next RSB support for or1ksim. :)
And them rtems-tester
--joel
On 8/26/2014 2:09 PM, Joel Sherrill wrote:
> On 8/26/2014 2:06 PM, Hesham Moustafa wrote:
>> Hi,
>> On Tue, Aug 26, 2014 at 8:47 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> This looks good except that it is missing a comment for the commit.
>>> Can you add that and resubmit?
>> Done. Is it Ok to submit the sim.cfg and README change for or1ksim BSP too?
> Yes. and the sim.cfg should be its own file. It is large. :)
>>> Thanks.
>>> On 8/26/2014 12:59 PM, Hesham ALMatary wrote:
>>>>  sim-scripts/Makefile   |   5 +-
>>>>  sim-scripts/or1ksim.in | 155 +++++++++++++++++++++++++++++++++++++++++++++++++
>>>>  2 files changed, 159 insertions(+), 1 deletion(-)
>>>>  create mode 100644 sim-scripts/or1ksim.in
>>>> diff --git a/sim-scripts/Makefile b/sim-scripts/Makefile
>>>> index 9d9baaf..e45feae 100644
>>>> --- a/sim-scripts/Makefile
>>>> +++ b/sim-scripts/Makefile
>>>> @@ -1,6 +1,6 @@
>>>>  INSTALL_DIR=../bin
>>>>  GDBSIM_SCRIPTS=bf537Stamp ezkit533 gdbarmsim h8sim jmr3904 lm32_evr \
>>>> -  m32csim m32rsim psim sis simsh v850sim
>>>> +  m32csim m32rsim or1ksim psim sis simsh v850sim
>>>>  SKYEYE_SCRIPTS=ant5206 bf537Stamp-skyeye csb337 csb350 csb360 edb7312 \
>>>>    ezkit533-skyeye gumstix rtl22xx smdk2410 leon2-skyeye
>>>> @@ -130,6 +130,9 @@ m32csim m32csim-gdb: gdb-sim-run.in gdb-sim.in m32csim.in
>>>>  m32rsim m32rsim-gdb: gdb-sim-run.in gdb-sim.in m32rsim.in
>>>>       ./mkrun yes M32R m32r m32rsim
>>>> +or1ksim or1ksim-gdb: or1ksim.in
>>>> +     ./mkrun yes OR1K or1k or1ksim
>>>>  psim psim-gdb: gdb-sim-run.in gdb-sim.in psim.in
>>>>       ./mkrun yes PowerPC powerpc psim
>>>> diff --git a/sim-scripts/or1ksim.in b/sim-scripts/or1ksim.in
>>>> new file mode 100644
>>>> index 0000000..3f59e47
>>>> --- /dev/null
>>>> +++ b/sim-scripts/or1ksim.in
>>>> @@ -0,0 +1,155 @@
>>>> +#  or1k/or1ksim Support
>>>> +bspSupportsGDBServerMode="yes"
>>>> +runBSP=or32-elf-sim
>>>> +bspTreeFile=sim.cfg
>>>> +runARGS()
>>>> +  echo "-f ${bspTreeFile} ${1}"
>>>> +checkBSPFaults()
>>>> +  return 0
>>>> +bspLimit()
>>>> +  testname=$1
>>>> +  case ${testname} in
>>>> +    *stackchk*)limit=5 ;;
>>>> +    *fatal*)   limit=1 ;;
>>>> +    *minimum*) limit=1 ;;
>>>> +    *psxtime*) limit=180 ;;
>>>> +    *)         limit=60 ;;
>>>> +  esac
>>>> +  echo ${limit}
>>>> +bspGeneratesGDBCommands="yes"
>>>> +gdbServerARGS()
>>>> +  echo "-c ${bspTreeFile}"
>>>> +bspGenerateGDBCommands()
>>>> +cat <<EOF
>>>> +tar remote :50001
>>>> +EOF
>>>> +### Generate the or1ksim device tree based upon the type of application being run
>>>> +bspGenerateDeviceTree()
>>>> +cat <<EOF
>>>> +section memory
>>>> +  name     =      "RAM"
>>>> +  random_seed = 12345
>>>> +  type        = random
>>>> +  ce       =          0
>>>> +  mc       =          0
>>>> +  baseaddr = 0x00000000
>>>> +  size     = 0x08000000
>>>> +  delayr   =          1
>>>> +  delayw   =          2
>>>> +end
>>>> +section immu
>>>> +  enabled = 0
>>>> +  nsets = 64
>>>> +  nways = 1
>>>> +  pagesize = 8192
>>>> +  hitdelay = 0
>>>> +  missdelay = 0
>>>> +end
>>>> +section dmmu
>>>> +  enabled = 0
>>>> +  nsets = 64
>>>> +  nways = 1
>>>> +  pagesize = 8192
>>>> +  hitdelay = 0
>>>> +  missdelay = 0
>>>> +end
>>>> +section mc
>>>> +  enabled = 0
>>>> +  baseaddr = 0x90000000
>>>> +  POC = 0x0000000a                 /* 32 bit SSRAM */
>>>> +  index = 0
>>>> +end
>>>> +section ic
>>>> +  enabled   =   0
>>>> +  nsets     = 256
>>>> +  nways     =   1
>>>> +  blocksize =  16
>>>> +  hitdelay  =  20
>>>> +  missdelay =  20
>>>> +end
>>>> +section dc
>>>> +  enabled = 0
>>>> +  nsets = 256
>>>> +  nways = 1
>>>> +  blocksize = 16
>>>> +  load_hitdelay = 0
>>>> +  load_missdelay = 0
>>>> +  store_hitdelay = 0
>>>> +  store_missdelay = 0
>>>> +end
>>>> +section pic
>>>> +  enabled = 1
>>>> +  edge_trigger = 1
>>>> +end
>>>> +section sim
>>>> +  verbose  =  1
>>>> +  debug    =  0
>>>> +  profile  =  0
>>>> +  history  =  0
>>>> +  clkcycle = 10ns            /* 100MHz clock */
>>>> +end
>>>> +section VAPI
>>>> +  enabled = 1
>>>> +  server_port = 50000
>>>> +  log_enabled = 1
>>>> +  vapi_log_file = "vapi.log"
>>>> +end
>>>> +section cpu
>>>> +  ver = 0x12
>>>> +  cfg = 0x00
>>>> +  rev = 0x0001
>>>> +  superscalar = 0
>>>> +  hazards = 0
>>>> +  dependstats = 0
>>>> +  sbuf_len = 100
>>>> +end
>>>> +section debug
>>>> + enabled = 1
>>>> + rsp_enabled = 1
>>>> + rsp_port = 50001
>>>> +end
>>>> +section uart
>>>> +  enabled  = 1
>>>> +  #channel = "xterm"
>>>> +  channel = "file:uart0.rx,uart0.tx"
>>>> +  irq = 2
>>>> +  16550    = 1
>>>> +end
>>>> +section pm
>>>> +  enabled = 1
>>>> +end
>>>> +EOF
>>>> +bspGeneratesDeviceTree="yes"
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
