[PATCH] Add or1ksim (sim.cfg) configuration file and edit README.
Tue Aug 26 20:34:05 UTC 2014
Now committed.
Thanks.
On 8/26/2014 2:42 PM, Hesham ALMatary wrote:
> OpenRISC/or1ksim BSP: The new sim.cfg file configures or1ksim emulator with HW
> capabilities that the current RTEMS/or1ksim BSP supports.
> README: HOWTO run the or1ksim simulator.
>  c/src/lib/libbsp/or1k/or1ksim/README  |  20 ++++++-
>  c/src/lib/libbsp/or1k/or1ksim/sim.cfg | 104 ++++++++++++++++++++++++++++++++++
>  2 files changed, 123 insertions(+), 1 deletion(-)
>  create mode 100644 c/src/lib/libbsp/or1k/or1ksim/sim.cfg
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/README b/c/src/lib/libbsp/or1k/or1ksim/README
> index 43b4703..dfa3cb1 100644
> --- a/c/src/lib/libbsp/or1k/or1ksim/README
> +++ b/c/src/lib/libbsp/or1k/or1ksim/README
> @@ -14,4 +14,22 @@ Configuration file "sim.cfg" should be provided for complex board
>  configurations at the current directory (which you run or1ksim from) or at
>  ~/.or1k/
> -sim -f sim.cfg hello.exe
> +The current sim.cfg file that configures or1ksim emulator to RTEMS/or1ksim BSP
> +is at the same directory as this README. You can also use or1ksim script from
> +rtems-tools/sim-scripts.
> +From command line type:
> +sim -f sim.cfg $PATH_TO_RTEMS_EXE
> +or (if you use a stable or1ksim release)
> +or32-elf-sim -f sim.cfg $PATH_TO_RTEMS_EXE
> +from sim-scripts:
> +or1ksim $PATH_TO_RTEMS_EXE
> +and then attach GDB to or1ksim from another terminal by running
> +or1ksim-gdb $PATH_TO_RTEMS_EXE
> diff --git a/c/src/lib/libbsp/or1k/or1ksim/sim.cfg b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
> new file mode 100644
> index 0000000..cfc3d2b
> --- /dev/null
> +++ b/c/src/lib/libbsp/or1k/or1ksim/sim.cfg
> @@ -0,0 +1,104 @@
> +section memory
> +  name     =      "RAM"
> +  random_seed = 12345
> +  type        = random
> +  ce       =          0
> +  mc       =          0
> +  baseaddr = 0x00000000
> +  size     = 0x08000000
> +  delayr   =          1
> +  delayw   =          2
> +end
> +section immu
> +  enabled = 0
> +  nsets = 64
> +  nways = 1
> +  pagesize = 8192
> +  hitdelay = 0
> +  missdelay = 0
> +end
> +section dmmu
> +  enabled = 0
> +  nsets = 64
> +  nways = 1
> +  pagesize = 8192
> +  hitdelay = 0
> +  missdelay = 0
> +end
> +section mc
> +  enabled = 0
> +  baseaddr = 0x90000000
> +  POC = 0x0000000a                 /* 32 bit SSRAM */
> +  index = 0
> +end
> +section ic
> +  enabled   =   0
> +  nsets     = 256
> +  nways     =   1
> +  blocksize =  16
> +  hitdelay  =  20
> +  missdelay =  20
> +end
> +section dc
> +  enabled = 0
> +  nsets = 256
> +  nways = 1
> +  blocksize = 16
> +  load_hitdelay = 0
> +  load_missdelay = 0
> +  store_hitdelay = 0
> +  store_missdelay = 0
> +end
> +section pic
> +  enabled = 1
> +  edge_trigger = 1
> +end
> +section sim
> +  verbose  =  1
> +  debug    =  0
> +  profile  =  0
> +  history  =  0
> +  clkcycle = 10ns		/* 100MHz clock */
> +end
> +section VAPI
> +  enabled = 1
> +  server_port = 50000
> +  log_enabled = 1
> +  vapi_log_file = "vapi.log"
> +end
> +section cpu
> +  ver = 0x12
> +  cfg = 0x00
> +  rev = 0x0001
> +  superscalar = 0
> +  hazards = 0
> +  dependstats = 0
> +  sbuf_len = 100
> +end
> +section debug
> + enabled = 1
> + rsp_enabled = 1
> + rsp_port = 50001
> +end
> +section uart
> +  enabled  = 1
> + #channel = "xterm"
> +  channel = "file:uart0.rx,uart0.tx"
> +  irq = 2
> +  16550    = 1
> +end
> +section pm
> +  enabled = 1
> +end
