Using rtl-host in covor - some questions
Wed Aug 27 01:39:25 UTC 2014
On 27/08/2014 5:07 am, Joel Sherrill wrote:
> Chris.. ping?
I am looking at this. It will take some time to sort out. I suggest
changes be committed to covoar assuming the current rtl-host code and if
someone needs to built it they copy the code in. I can clean up the
building as I sort out the merge.
> Do we need to remove things from rtems-testing since the
> official version is not in rtems-tools?
Is the rtems-testing version of the code being updated ?
> And what about the rtl-host build dependency? Is it time to
> move it as well?
Yes. I need to figure out how to do this. The rtl-host code has the
library and then the actual tools and this may be separated. I also need
to get the code into a structure that lets waf manage it and I this is
what I need to look at.
