USB Host and MMC/SD Card Stack
Wed Aug 27 12:19:44 UTC 2014
Hello,
I added a USB host and MMC/SD card stack for RTEMS (libusb) to my Git
repository area:
http://git.rtems.org/sebh/rtems-libusb.git/
It was previously only available as a snapshot:
https://www.rtems.org/bugzilla/show_bug.cgi?id=1601
The USB host stack is a port from FreeBSD 8.  The MMC/SD card stack is a port
from FreeBSD 9.3.
The libusb is a subset an older version of the libbsd which contains also the
network stack from FreeBSD 9.3.  We use libusb on some boards and projects.  I
simply had no time to test the USB and MMC/SD parts in libbsd.
http://git.rtems.org/rtems-libbsd/
Both libraries lack documentation.  The basic network stack in libbsd works
well, but more work is required to polish it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
