capture engine ref_count question
Wed Aug 27 13:05:10 UTC 2014
On August 27, 2014 7:33:28 AM CDT, Daniel Hellstrom <daniel at gaisler.com> wrote:
>Hi,
>On 08/27/2014 02:39 AM, Chris Johns wrote:
>> On 27/08/2014 3:50 am, Jennifer Averett wrote:
>>>  > We suggest to remove the ref_count of the task structures to save
>>>  > time and locking. Otherwise we need atomic counters here?
>> You need a means of tracking the logged references to the task data
>in the trace log. The log can exist well past the life time of the task
>and the data.
>Yes, I thought that was inline with what we suggested.
>>>  > We suggest to free task structures when reading, by recording
>time of
>>>  > task deletion event we know when last event referencing the task
>>> occurred,
>> I do not like this approach.
>Allocating and freeing memory in the trace recording path introduces
>jitter in adding records, it requires taking a SMP lock.
>>>  > when that time have passed it should be okay to free the task
>structure?
>>> Can anyone see a problem with this.   My question is will this
>always
>>> work based on the zombie state of the thread?  I thought I saw
>> You cannot remove the ref_counts without an equivalent. The data is
>referenced beyond the life of a task.
>Do you mean that there will be references to the task struct after the
>task delete record has been read? I assumed that the task delete was
>the last record referencing the task struct?
>> Another approach could involve adding the task data to the trace
>buffer when the first reference to the task is added to the trace
>buffer. You would add the task data tagging it with some sort of
>> "id". When added events related to the task the "id" is used. The
>trace buffer decoder extracts the task data building a suitable table
>to decode the following "id" references. There is a small
>> extra bump filling the trace buffer with the task details but this is
>the cost of tracing in software. This approach helps solves the problem
>of off board streaming of the trace data.
>I like this approach much better, but I assumed it would be harder to
>implement. Then we could basically remove the task struct.. That would
>solve allocation/freeing of the task structs too?
This is impossible or at least very complicated  to implement. The trace buffers are a circular queue and you would end up with gaps in the middle which would have to be preserved across reads of records and wrapping.
Using an id may require a global lock but we can use the same basic algorithm as the id look up and be deterministic.
>Thanks,
>Daniel Hellstrom
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
